Check it out...
http://sony.storagesupport.com/dvdrw/drx500uldwn.htm
chon_wang wrote:weird. when i clicked on the updater, it gave me a sendcom.dll error. does anyone have this problem?
What improvements will the 1.0e firmware upgrade give my DRU500A or DRX500L?
This new firmware will allow your Dual RW drive to record at 4X on 4X compatible DVD+R media, as well as improve the DVD-ROM reading performance with DVD recordable/rewritable media.
What DVD Media will work best with my DRU500A or my DRX500UL?
Please click here for a list of recommended media.
Why am I unable to view my burned DVD in my DVD/RW drive?
You will not be able to view a region free disc(DVD's you record yourself are region free), until a region code has been set by viewing a manufactured DVD disc that has a region code setting. Please download and review the Region code notice.
Click here for the Region Code Notice.
gurgenpb wrote:Can't install teh new firmware (1.0f from teh USA site)!!! The first time i start it, it starts and says that to upgrade, you must restart computer. So i do that and start the firmware updater again, and after pressing START UPDATE, nothing happens!!!!!
Help guys. Give us your feedback.
Gurgen
gurgenpb wrote:Thanks seezar.
Now that I did turn off the DMA (forgot to do it at first - but I did unistall all the packetwriting software that I had), it worked. Burning a movie at 4x ont he new ritek 4x media (DVD-r, in jewelcase, purchased from meritline.com for $3.09 each).
Will let you guys kwno if any problems. This drive is awesome. My first 4x burn is finishing up as I am typing this. Great to have a disk in 15minutes!!!
Gurgen
gurgenpb wrote:Which crappy 1x's are these? Princo? Ritek?
| All Content is Copyright (c) 2001-2026 CDRLabs Inc. |
