1+ Year Old Media Results
Postby [buck] on Sat Jul 29, 2006 2:52 am
After seeing Dolph's results with his old review media, I was inspired dig up some of my older media (12-18 months old) and scan them. :) Over the past few weeks, I've been able to scan 39 older discs for which I have initial scans for.
Just a few notes:
  • All discs were originally burned in a BenQ DW1620 with B7P9, B7T9, B7U9 or B7V9 firmware.
  • All discs were originally scanned in the same BenQ DW1620 with the same firmware as they were burned with.
  • All discs were rescanned in the same drive with the same firmware as they were orignally scanned in.
  • Unfortunately, the discs were rescanned with a different CD Speed version (v4.51.1) than they were orginally scanned with simply because I have no way of knowing exactly which version of CD Speed I used initially :(
  • Discs were stored in cheapie DVD cases or a Case Logic CD/DVD wallet.
    edit: I updated each post to specifically state how each disc was stored :D
  • I don't have the *exact* dates of when these discs were burned, but my guesses should be accurate to within a month or so.
  • Unless stated otherwise, all discs are in good physical condition with minimal scratches/dust (I made sure to dust off every disc with canned air before rescanning).
I should also mention that the initial scans were not always performed under ideal circumstances, which is reflected by the not-so-straight reading line seen in many scans :P
The first pic will be the original scan, and the second pic will be the rescan.
Let me know if you have any questions or requests! :D
update: I assigned every disc a number for easier referencing :)
Postby [buck] on Sat Jul 29, 2006 2:53 am
Disc # 001
Fujifilm DVD+R 8X (Made in Japan)
YUDEN000T02 burned @ 12X in BenQ DW1620 B7T9
Burned: mid February 2005
Rescanned: July 04 2006
Stamper serial: TG001133 0201
Stored in poor quality DVD case
Postby [buck] on Sat Jul 29, 2006 2:54 am
Disc # 002
YUDEN000T02 burned @ 8X in BenQ DW1620 B7T9
Burned: late February 2005
Postby [buck] on Sat Jul 29, 2006 2:55 am
Disc # 003
YUDEN000T02 burned @ 12X in BenQ DW1620 B7U9
Stamper serial: TG001133 1602
Postby [buck] on Sat Jul 29, 2006 2:56 am
Disc # 004
Postby [buck] on Sat Jul 29, 2006 2:58 am
Disc # 005
YUDEN000T02 burned @ 12X in BenQ DW1620 B7V9
Burned: late April 2005
Rescanned: July 13 2006
Stored in Case Logic wallet
Postby [buck] on Sat Jul 29, 2006 2:59 am
Disc # 006
Burned: early June 2005
Rescanned: July 18 2006
Stamper serial: TG001159 0604
Postby [buck] on Sat Jul 29, 2006 3:00 am
Disc # 007
YUDEN000T02 burned @ 8X in BenQ DW1620 B7V9
Burned: early July 2005
Postby [buck] on Sat Jul 29, 2006 3:01 am
Disc # 008
Burned: mid July 2005
Disc # 009
Fujifilm DVD-R 8X (Made in Japan)
TYG02 burned @ 8X in BenQ DW1620 B7T9
Burned: early May 2005
Stamper serial: GG000103 0501
Postby [buck] on Sat Jul 29, 2006 3:02 am
Disc # 010
TYG02 burned @ 8X in BenQ DW1620 B7V9
Burned: early April 2005
Rescanned: July 05 2006
Postby [buck] on Sat Jul 29, 2006 3:03 am
Disc # 011
Postby [buck] on Sat Jul 29, 2006 3:04 am
Disc # 012
Verbatim DVD-R 8X Silver Thermal Printable (made in Taiwan by Prodisc)
MCC02RG20 burned @ 8X in BenQ DW1620 B7T9
Burned: mid December 2004
Rescanned: July 17 2006
Disc # 013
Postby [buck] on Sat Jul 29, 2006 3:05 am
Disc # 014
MCC02RG20 burned @ 8X in BenQ DW1620 B7P9
Burned: December 2004
Postby [buck] on Sat Jul 29, 2006 3:06 am
Disc # 015
MCC02RG20 burned @ 8X in BenQ DW1620 B7U9
Burned: mid January 2005
Postby [buck] on Sat Jul 29, 2006 3:07 am
Disc # 016
Burned: early February 2005
Disc # 017
Postby [buck] on Sat Jul 29, 2006 3:08 am
Disc # 018
Postby [buck] on Sat Jul 29, 2006 3:09 am
Disc # 019
Postby [buck] on Sat Jul 29, 2006 3:10 am
Disc # 020
Postby [buck] on Sat Jul 29, 2006 3:11 am
Disc # 021
unbranded Taiyo Yuden DVD+R 8X (Made in Japan)
YUDEN000T02 burned @ 16X in BenQ DW1620 B7U9
Burned: February 2005
Stamper serial: TG001158 0305
Postby [buck] on Sat Jul 29, 2006 3:13 am
Disc # 022
Maxell DVD+R 8X (Made in Japan)
MAXELL002 burned @ 8X in BenQ DW1620 B7P9
Burned: mid April 2005
Postby [buck] on Sat Jul 29, 2006 3:14 am
Disc # 023
MAXELL002 burned @ 8X in BenQ DW1620 B7V9
Postby [buck] on Sat Jul 29, 2006 3:15 am
Disc # 024
