Sony CRX195E1 issues
Postby eRad on Mon Nov 25, 2002 12:38 am
I just bought this model, its a 40x burner OEM. I found that it can only burn at up to 24x, regardless of the software. Unfortunately i wasn't able to return it in time but the tech support at the place said others had the same problem regardless of what burning software they used. I suspect it has to do with the firmware... I know at the moment there is no updated firmware available for this model, but can anyone either
a) suggest a possible remedy to the problem
or
b) give me a link to the site where i would be able to get this firmware in the future, as the sony site seems to have nothing really (or i can't find it at least)
thanks for any help
eRad
Postby dhc014 on Mon Nov 25, 2002 12:42 am
If you ever need ZYS2, ZYS3, or ZYS5 they're here:
http://kickme.to/sony195
dhc014
Postby cfitz on Mon Nov 25, 2002 12:44 am
Is DMA enabled? Check the FAQ section: http://www.cdrlabs.com/phpBB/viewtopic.php?t=7625
Postby dodecahedron on Mon Nov 25, 2002 2:16 am
way to go, cfitz!
this is (to my knowledge) the first usage of the new FAQ! :P
Postby cfitz on Mon Nov 25, 2002 11:23 am
dodecahedron wrote:way to go, cfitz!
It is my honor. :D
