Sony DRU500 & Media that does not work !
Postby SonyUser on Wed Nov 20, 2002 8:54 pm
Hi All,
I got this drive today and so far I am pleased with it, works a treat, but.....
Media
DVD-R VIVASTAR 4.7
Manufacturer ID: VIVASTAR
Physical Format Information:
Book Type: DVD-R
Part Version: 5
Disc Size: 120mm
Maximum Read Rate: Not Specified
Number of Layers: 1
Track Path: Parallel Track Path (PTP)
Linear Density: 0.267 um/bit
Track Density: 0.74 um/track
This media fails in my drive at about 20% - 45% of the burn.
The media is rated as 1x - 2x.
There is no part number on the disc or the case.
The drive came with 1.0c firmware, I up-dated it with 1.0d before I did a burn to any media, so this was the 1st real test with the drive.
I have also tested the drive with Mirror DVD+R media, here the drive worked without any problems.
Now, does anyone have a list of media that DOES NOT WORK with the Sony DRU500a, as this would be good for those that are looking at buying media, could even make this a dual (no pun intended) list of yes it works, no it don't (DVD-R / +R).
I have seen the list of media thats been reported to work here in this forum, but it does not help those that can not get this media (I live in the UK).
Any help here would be good.
TIA.
SonyUser
Update - Tried to burn to this VivaStar DVD-R with Nero 5.5
Postby SonyUser on Thu Nov 21, 2002 6:48 am
I did a second test in the Sony DRU500a using Nero this time with the VivaStar DVD-R media.... it failed again, snips from the log enclosed (oi Sony, this needs to be fixed ASAP in the new firmware thats due in December !!).
Stay away from this media from VivaStar (www.vivastar.com / www.vivastar.ch) as it fails to work in the Sony DRU500a.
Nero Version: 5.5.9.17
Recorder: <SONY DVD RW DRU-500A> Version: 1.0d - HA 1 TA 0 - 5.5.9.17
Adapter driver: <atapi> HA 1
Drive buffer : 8192kB
CD-ROM: <SONY DVD RW DRU-500A>Version: 1.0d - HA 1 TA 0 - 5.5.9.17
=== Scsi-Device-Map ===
CdRomPeripheral : SONY DVD RW DRU-500A atapi Port 1 ID 0 DMA: On
09:19:07 #13 Text 0 File Cdrdrv.cpp, Line 7293
Book Type: DVD-R (2), Part Version: 5
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
09:19:10 #14 Text 0 File Writer.cpp, Line 317
09:19:10.132 - SONY DVD RW DRU-500A : Queue again later (Intervall : 47msec)
09:20:28 #15 Text 0 File Writer.cpp, Line 317
09:20:28.324 - SONY DVD RW DRU-500A : Queue again later (Intervall : 47msec)
09:20:29 #16 Text 0 File Writer.cpp, Line 317
09:20:29.235 - SONY DVD RW DRU-500A : Queue again later (Intervall : 47msec)
09:20:29 #17 Text 0 File Writer.cpp, Line 317
09:20:29.295 - SONY DVD RW DRU-500A : Queue again later (Intervall : 47msec)
09:20:29 #18 Text 0 File Writer.cpp, Line 317
09:20:29.366 - SONY DVD RW DRU-500A : Queue again later (Intervall : 47msec)
09:20:29 #19 Text 0 File Writer.cpp, Line 317
09:20:29.426 - SONY DVD RW DRU-500A : Queue again later (Intervall : 47msec)
09:20:29 #20 Text 0 File Writer.cpp, Line 317
09:20:29.486 - SONY DVD RW DRU-500A : Queue again later (Intervall : 47msec)
09:22:57 #21 Text 0 File Writer.cpp, Line 317
09:22:57.589 - SONY DVD RW DRU-500A : Queue again later (Intervall : 47msec)
09:25:26 #22 Text 0 File Writer.cpp, Line 317
09:25:26.783 - SONY DVD RW DRU-500A : Queue again later (Intervall : 47msec)
09:27:55 #23 Text 0 File Writer.cpp, Line 317
09:27:55.988 - SONY DVD RW DRU-500A : Queue again later (Intervall : 47msec)
09:30:25 #24 Text 0 File Writer.cpp, Line 317
09:30:25.222 - SONY DVD RW DRU-500A : Queue again later (Intervall : 47msec)
09:32:54 #25 Text 0 File Writer.cpp, Line 317
09:32:54.387 - SONY DVD RW DRU-500A : Queue again later (Intervall : 47msec)
09:33:41 #26 SCSI -1135 File Cdrdrv.cpp, Line 1388
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02450000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x0C
Sense Qual: 0x08
CDB Data: 0x2A 0x00 0x00 0x08 0x24 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF1 0x00 0x03 0x00 0x08 0x1C 0x00 0x12
0x00 0x00 0x00 0x00 0x0C 0x08
09:33:41 #27 DVDR -1135 File Writer.cpp, Line 334
Write error
SonyUser
Postby seezar on Thu Nov 21, 2002 1:25 pm
See this thread regarding media for the drive:
http://www.cdrlabs.com/phpBB/viewtopic.php?t=7325
seezar
Postby Stereodude on Thu Nov 21, 2002 2:30 pm
Sounds like my experience with Khypermedia 1x discs. They will even fail with a media error during a simulation.
Stereodude
Stereodude
