What dvd rom best for ripping dvd(especially Lilo and stitc)
How fast is too fast?
Postby xboxnoob on Tue Jan 11, 2005 1:51 pm
Got a Lite On dual DVD -+r burner - but got proplems ripping dvd's like some cartoons and some other dvd's - anyone rcomend a good dvd rom to supply my burner for this ?
T.I.A. :lol:
Cheers
John
Denmark
"Experience is something you don't get until just after you need it."
xboxnoob
Postby Spazmogen on Tue Jan 11, 2005 2:16 pm
I sugguest you edit your post to remove the name of the movies.
If your DVD burner can play them, you can copy them. All you need is software.
Postby xboxnoob on Tue Jan 11, 2005 5:21 pm
Names removed..
The question is because i can play them in my stationary denver dvd player - but not rip them with my recorder (only probs with some of the movies) - so i just wanted to ask if any one got a good suggestion for a intern dvd player for reading dvd's
Cheers
John
Denmark
xboxnoob
Postby spryfly on Tue Jan 11, 2005 10:58 pm
I think that there is a language barrier here.......
"Why? Said the spry little fly."
Nec 3500 LD V2 B6 Quiet
Benq 1620 B7T9 Stock
Liteon 1633sx BS41 Patched for 12x DL Ripping
spryfly
Postby cfitz on Tue Jan 11, 2005 11:41 pm
You said you are having trouble ripping some DVDs on your Lite-On DVD burner. You also said you can play those same DVDs on a stand-alone (stationary) DVD player.
My question to you: Can you play those same DVDs on your Lite-On DVD burner? If so, then you should also be able rip them with the Lite-On. You just need the right software. That is what Spazmogen was telling you.
Click on this link or this link for some software to help you rip those DVDs.
Postby xboxnoob on Wed Jan 12, 2005 5:10 am
Ye - well - got all the software - but cannot rip them on the Lite On (SOHW 1633S burner)... Problem is i had a intern DVD Rom that could but i cannot remember if it was the Asus 616 or another Asus model..
Cheers
John
Denmark
xboxnoob
Postby Jim on Wed Jan 12, 2005 6:27 am
Why can't you rip them? What software are you using and what error are you receiving?
Jim
Postby MadBurner on Thu Jan 13, 2005 7:13 am
Install AnyDVD from SlySoft and see if that will solve your problem.
MB
MadBurner
