sound trax question
sound trax question
Postby stretch on Sun Sep 14, 2003 3:49 pm
Have just used sound trax for the first time to convert an old tape to CD. The copy is fine, but I'm left with a CD with one track 59 minutes long, and I am unable to skip to the different tracks on it, except by fast search.
Has anyone got any experience with this piece of software?
Regards Stretch
stretch
Postby CDRecorder on Sun Sep 14, 2003 4:19 pm
I don't know how this particular piece of software works, but I know that some programs that are made to convert tapes to CDs have a function that can split up that long single track into individual tracks by looking for periods of silence. I would suggest looking for a feature like that.
In Roxio SpinDoctor (included with ECDC 5 Platinum), there is a similar feature, but it didn't work well in my test with an old tape; it created far too many tracks. I just started and stopped the tape and the recording manually to create separate tracks for separate songs.
Postby Justin42 on Sun Sep 14, 2003 6:42 pm
Go to http://www.cdwave.com -- awesome program to split a long WAV file into tracks. Won't do it manually, though.... but it's really easy to use.
Postby MediumRare on Mon Sep 15, 2003 3:39 pm
Try Feurio, also available from Ahead's site.
