sound forge
sound forge
Postby coonsanders on Thu Apr 17, 2008 9:57 am
hi gang
that r the reviews 4 sound forge?is it a good software?better than nero??
thanks
coonsanders
coonsanders
Postby redk9258 on Thu Apr 17, 2008 6:45 pm
Sound Forge is expensive professional level software that is very good at what it is designed to do - edit audio. I think it is sometimes bundled with CD Architect - Again, very good professional level software that is good at what is is designed to do - master audio CDs. Nero, on the other hand is not professional software and it trys to do all things. It is OK at most, but for editing audio files / mastering CDs SF / CD Architect are much better.
You may want to check out Sony Forge Audio, it is a stripped down version of Sound Forge. I have seen the for free after rebate.
redk9258
