Sony and Maxell cd-r @ Staples for $2.94 AMIR
Postby xeetim on Fri Mar 14, 2003 5:13 am
Any info on who makes Sony and Maxell CD-R?
xeetim
Postby cfitz on Fri Mar 14, 2003 10:41 am
In these days, usually Sony and Ritek, respectively. In the past you could also find Sony discs made by Taiyo Yuden and Maxell discs made by Hitachi-Maxell.
Postby xeetim on Fri Mar 14, 2003 1:11 pm
Is Ritek any good? I refuse to buy anymore CMC crap!
xeetim
Postby cfitz on Fri Mar 14, 2003 1:53 pm
What's your drive? I've had good success with Ritek media, both TDK and Maxell branded, in my LiteOn LTR-48246S and Yamaha CRW-3200EZ. In my drives Ritek isn't as good as Taiyo Yuden and Verbatim DataLifePlus, but it's still quite decent. Also, the TDK branded Ritek seemed to be a little better than the Maxell branded version.
Have you checked the media compatibility thread:
http://www.cdrlabs.com/phpBB/viewtopic. ... 05&start=0
Postby xeetim on Fri Mar 14, 2003 4:33 pm
I also have a LiteOn LTR- 48246S, FW SS0B. If you say they're good then I guess I'll be buying the Sony or Maxell CD-R then.
xeetim
Postby cfitz on Fri Mar 14, 2003 4:41 pm
My experience with Sony media is very limited, just a couple of discs from a trade with a buddy. I wasn't too pleased with them because the reflective layer began corroding around the edges within a month of burning them and handling them. I don't know if that was just one batch or indicative of a general quality control problem with Sony.
By the way, do you have a link for those $2.94 specials? The only deal I see at my local Staples is $7.94 for 100 74-minute Maxell discs:
http://www.cdrlabs.com/phpBB/viewtopic.php?t=9710
Postby Inertia on Sat Mar 15, 2003 1:36 am
cfitz, here's the link to SONY OR MAXELL 50/PACK RECORDABLE CD-R for $2.94 after rebates.
This is an in-store special only good from March 16-29.
Inertia
Postby cfitz on Sat Mar 15, 2003 1:58 am
Thanks Inertia. When I looked earlier on staples.com I couldn't find it. Either I wasn't looking hard enough or it hadn't been posted for my area yet.
Return to Hot Deals
