sony dru500a and nero
Postby dogdivine on Fri Nov 29, 2002 12:37 pm
Hi,
does anyone know how can't I see the sony dru 500a in nero....
I have a LG 40x12x40 and a Sony dru500a in my PC but when I go to select a recorder in Nero just give the LG how can't I put both?
DogDivine®
just for fun !!!!!!!!!!!!!!!!
dogdivine
Postby sonyman on Fri Nov 29, 2002 1:31 pm
Did nero come with your LG burner? If so, it is probably an OEM version locked specifically to the drive it came with. You can purchase an upgrade to the full version of nero at http://www.nero.com for $20.
-Scott
Gigabyte GA-8KNXP
Intel Pentium 4 3GHz
1024MB PC3700 DDR @400MHz CL2
ATI Radeon 9700 Pro
Sony DRU-500A
Lite-On LTR-52327S 52x32x52
sonyman
sony
Postby dogdivine on Fri Nov 29, 2002 1:58 pm
sory but I have the full version
and I can't see the sony in list of recorders just the LG and the HD...
Have you any idea?
tks
DogDivine®
dogdivine
Postby CCampbell on Mon Dec 09, 2002 6:59 pm
Are you sure you have our latest Nero 5.5.9.17 installed? I have this drive in our lab and it's working fine with an LG and the Sony DVD Recorder on the same system.
I assume you can read data CD's from this drive, or play an audio CD?
And check the drives jumpers, to make sure you do not have a master/Slave conflcit.
Postby CCampbell on Mon Dec 09, 2002 7:02 pm
