CD Speed 4.70 Available - New BenQ and Lite-On Tests
Postby Ian on Fri Oct 27, 2006 7:40 pm
If you have a BenQ or newer Lite-On drive, you might want to give it a try.
http://www.cdspeed2000.com/files/NeroCDSpeed_4700.zip
Code: Select all
Changes
Added Advanced Disc Quality test for certain BenQ drives
Following parameters are measured:
CD: E11,E21,E31,E12,E22,E32,BLER,Jitter
DVD: 1-5 PIE,PIE,PIF,POE,POF,Jitter
Disc Quality test:
  Jitter can be reported with recent LiteOn drives
  Added CLV and P-CAV settings for BenQ drives (CD scanning)
  Added Advanced options button
Replaced 'Write and Verify' option by 'Streaming' option
Bitsetting: improved support for NEC drives
Small improvements and bug fixes
Postby Ian on Fri Oct 27, 2006 8:20 pm
Lots of new information to debate over. :P
Postby MediumRare on Sat Oct 28, 2006 1:30 am
I'll have to try this out- lots of new stuff!
According to this post, Erik's also cleared up the reason for the useless CD scans with LiteOn DVD burners: they report just part of the errors (E31) instead of BLER (E11 + E21 + E31).
Postby Ian on Sat Nov 04, 2006 10:14 am
This is annoying. Why is the graph scaling to 50GB and not 25GB like with previous versions?
CD Speed 4.70 BD-R Graph.png (15.49 KiB) Viewed 1719 times
