Using Nero5 Erased CDrw's for Re-use w/DCD?
Postby EEG161 on Tue Mar 18, 2003 8:58 pm
Can I erase CDrws using Nero5's deep erase option on CDrws that were DirectCD 5 formatted to reuse with DCD? I have DCD custom installed and have no DCD erase option. Just wondering, please advise.
EEG161
Postby Inertia on Tue Mar 18, 2003 9:41 pm
You can erase any CD-RW with any program and reuse it with any program.
If you erase the CD-RW, you will have to reformat it to use it for packet writing with DirectCD.
If you simply "delete" the files on the CD-RW in Explorer, you can free all of the available capacity and reuse the disc in DirectCD without having to erase and reformat it.
Inertia
Postby EEG161 on Thu Mar 20, 2003 12:04 pm
Yes, it works, thanks. :D
EEG161
