What could be the problem?
Postby henik on Wed Apr 27, 2005 10:51 pm
When I make an audio CD & play the compilation in my car or at home, starting at the begining, the CD will start playing right away. If I jump to track 7 ot higher it takes quite a while for it to start playing. Almost sounds like the deck is searching where the start of the track is, but is having trouble finding it.
I have ruled out the problem with my car deck as I borrowed a home made compilation CD and it would start playing right away regardless of which track I entered.
I am using Nero 6 with all the latest updates. My CD burner is a Lite On LTR. I am using TDK CDR & always burn at the slowest speed (8X).
Two possible problems that I can think of that are causing this. The burner or the software. Has anyone encountered a problem like this?
I don't want to buy another burner if that's not my problem.
henik
Postby hoxlund on Thu Apr 28, 2005 2:58 am
we need a more exact model number then LTR, theres going to be numbers followed after the LTR part, like ltr-48125w
in my expertise you can never go wrong with TY cd media, ive used them ever since my first cd-rw drive which was a litey ltr-48125w, which i still have in an old machine
Postby Bhairav on Thu Apr 28, 2005 10:56 am
hoxlund wrote:we need a more exact model number then LTR, theres going to be numbers followed after the LTR part, like ltr-48125w
You STARTED writing CDRWs on a 48X drive?? Man.. I feel old. First drive was a Sony CRX140E, 8/4/32!
Postby hoxlund on Thu Apr 28, 2005 10:59 am
no i wrote cd-r on 48x, haha just kidding i knew what you meant
actually my very first drive was a iomega 8/4/32, but i didn't want to date myself either
Burner number
Postby henik on Thu Apr 28, 2005 9:04 pm
The CD burner is a Lite On LTR 321231 if that helps.
henik
