Verbatim Producer 4
Verbatim Producer 4
Postby homenetman on Sat Apr 19, 2003 11:05 am
Does anyone have any info or experience on the Verbatim Producer 4, the 4x model from this company. BestBuy has on sale for $229, but I can't find any reviews on the drive. Must be using someone's drive (Ricoh? NEC?) but I can't find that out either. Thanks.
homenetman
Postby Ian on Sat Apr 19, 2003 11:37 am
It's based on the NEC ND-1100A
Postby Banshee on Wed Apr 23, 2003 7:50 pm
Ian, not only is it the ND-1100A, it's also with the newer firmware, 1.A0, not the 1.60 or 1.70's. They changed the way thhey made the drive a bit, resulting in a higher yield to keep up with demands from vendors.
Banshee
Coder - http://www.planetquake.com/alliance and http://www.lrctf.com
Editor-in-Chief - http://www.pcextremist.com
President and Videographer - http://www.velocitymc.org
Banshee
Postby Kennyshin on Thu Apr 24, 2003 2:33 am
Banshee wrote:Ian, not only is it the ND-1100A, it's also with the newer firmware, 1.A0, not the 1.60 or 1.70's. They changed the way thhey made the drive a bit, resulting in a higher yield to keep up with demands from vendors.
Good news to hear.
Kennyshin
