TDK 4x DVD+R (Ricoh)
Memorex 8x DVD+R (Ricoh)
Verb 8x DVD+R (MMC)
The thing that caught my eye right away was the "spikes" about 1/3 of the way through. This is the same spot where the drive changes speeds.
dodecahedron wrote:weird.
but the fact that the spike appears in the same place in all 3 brands suggests that this is a drive/firmware issue and not a media issue. the drive has probelms making good burns at 8x.
i wonder, did you notice if it's a real 8x burn? the drive is probably does 8x at ZCLV. so does it really stay 8x all the way to the end?
BTW does this mean youv'e started working on a review of this drive?
Ian wrote:i wonder, did you notice if it's a real 8x burn? the drive is probably does 8x at ZCLV. so does it really stay 8x all the way to the end?
I haven't seen any slow downs at all with this drive. You select 8x and it writes at 8x.
Ian wrote:craptastic
dodecahedron wrote:if i'm not mistaken it switches from 6x to 8x earlier than the Plexor does. is it indeed faster (any noticeable difference)?
zebraX wrote:I used exactly the same KProbe settings and an LDW-811S in this test.
