Sony 16X DVD Rom - no Audio in XP ???
How fast is too fast?
Postby DavidI on Sat Dec 27, 2003 12:23 am
Help !!
I was just given this unit from my brothers machine.
It is a Sony 16x DVD Rom model 1621 - it is manufactured in January 2002, so it is relatively "old".
It is running the 1.6 firmware.
I run WinXP Pro.
DVD video is perfect - I use Power DVD 5
***BUT***
I have no audio - it appears NOT to be transmitting the audio through the IDE cable [ as XP is supposed to do - and does - with my other, newer Sony 52X CD Rom ]
=> Can any please help / advise ?
=> Is it a firmware glitch OR does the 1621 simply not transmit its audio via the IDE cable.
Many thx,
Dave
DavidI
Postby dodecahedron on Sat Dec 27, 2003 4:59 am
go to the Device Manager, find your DVD-ROM, double click, in the Properties tab make sure you have Enable digital CD audio for the CD-ROM device checked.
Postby DavidI on Sun Dec 28, 2003 6:31 am
Hi dodecahedron
Many thanks - you solved my problem.
Dave
DavidI
Postby dodecahedron on Sun Dec 28, 2003 11:00 am
welcome, glad to have been of help :)
