"Ultra" 4x4x12 DVD+RW for $99 after rebate
Postby legalalien on Fri Aug 22, 2003 4:06 pm
http://www.tigerdirect.com/applications ... &CatId=482
I dunno anything about this drive, but the description sounds good:
Ultra's 4x4x12x DVD+RW features a Tilt Control technology, which automatically adjusts the angle of the write head to maintain burn quality. With available firmware upgrades, this burner will implement Mount Rainier technology, which simplifies and speeds up the burning process. A user-friendly software interface effectively eases the learning curve for newcomers to DVD burning, allowing users to quickly incorporate a new source of enjoyment into their lifestyles.
Note: This Product Ships in a White Box.
legalalien
Re: "Ultra" 4x4x12 DVD+RW for $99 after rebate
Postby dodecahedron on Fri Aug 22, 2003 5:39 pm
legalalien wrote:Ultra's 4x4x12x DVD+RW features a Tilt Control technology, which automatically adjusts the angle of the write head to maintain burn quality.
all DVD burners have this capability. it's not something special to this drive, it's part of the DVD technology.
and all DVD readers too, i believe.
Return to Hot Deals
