The Sony CRX was OEM and my first job was to transfer some MP3s and other data files that I had written on my old PC using Adaptec Direct CD, which had been bundled with my old Sony CD Writer on the previous PC.
Problem is the new CD writer could not recognise the disc, nor others I had recently made. It did recognise some much older CDRs I tried.
I had done the job properly, so it was not the case that they had not been finished and closed.
I went out and bought a couple of Maxell XL-11s, which the guy in the shop said were up to the job and put one of them into the drive to try to write to it....no recognition. There seems to be an intermittent problem.
Has anyone any solution to this problem as I am having no joy with the techies at Evesham.
Please help..I am getting desperate. I am sure you will have gathered I am not particularly technical...I just try!
