EDIT: Nevermind, the last 3 DVD-Rs in the stack were bad. I just burned all the data on one DVD+R DL in the Pioneer with Nero and no problems!!! Of course, anyone that wants to agree with my conclusion, feel free to comment.
4.8.2011
ISO compilation
10:08:06 PM #1 Text 0 File Isodoc.cpp, Line 6194
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
10:08:06 PM #2 Text 0 File Reader.cpp, Line 127
Reader running
10:08:06 PM #3 Text 0 File Writer.cpp, Line 122
Writer PIONEER DVD-RW DVR-216D running
10:08:06 PM #4 ISO9660GEN -11 File geniso.cpp, Line 3293
10:08:06 PM #5 Text 0 File Burncd.cpp, Line 3167
10:08:08 PM #6 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1485711 (330:09.36, 2901MB)
10:08:08 PM #7 Text 0 File DlgWaitCD.cpp, Line 272
10:08:08 PM #8 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: PIONEER DVD-RW DVR-216D, Media type: DVD-R
Disc Manufacturer: MCC 02 - RG20
10:08:08 PM #9 Text 0 File DlgWaitCD.cpp, Line 438
10:08:08 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_DATA_MODE1 ()
original disc pos #0 + 1485712 (1485712) = #1485712/330:9.37
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1485712 blocks [PIONEER DVD-RW DVR-216D]
10:08:08 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [PIONEER DVD-RW DVR-216D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3042738176, ISRC ""
DAO layout:
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1485712 | lead-out | 1 | 0x41 | 0x00
10:08:08 PM #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
10:08:10 PM #13 Text 0 File Burncd.cpp, Line 4051
Cache writing successful.
10:08:10 PM #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
10:08:10 PM #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 8x (11,080 KB/s)
10:08:11 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2609
10:08:11 PM #17 Text 0 File DVDR.cpp, Line 2267
Recording mode: Sequential Recording Mode
10:08:11 PM #18 Text 0 File Mmc.cpp, Line 21469
Set BUFE: Buffer underrun protection -> ON
10:08:11 PM #19 Text 0 File DVDR.cpp, Line 2421
Start write address at LBA 0
10:08:11 PM #20 Text 0 File Cdrdrv.cpp, Line 8438
Book Type: DVD-R (2), Part Version: 5
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
10:09:49 PM #21 SCSI -1128 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 2, TA 3, LUN 0, buffer 0x0BEC0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x2A 0x00 0x00 0x00 0x03 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0xFF 0xFF 0x04 0x70 0x0E
0x00 0x00 0x00 0x00 0x11 0x05
10:09:49 PM #22 CDR -1128 File Writer.cpp, Line 311
Unrecoverable read error
10:09:49 PM #23 Text 0 File ThreadedTransfer.cpp, Line 228
10:09:49 PM #24 Text 0 File ThreadedTransfer.cpp, Line 222
10:09:49 PM #25 Text 0 File DVDR.cpp, Line 2658
EndDAO: Last written address was 767
10:09:49 PM #26 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 8x (11,080 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9200 bytes, created 8/20/2008 1:58:58 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/17/2002 9:05:10 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.83a, size=44944 bytes, created 8/20/2008 1:58:58 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\iaStor.sys': Ver=8.5.0.1032, size=324120 bytes, created 7/20/2008 1:44:44 PM (Adapter driver for rec)
Registry Keys:
"Sense Key: 0x03 (KEY_MEDIUM_ERROR)"
This line would suggest to me a DVD-R media error and maybe the last 3 in the stack were bad. Any ideas?
