software to compress, preserving as much quality as possible
Postby faithfoo on Mon Jun 09, 2003 2:14 pm
HI
Pardon my ignorance
1) What is the software that will allow me to compreress DVD ( 4.7 Gb ) into CDRW ( 1 or 2 CDRW is fine) ..any freewares that is as good
2) I am aware that quality will be lost, what is the software that can hopefully retain as much quality as well as have less conversion /writing errors
I am using roxio to burn CDRW at the moment.
faithfoo
Postby Han on Mon Jun 09, 2003 2:51 pm
What would you like to compress?
Han
CD-RW PiMP
Postby Inertia on Mon Jun 09, 2003 5:55 pm
DivX is probably the most commonly used codec for high resolution copies from DVD to CD-R. XviD and others provide excellent results, but for a beginner DivX is probably the safest bet.
If you go to Doom9, there is a wealth of information regarding high quality transfer of DVD's to compressed files on CD-R.
I use the program called Gordian Knot for this purpose, and highly recommend it. It is available at Doom9 along with all of the freeware necessary to make high quality copies.
Inertia
Postby Han on Tue Jun 10, 2003 2:33 pm
Gordian Knot site, where the latest versions are published... 8)
Han
CD-RW PiMP
can you point me to the link
Postby faithfoo on Mon Jun 30, 2003 3:49 pm
Han wrote:Gordian Knot site, where the latest versions are published... 8)
I am not sure which gordion Knot to download
I belive after the exe file..
I just have to cut and paste the DVD files ( VOB files )
into the CDRW and that's it ..
faithfoo
