Is there a problem if I uncheck NeroCheck from msconfig?
Postby hariskar on Mon Oct 06, 2003 8:15 am
Is there a problem if I uncheck NeroCheck from msconfig/Startup?
Can I stop it from auto-starting with windows from nero?
What exactly does it do?
hariskar
Postby CDRecorder on Mon Oct 06, 2003 11:24 am
I don't know what it does, but I'd be interested to find out, too!
Postby Pilgrim on Mon Oct 06, 2003 12:12 pm
nerocheck.exe = Associated with "Nero Burning Rom" CD writing software. Used to install/control Nero driver nerocd2k.sys. Required only if you use Win2K/XP and login without admin privileges.
Jeff
Pilgrim
Postby cfitz on Mon Oct 06, 2003 12:47 pm
Nerocheck.exe:
http://www.nero.com/en/631931396925072.html#2
BurnRights:
http://www.nero.com/us/631940824944968.html
You can disable Nerocheck.exe from running at startup and still run Nero if you want, but since Nerocheck can be helpful, unless you know it to be causing problems I would suggest just leaving it enabled.
Postby CDRecorder on Mon Oct 06, 2003 5:04 pm
Thanks, Jeff and Cfitz! :D
Postby cfitz on Mon Oct 06, 2003 5:05 pm
You're welcome.
NeroCheck.exe using system resources?
Postby XIII on Tue Oct 07, 2003 5:00 pm
cfitz wrote:Nerocheck.exe: http://www.nero.com/en/631931396925072.html#2
Does it use any system resources?
I guess so if it periodically checks for drivers.
That might be a reason to disable it.
XIII
Postby TCAS on Thu Oct 09, 2003 1:12 am
I have unchecked this fuction since the installation of Nero 6.0.019 and nothing has been happening. Nero fuction normally and I have burnt quite few CDs with no problem anticipated.
Postby dodecahedron on Fri Oct 10, 2003 3:33 pm
Pilgrim wrote:nerocheck.exe = Associated with "Nero Burning Rom" CD writing software. Used to install/control Nero driver nerocd2k.sys. Required only if you use Win2K/XP and login without admin privileges.
here's the source for this info:
http://www.pacs-portal.co.uk/startup_pa ... rtup_n.php (search for NeroCheck).
the home page of that site:
http://www.pacs-portal.co.uk/startup_content.htm
a very useful website!
Postby dodecahedron on Fri Oct 10, 2003 3:36 pm
TCAS wrote:I have unchecked this fuction since the installation of Nero 6.0.019 and nothing has been happening. Nero fuction normally and I have burnt quite few CDs with no problem anticipated.
same here for Nero 5.5
however, in view of the FAQ cfitz linked to, i think i'll re-enable it.
i wonder exactly how it finds drivers that conflict with Nero - does it have a list of 'bad' drivers?
Postby Howard Kaikow on Sat Oct 11, 2003 1:04 am
BurnRights:
Does Nero below that the following is causing a conflict?
I found this in the Nero log file.
If so, that's nonesense.
AIC78XX.SYS is a Win 2000 driver provided by Microsoft.
Existing drivers:
File 'Drivers\AIC78XX.SYS': Ver=v2.20b, size=56848 bytes, created 12/7/1999 12:00:00 (Adapter driver for src)
Registry Keys:
Also, earlier in the log file, in addition the following was listetd:
File 'Drivers\atapi.sys': Ver=5.00.2195.6699, size=86672 bytes, created 6/19/2003 15:05:04 (Adapter driver for rec)
However, the atapi.sys is no longer listed in the log file.
This is with Nero 5.5.10.42.
I do not believe that this is a list of conflicting drivers.
Howard Kaikow
Postby hariskar on Tue Oct 14, 2003 8:08 am
Thanks a lot for your help!
hariskar
Postby cfitz on Tue Oct 14, 2003 10:00 am
You're welcome.
Startup info
Postby XIII on Thu Oct 23, 2003 3:49 pm
dodecahedronthe wrote:home page of that site:
That's a great site. Thanx!
XIII
Postby dodecahedron on Thu Oct 23, 2003 5:22 pm
welcome! :D
yeah, terrific site, isn't it?
Postby mrk1283 on Sat Nov 15, 2003 8:40 pm
Ive never had nerocheck enabled even since nero 5, never had a single problem either, i guess if you're a single user then its not really needed and i only use nero, clonecd and alcohol 120%
mrk1283
Postby CCampbell on Mon Nov 17, 2003 12:52 pm
cfitz[/quote]
Existing drivers:
Registry Keys:
I do not believe that this is a list of conflicting drivers.[/quote]
Not all drivers listed cause problems in and of themselfs. In many cases we just list drivers that could be a problem for Nero or your system if they are old and in need of being updated. Just because they are listed does not mean they will cause problems with our software. We just want you to be aware of them and the fact that they may be old versions and in need of an upgrade to prevent system performance issues, which may be associated with Nero being the cause.
