cfitz, thanks for the test! I didn't even notice it was adware :(
I think the exact definition is not more than 280 erroneus rows (containing at least one errored symbol or byte) in eight consecutive ECC blocks.
This is not exactly the same as not more than 280 PI errors in eight consecutive blocks, just as my previous post is trying to (badly) explain. There can be more than just one PI error per row, so 280+ errors can be less than 280 errored rows.
That is, a disc with 280+ errors in eight consecutive blocks may or may not within spec, but a disc with more than 280+ erroneus rows in eight consecutive blocks is by definition out of spec.
My understanding is from a Karr's reply that Mediatek chipset only reports errors per ecc block, not number of erroneus rows per ecc block.
It's a slight difference, and could be averaged with probability assuming random distribution of errors, but still, if we were to measure disc readability within a drive according to specs, it would be nice to have the correct measures and units.
Currently KProbe has only numbers on the vertical axis in C1/C2 and PI/PO measures. If I've understood correctly the C1/C2 measures C1 and C2 stage errors per 75 sectors while PI/PO is row and column errors per ECC block.
It appears that both Pioneer and LiteOn DVD drives cannot return exact C1/C2 and PI/PO information to calculate conformance to disc standards.
Just as we cannot calculate BLER and BERL limits from KProbe C1/C2 measurements, we can't calculate DVD disc error limits from KProbe PI/PO threads.
Of course, this is not to say the scans are not useful, of course they are, I'm just trying how accurate the reported numbers are for a parictular reader/media combination.
regards,
Halcyon
PS I found another utility, for-pay CD/DVD Inspector, that has some sort of "Disc Readability test":
http://www.cdrom-prod.com/cddvd_inspector_screens.html
Probably not nearly as useful as Kprobe, but perhaps works on a wider variety of drives (?)
