Static electricity and CD-R
Postby iowa jazz on Wed Dec 17, 2003 1:29 pm
The subject pretty much summarizes the question. Does static electricity pose a risk to data on a CD-R? Can static cause temporary or permanent damage? Do precautions need to be taken to discharge static electricity before handling CDRs?
Thanks!
Iowa Jazz
System Specs:
ASUS A7V8X-X / KT400
Athlon XP Thoroughbred 2600+ / 512MB PC3200 DDR
Maya 44 audio
Radeon 9200 128MB
Lite-On LTR-52327S
Lite-On LTC-48161H
LG GCC-4480B
Plextor PX-Premium (52/32/52)
Plextor PX-W1210A
iowa jazz
Postby cfitz on Wed Dec 17, 2003 3:08 pm
No, static electricity does not pose any danger to CD-R that I know of. There aren't any delicate MOS capacitors to destroy as in electronics devices. With CD-R you should be careful to avoid exposure to sunlight, temperature extremes, excessive humidity and dust and dirt. You may wisth to take a look at NIST (National Institute of Standards and Technology) Special Publication 500-252 "Care and Handling for the Preservation of CDs and DVDs - A Guide for Librarians and Archivists".
Postby CameraMan on Tue Dec 23, 2003 4:00 pm
I would counter that thought. I think static electricity CAN damage a disc.
Just HOW much is debatable. The metal layer in the disc can conduct electricity. Anything that conducts can be damaged.
Imagine a small wire driving a huge load. The wire will get hot, and give out. I'm not suggesting you use a CD-R in your fuse panel, but the high voltage you find in static electricity can burn pits in the disc. It can jump from bits to bits.
I guess the only way to be sure is to burn a disc, do a 100% error check on it, then zap it, and error check it again.
An audio disc is no big deal, but a data disc could become a coaster.
-John
Winnipeg, Manitoba, Canada - Slurpee Capital of the world!
BenQ DW400A, LG 24x, 48x & 52x
CameraMan
Postby dodecahedron on Tue Dec 23, 2003 5:17 pm
well, if you put it this way...
lightning is an effect of static electricity buildup (the discharge, actually), yeah so static electricity can damage CDs, CDRW drives, houses, cars, people etc. etc.
i think the question in this topic was what kind of damage can be cause by "normal household" static electricity, like you would accumulate by walking on a carpet. while this can be enough to fry CMOS chips, it's probably harmless as far as frying CDs go.
