Question storage DVD Media
Postby gamemaniaco1987 on Mon Nov 15, 2021 7:18 am
Which is worse for dvd and mdisc dvd lifespan, high temperature or high humidity?
gamemaniaco1987
Re: Question storage DVD Media
Postby Ian on Tue Nov 16, 2021 5:35 pm
I'm going to say high temperature
Postby gamemaniaco1987 on Tue Nov 16, 2021 6:22 pm
in my room I use a dehumidifier but it raises the temperature by 1 or 2 degrees (32-34ºC), if I turn it off the temperature drops and the humidity rises to 60-70%
with dehumidifier the humidity goes to 55-58%
gamemaniaco1987
Postby gamemaniaco1987 on Sun Nov 28, 2021 9:26 am
somebody???
gamemaniaco1987
Postby Ian on Tue Nov 30, 2021 1:54 pm
I think we've talked about this before. IMO, a degree or two doesn't really matter. No matter what, your temperatures are pretty hot. Same goes with humidity. Even with the humidifier, the humidity is higher than ideal for long term storage.
Postby gamemaniaco1987 on Tue Nov 30, 2021 2:26 pm
if I put the dehumidifier on longer the humidity may drop to 50% but the temperature will be between 34-35C
gamemaniaco1987
Postby Ian on Tue Nov 30, 2021 3:19 pm
Can I ask what the long term goal is for this?
Postby gamemaniaco1987 on Tue Nov 30, 2021 3:35 pm
these are important files of mine from games burned on dvd mdisc verbatim
Do you know any optical disc (DVD) engineer?
gamemaniaco1987
Postby Ian on Tue Nov 30, 2021 4:42 pm
Do you have anywhere else you can store them like a relatives house or even a safety deposit box where the temperatures and humidity are lower?
Postby gamemaniaco1987 on Tue Nov 30, 2021 7:15 pm
No
gamemaniaco1987
Postby stix on Sun Dec 26, 2021 6:16 am
the solution might be to loosen up behind the game console.
stix
stix
