dolphinius_rex wrote:MAM-A/MAM-E makes some media for TDK as well. The MAM-A 8x DVD-Rs I have are TTH01.
Given the good performance of the TDK media in the C't test... I'm not sure WHO made it
alexnoe wrote:IIRC TTH01 is 16x compatible in a few drives (e.g. NEC 3500), TTG02 shouldn't be written faster than 8x
Scour wrote:alexnoe wrote:IIRC TTH01 is 16x compatible in a few drives (e.g. NEC 3500), TTG02 shouldn't be written faster than 8x
So I still can´t believe that MAM manufacture such good media
Gary Kokkin wrote:
MAME were very reliable media company in CDR times ,after deal with Mitsui Japan-Unfortunately bought last years by an Italian Milanese low cost media trade company have relations with Plasmon and small production in Italy-
MAME had strong second tier clients for European release, like Emptec,MMore,Creation,Imation but Italian company targets custom Paneuropean supermarket media brands like Makro,Carefour,Lidl
Main factory are still in use in France,but alwayw depends on Italian management target products group-So I think TDK's production maybe temporary for some availibility reason in some market.
I have old MItsui-CDR-media and some MAM-E 48x. The MAM are no match for the original Mitsui.
Saw the test in c´t and all MAM-branded-media was bad in burn-quality, otherwise the TDK TTH01 had good quality with all tested writers, so I can´t believe that MAM make this media
Are you saying that manufacturers can't have higher grade OEM discs? Look at CMC if you want an example, or even Ritek. Lead Data also has been able to make good OEM discs!
So even if the quality of MAM-E's normal stuff is not very good, then that doesn't rule out the possability of them working extra hard for an OEM customer.
Still, I'm not saying they WERE made by MAM-E, we would need to know the country of origin to be 100% sure.
That´s a good point.
CMC makes good disc´s for MCC and TDK, Ritek have good Ricoh-media. Lead Data? You mean CDR for Sony?
Can you tell me were your TTH01-media is coming from?
Scour wrote:Hello!
I want to test this media, but I´m not sure when I order tDK -R 8x if I get TTH01 or TTG02
dolphinius_rex wrote:Scour wrote:Hello!
Well, why not try ordering MAM-E 8x DVD-Rs? Ask for the TDK code![]()
*OR* just look for TDK made in France DVDRs.
Gen-An wrote:I thought TTH01 was made in Luxembourg at TDK's plant there...
Scour wrote:dolphinius_rex wrote:Scour wrote:Hello!
Never saw a MAM with that code (see c´t-Thread)
There's some included in my BenQ DW1640 review I'm working on![]()
But they aren't the TDK brand ones, they are MAM-A brand ones.
I already look forward to it
So far 83 DVDRs burned and counting... including 8 different brands of DVDRDL (well, 7 DVD+RDL and 1 DVD-RDL)
Much overspeeding included?
