Costco TDK DVD-Rs from BOGO sale
Postby dolphinius_rex on Sat Feb 04, 2006 2:27 pm
Since it has been mentioned here on this forum before, I thought I should post some of my results with testing the TDK 16x white inkjet printable media, often sold at Costco on a buy one get one free sale (~$45 CAD for 200 discs).
So far, I've burned 2 discs, and both have made me believe my initial thoughts on them were correct. This media is low grade stuff, probably B Grade or worse.
The first disc was burned in the DVR-110 running firmware 1.37. I've attached a picture of the burn, and my test of it in my DW1640.
Postby dolphinius_rex on Sat Feb 04, 2006 2:30 pm
I then burned a disc in my BenQ DW1640. The speed was automatically pushed down to 4x by the WOPC. I think it probably kept the disc from turning out like the one burned on the Pioneer! But it still isn't that good :o
Postby dolphinius_rex on Sat Feb 04, 2006 2:32 pm
I hope to do further testing on this media, and eventually test the 16x DVD+Rs as well.... but it depends a lot on if I can find time.
Postby eric93se on Sat Feb 04, 2006 3:23 pm
I knew to get the +R's on that sale and MII instead of MIT :D
BTW, I have seen excellent burns with that TTH02 stuff
Pioneer 110 at 12x, FW 8,37
Benq BSLB 12x SB off
Benq BSOB 12x SB off
Benq DW-1640
eric93se
Postby dolphinius_rex on Sat Feb 04, 2006 4:14 pm
well, what I'm trying to get across here is that the media is highly variable, and risky.
Postby eric93se on Sat Feb 04, 2006 5:01 pm
I meant to say that wopc was off on the 1640 (SB off too).
For whatever reason I get better burn with wopc off, with pretty much every media. Others get really good results with it on, so I guess the drives do in fact vary, as well as the media as you pointed out.
Benq DW-1640
eric93se
Postby RJW on Mon Feb 06, 2006 9:12 am
MMI with TDK code hmm interresting move.
Postby eric93se on Mon Feb 06, 2006 11:27 am
RJW wrote:MMI with TDK code hmm interresting move.
I know in the begining MII media was quite poor. Most recent scans of MII media looked quite good, and that prompted me to get some.
MIJ>MII>MIT>MIC I think EU makes media now, don't know where they would fit in though. :)
Benq DW-1640
eric93se
Postby RJW on Mon Feb 06, 2006 1:38 pm
TDK's own manufacturing sites are luxembourg and Japan. These are the places that make most new stuff (demonstrating technology).
Quality of luxembourg is good.
Then there is CMC (and probally also RITEk but I have to double check that one still) who make media in Taiwan.
And then there is MBIL in India.
The point why I was suprised about the TDK code is that all OEM jobs befor done by MBIL for TDK (good consistant media) had MBIL's own codes.
