tool for checking the quality of a burner cd ?
Postby ZL1 on Wed Aug 20, 2003 9:28 am
Hi
guys Im looking for a tool that will show the quality of a burn
Ive heard of crc errors or something, im new to all this :)
could you advise me ?
Thank You
Dan
ZL1
Postby CDRecorder on Wed Aug 20, 2003 8:59 pm
KProbe is good for checking the quality of any CD if you have a Lite-On drive. I use KProbe with my Lite-On drives. What brand and model is your drive?
If you search here at CDRLabs, there is a large amount of information about KProbe.
Postby ZL1 on Wed Aug 20, 2003 9:00 pm
CDRecorder wrote:KProbe is good for checking the quality of any CD if you have a Lite-On drive. I use KProbe with my Lite-On drives. What brand and model is your drive?
Hi
I have a Plextor
by the way where can I get KProbe ?
Dan
ZL1
Postby CDRecorder on Wed Aug 20, 2003 10:08 pm
Well, you used to be able to get KProbe here, but it seems to have changed.
KProbe won't help much, though, because it works only with Lite-On drives.
Plextor does supply a utility with a similar functionality (I forget what it's called) with some Plextor drives; which Plextor do you have?
Postby ZL1 on Wed Aug 20, 2003 10:15 pm
CDRecorder wrote:Well, you used to be able to get KProbe here, but it seems to have changed.
Hi
its a 48x 24x 48x plex burner (not the dvd combo) Im not sure what model would that be
Dan
ZL1
Postby cfitz on Wed Aug 20, 2003 10:58 pm
Then your only real option for checking physical burn quality is CD Speed with its scan disc and CD quality tests. It comes with Nero, or you can get it here for free.
To verify that your files are not corrupted, you can try CDCheck, also free for personal use at home.
