speed
speed
Postby salvie00 on Sun Sep 07, 2003 3:13 pm
hey everyone just wondering if anyone can suggest what speed to use for burning cds to avoid skips when listening to cd. Im using the LT52327s with the fuji media (48). Also i wanted to mention that I have an HP pavilion with amd k6-2 /333 mhz. 256mb ram 80gig HD. I was thinking of using 24x as the speed for writing is that too slow? LT is cable of 52x but im not sure if my system can handle that or if that even matters. thanks guys. :)
salvie00
Postby dhc014 on Sun Sep 07, 2003 3:16 pm
16x is a good choice for burning audio CD's.
dhc014
Postby aviationwiz on Sun Sep 07, 2003 3:55 pm
I like to use 32x or below for audio cd's.
Postby CDRecorder on Sun Sep 07, 2003 4:52 pm
I burn all of my CDs as fast as the burner allows (if the quality is good); I've never found that to be a problem.
Postby rdgrimes on Sun Sep 07, 2003 5:11 pm
Given the 7S drive and TY media, there's no reason not to burn at 40x to 48x. Even 52x should produce very good quality audio discs, (better than manufactured discs). If a disc skips in a player, the problem is more likely to be due to the media/player combination rather than the burn speed. Burning slower than 24x will likely produce lower quality, not higher.
rdgrimes
Postby dolphinius_rex on Sun Sep 07, 2003 11:12 pm
16x is usually safe for most media, although *SOME* media require much faster or slower speeds. But generally I use 16x if I'm uncertain about how the media will react, since most of my reviews have shown 16x to be a sort of "happy medium" :D
Postby MediumRare on Mon Sep 08, 2003 12:53 am
dolphinius_rex wrote:16x to be a sort of "happy medium" :D
Ouch !!! (or was that pun unintentional?)
Postby dolphinius_rex on Mon Sep 08, 2003 4:34 am
I caught the pun as I was writing it, but decided to leave it in... so you could say it was half intentional :wink:
