Sony DW-U12A OEM of Sony DRU-510A ?
Postby Spawn182 on Fri Jun 20, 2003 7:28 pm
Hi,
maybe someone can confirm, if the Sony DW-U12A is the OEM version of the DRU-510A. According to "The Firmware Page" it is an OEM version of the 500A.
Here in Germany the hardware dealers advertise the U12A as the OEM version of the 510A. An inquiry at Sony remained unanswered.
Since the DW-U12A sells for 285 Euro (330 US$) and the DRU-510A sells for 330 Euro (382 US$), I really want to know what I am buying.
Spawn182
Postby Telstar on Fri Jun 20, 2003 11:44 pm
According to the following link:
http://www.esbuy.com/sonydwu12a.html
It is indeed the OEM version of the DRU-510A, and I think the DW-U10A is the OEM of the DRU-500A. These OEM versions don't have the silver front plate but the plain beige one.
Telstar
Postby jsl on Sat Jun 21, 2003 5:19 am
DW-U10A = OEM of DRU-500A
DW-U12A = OEM of DRU-500AX
DW-U14A = OEM of DRU-510A
jsl
Postby Spawn182 on Sat Jun 21, 2003 8:16 am
Thanks a lot, but it is still confusing!
What is the difference between the 500A and the 500AX? Should I wait for the U14A, take the U12A or go for the more expensive 510A?
Spawn182
Postby Telstar on Sat Jun 21, 2003 10:46 am
After further research, I think jsl's post is correct. Never trust those online retailers too much. If I'm not mistaken, the DRU-500AX has a newer version of firmware (writes +R at 4X instead of 2.4X) and the same hardware as the DRU-500A. The DRU-510A has a different hardware and can write +RW at 4X instead of 2.4X.
There is no tech support and firmware upgrade for Sony's OEM drives. If you don't care about them and the included software, then the OEM version can save some money. Otherwise consider the retail version or get an NEC ND-1300A burner which is cheaper and also very popular.
Telstar
Postby Kennyshin on Sat Jun 21, 2003 1:19 pm
jsl wrote:DW-U10A = OEM of DRU-500A
And...
DRU-500A => DW-U10A => DVM-4222FB / DVM-4222iU2
DRU-500AX => DW-U12A => DVM-4242FB / DVM-4242iU2
DRU-510A => DW-U14A => DVM-4244FB / DVM-4244iU2
DVM-4244FB (Melcoinc retail) costs US$240 in Tokyo.
Kennyshin
