Very strange problem
Postby jeanluc_67 on Tue May 11, 2004 12:47 pm
Hi all..
After using D2D6 on a data dvd I closed it out and ejected it. I have had no problems using it and seeing what is on it for days on end. Then I put it in recently and now it shows three files...autorun, udfrchk, ufdrinstl.zl. I have used scan disk to save the original files but it has happened on other disks as well now. Has anyone had anything similar to this happen to them? I am using W2000 and a Micro Advantage DVD+-RW/CD-RW superdrive with 3M media.
Thanks!
jeanluc_67
Postby tazdevl on Tue May 11, 2004 2:19 pm
Please only post a topic once.
RIG:
tazdevl
