LG GCE-8520B strange problems.
Postby heappy on Thu May 22, 2003 5:49 pm
Hi all.
I've recently bought an LG GCE-8520b recorder after my old TEAC CD-540E sadly passed away. I must say I am not satisfied with LG because:
* Windows 2000 option "Enable digital audio for this device" is not working - when I try to enable it, I get a warning saying "This device has not been shown to support digital audio playback. You may have problems." And I do hear all kinds of pops and clicks whenever I play an audio CD (tested on different original CDs) with this option on, or with Winamp's CDReader plugin.
* It will sometimes not recognize medias, while other times everything is perfectly Ok. It is not media-related because I use only one kind of media, plus it happens with the same CD.
* EAC will not recognize it as a writer with blank CD-Rs ("Can't determine write speeds"), while when using CD-RW everything is smooth.
* Plus sometimes when I try to check media info (with various programms), it gets stuck, and won't eject the CD-R.
I've tried all kinds of solutions - reinstalling IDE drivers for Windows, reinstalling ASPI layer, I've flashed it with 1.04 firmware, and I even flashed it with a GCE-8480B firmware (this time EAC seemed to work fine), but it stays the same. I've tried it on different PC - same thing. I replaced it in the shop, but nothing changed.
I have to say that I own a LG GCE-8400B for some time now, and I'm more than satisfied with it. It's a shame I can't buy another one like it.
My config: Windows 2000, LG is connected as secondary master with no slave.
I'll be glad to hear any suggestions.
heappy
Postby CDRecorder on Thu May 22, 2003 8:24 pm
Welcome to CDRLabs, heappy! :D
Have you updated your firmware? I would recommend that you upgrade it to the latest version if you haven't already. You can download the upgrade at LG's website.
Postby jedimc on Fri May 23, 2003 2:36 am
I had none of the problems you have,It Automatically had "Enable digital audio for this device" on and i have never had trouble playing music, try using other music and see if its the same.it could be a windows 2000 problem have you updated all your ide drivers.
my config:windows ME, intel 810e chipset,Lg connected to secondary master
and Samsung CD-ROM SC-148T
jedimc
Postby heappy on Fri May 23, 2003 2:56 am
LiteOnGuy wrote:Welcome to CDRLabs, heappy!
Thanks, glad to join.
I have tried all of these things with 1.0 firmware that the drive came with, then I flashed with 1.04 - the problems stayed, and then I tried 1.06 firmware for GCE-8480b - I deliberatly slowed it down. The problems stayed (except for EAC not recording), and some others have shown. I'm now back to 1.04.
It is not disc problem, since I tried several original discs, plus these discs play fine in GCE-8400 and even in my 8-years old home stereo.
I did reinstall IDE drivers several times. But what's worst, I tried to install it on another PC, with completely different configuration, the only thing that is the same is Win2K (but the drivers are of course different) - no changes (the GCE-8400B though works fine on that same PC).
heappy
Postby CDRecorder on Fri May 23, 2003 3:09 am
Maybe the drive is just bad. :(
If it wouldn't be too hard, I think your best option would be to exchange it for another.
Postby Scrondar on Fri May 23, 2003 4:30 pm
Is it possible this is your problem? As solid as Win2K is as network client, I never (after using it for about a year) found it to be as hardware or multimedia freindly as I needed at home. WinXP Pro, however, has been a joy for all my upgrades, and my 8520B runs like a quiet rocket on it. EAC, CloneCD, Roxio, it all works flawlessly with the LG for me.
Scrondar
