temps for a 2.4ghz p4 800fsb
Postby kpassman on Wed Feb 04, 2004 3:32 am
sup guys. just got a newbie question. my p4 2.4 fluctuates from 35 idle to 57 degrees celsius while operating. is that normal? when should i get worried? thanks!
kpassman
Postby BurninMan921 on Wed Feb 04, 2004 12:39 pm
Nope. That's about normal. The full load temps a bit high, but nothing to be concerned about. Keep in mind if you have the heatsink/fan from Intel that has the termal pad (as opposed to one that uses thermal paste), it'll be a bit hotter.
I also have a P4C 2.4GHz, and it idles around 41C and hits about 55C under full load. Oh, and that's with the cpu running at 2.6GHz. My memory is junk and can't handle >2.6GHz, so it's upgrade time. Right now: 2.52GHz rock-solid. Better memory: ~3.0GHz or so. Cranking the speed from 2.4 up to 2.6Ghz didn't raise the temp even 1C under full load. Nice thing on mine: I've got an MSI mother board that has a little Windows program that monitors the temps, and lets me play with the FSB speed in real time. No rebooting to OC!
BurninMan921
Postby texascbx on Wed Feb 04, 2004 1:36 pm
Not too hot,just don't get into the 60s regularly or you need a new HSF. :P
P-4C 2.4 oc @ 3.1, Abit IS7e
Antec 430 PSU
Maxtor 300 Gig SATA 16MB
2x512 PC-3200 DDR Kingmax
Thermalright XP90, Audigy
Radeon 9800 PRO/Arctic Cooler
BenQ 1640/Liteon SHW-160P6S
texascbx
