CD WRITER:burning only works at lower speed
Postby joebf86 on Mon May 23, 2005 12:50 pm
i have a problem. my Cd Writer used to be working well till recently burning process always failed. i mean burning audio cds. when i burn
and today i tried again, but i used a lower speed, 12X, if i m not mistaken. and the burning process went well.
so maybe i can conclude that it works if only at lower speed...
could it be that the cd-writer has worn out? it's 3 years old...
anyone has the answer to my question?
i would really appreciate ur help.
joebf86
Postby TheWizard on Tue May 24, 2005 12:42 am
First step would be to try different blank discs. Try a different brand/manufacturer and see if you can burn at a faster speed.
What burner are you using? Make and model please.
No, I like women.
Postby SkaarjMaster on Tue May 24, 2005 12:10 pm
Also, could be the burning software just doesn't like the higher speeds anymore..........maybe it needs to be reinstalled. Do you have the latest firmware for your burner?
SkaarjMaster
Postby joebf86 on Wed May 25, 2005 10:27 am
liteon 48x12x12x
joebf86
Postby TheWizard on Thu May 26, 2005 7:31 pm
If it is the Lite-On LTR-48125W we are talking about, then look for it in the Media Compatibility Thread. You will find plenty of discs that burn over 12X; buy a pack of them to ensure better burning results. Double-check to see if the discs you are currently burning at only 12X are in the thread. They may be listed and the results may speak for themselves.
I would also recommend what SkaarjMaster said, check the firmware of your burner. A program like Nero CD-DVD Speed can inform you of the firmware, as well as other programs.
No, I like women.
