a new sound card
a new sound card
Postby coonsanders on Sat Jun 20, 2009 3:36 pm
hi gang
i just installed a new soundcard but when i looked at my devise manager its listed in yellow as a "multimedia audio controller" in yellow.i know this isnt good so what can i do?i uninstalled everything(soundcard and drivers)and rein-
stalled them but still have this issue..what else can i do?
lenny
coonsanders
Re: a new sound card
Postby Ian on Sat Jun 20, 2009 3:48 pm
It's probably missing the driver. If you view the properties, it will tell you what the issue is.
Postby coonsanders on Sat Jun 20, 2009 3:56 pm
hi
it said code 1 when i looked...
lenny
coonsanders
Postby coonsanders on Sat Jun 20, 2009 4:30 pm
hi
the issue seems to be with the multimedia audio controler...thats whats in yellow.the card seems to be ok...
lenny
coonsanders
Postby Ian on Sat Jun 20, 2009 10:42 pm
Soundcards usually have multiple pieces within the device manager. The multimedia audio controler is probably one of them.
Postby coonsanders on Sun Jun 21, 2009 6:20 am
o ok thanks ian...
lenny
coonsanders
Postby Ian on Mon Jun 22, 2009 8:49 am
Okay, do this. Right click on the multimedia audio controller in device manager and choose properties. Under the General tab, it lists the device status. Copy and paste this text or post a screenshot so we know exactly what the issue is.
Also, if you look under Details, there is a Device Instance ID. If you post that, I can try to figure out what the multimedia audio controller actually is.
Postby coonsanders on Mon Jun 22, 2009 9:01 am
hi
well i was told its a bios conflick by a friend who knows computers....
lenny
coonsanders
Postby coonsanders on Mon Jun 22, 2009 1:11 pm
hi
success i turned off the sound in my f2 setup...it wasnt the bios at all.thanks..
lenny
coonsanders
