New to the forum, so firstly hello!
Could you help me with a small problem that I have been getting. I wanted to make backups of some MP3 files, so I went out and purchased a Philips DVDR1660P1 (Firmware 1.6, latest) DVD writer drive and I am also running Nero 6.6.1.4 (as part of the Nero 6 Suite) - I'm using Logik Dvd+R discs as well as Sony Dvd-R discs.
Firstly I should say the drive seems to be able to read normal DVD's without any problem, and is very responsive. However when I put in one of the blank DVD's for writing, Nero reports "No Disc Inserted or drive not ready, please try again", and also it reports no disc present in My Computer.
Now the really weird thing is, every now and again when I put in it does work (less than 10% of the time), but when I try to record a disc even at low write speeds like 2x and 4x, it gives me a "session fixation error" - although I have managed one sucess out of probably two dozen attempts.
I have enclosed the Nero log in case it helps.
I would appreciate any suggestions on how to solve the problem as its driving me around the bend at the moment! :doh: All the best.
- Code: Select all
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32
NT-SPTI used
Nero Version: 6.6.1.4
Internal Version: 6, 6, 1, 4d
Recorder: <PHILIPS DVDR1660P1> Version: P1.6 - HA 1 TA 0 - 6.6.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
CD-ROM: <PHILIPS DVDR1660P1 >Version: P1.6 - HA 1 TA 0 - 6.6.1.4
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD600AB-77BVA0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST3802110A atapi Port 0 ID 1 DMA: On
CdRomPeripheral : PHILIPS DVDR1660P1 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST CD-RW GCE-8160B atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
PHILIPS DVDR1660P1 D: CDRom0
HL-DT-ST CD-RW GCE-8160B E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (83886080) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1047992kB)
Free physical memory: 189MB (194432kB)
Memory in use : 81 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
6.1.2007
ISO compilation
22:45:05 #1 Text 0 File Isodoc.cpp, Line 6475
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
Write ISO9660 ;1 file extensions : FALSE
22:45:05 #2 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 81920KB of Memory
22:45:05 #3 Text 0 File Reader.cpp, Line 124
Reader running
22:45:05 #4 Text 0 File Writer.cpp, Line 122
Writer PHILIPS DVDR1660P1 running
22:45:05 #5 ISO9660GEN -11 File geniso.cpp, Line 3312
22:45:05 #6 Text 0 File Burncd.cpp, Line 3305
22:45:05 #7 Text 0 File DlgWaitCD.cpp, Line 281
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2239887 (497:45.12, 4374MB)
22:45:05 #8 Text 0 File DlgWaitCD.cpp, Line 293
Write in overburning mode: NO
22:45:05 #9 Text 0 File DlgWaitCD.cpp, Line 2612
Recorder: PHILIPS DVDR1660P1, Media type: DVD+R
22:45:05 #10 Text 0 File DlgWaitCD.cpp, Line 459
22:45:05 #11 Text 0 File ThreadedTransferInterface.cpp, Line 847
0: TRM_DATA_MODE1 ()
original disc pos #0 + 2239888 (2239888) = #2239888/497:45.13
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2239888 blocks [PHILIPS DVDR1660P1]
22:45:05 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [PHILIPS DVDR1660P1] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4587290624, ISRC ""
DAO layout:
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2239888 | lead-out | 1 | 0x41 | 0x00
22:45:05 #13 Text 0 File SCSIPassThrough.cpp, Line 38
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
22:45:05 #14 Text 0 File SCSIPassThrough.cpp, Line 83
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
22:45:05 #15 Phase 24 File dlgbrnst.cpp, Line 1685
Caching of files started
22:45:05 #16 Text 0 File Burncd.cpp, Line 4145
Cache writing successful.
22:45:05 #17 Phase 25 File dlgbrnst.cpp, Line 1685
Caching of files completed
22:45:05 #18 Phase 36 File dlgbrnst.cpp, Line 1685
Burn process started at 2.4x (3,324 KB/s)
22:45:05 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2685
22:45:05 #20 SPTI -1066 File SCSIPassThrough.cpp, Line 289
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 00 00 00 00 00 00 00 08 04 00 00
Sense Area: 0x70 00 05 00 00 00 00 12 00 00 00 00 24
Buffer x04780600: Len x804
22:45:05 #21 Text 0 File DVDR.cpp, Line 6328
Drive: PHILIPS DVDR1660P1
Book Type request [gen]: DVD-ROM, write to EEPROM
Changing the Book Type was finished successfully, return code 0
22:45:05 #22 CDR -1207 File DVDR.cpp, Line 5463
Book Type automatically set to: DVD-ROM
22:45:05 #23 Text 0 File DVDPlusRW.cpp, Line 666
Start write address at LBA 0
22:45:11 #24 SPTI -1176 File SCSIPassThrough.cpp, Line 289
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1176)
Sense Code: 0x72
Sense Qual: 0x01
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 12 00 00 00 00 72 01
Buffer x04410000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
22:45:11 #25 CDR -1176 File Writer.cpp, Line 311
Session fixation error
D: PHILIPS DVDR1660P1
22:45:11 #26 Text 0 File ThreadedTransfer.cpp, Line 228
22:45:11 #27 Text 0 File ThreadedTransfer.cpp, Line 222
22:45:11 #28 Phase 127 File dlgbrnst.cpp, Line 1685
Generating DVD high compatibility borders
22:45:11 #29 Phase 129 File dlgbrnst.cpp, Line 1685
Generating DVD borders completed successfully
22:45:11 #30 Text 0 File DVDR.cpp, Line 6328
22:45:11 #31 Phase 38 File dlgbrnst.cpp, Line 1685
Burn process failed at 2.4x (3,324 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 05/12/2005 05:12:26 (Prassi/Veritas driver for win 2K)
File 'Drivers\InCDfs.SYS': Ver=4, 3, 23, 2, size=102016 bytes, created 23/03/2006 17:15:58 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=4, 3, 23, 2, size=29440 bytes, created 23/03/2006 17:15:56 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=4, 3, 23, 2, size=8704 bytes, created 23/03/2006 17:00:28 (InCD4 driver for win NT/2K/XP)
Registry Keys:
