using GigaRec with Nero
Postby aviationwiz on Fri Jun 06, 2003 8:06 am
On the Plextor Premium, can I set up GigaRec on the Plextools Pro Software and then burn the CD with Nero if I set up overburning?
Postby alchip80 on Fri Jun 06, 2003 1:07 pm
aviationwiz.
Yes you can, you will notice that Plextools will automatically set the burn speed in nero, just use the parameters you set in Plextools in the overburn section of your Nero preferences. If you don't use Plextools you will not be able to overburn by that amount.
alchip80
