Most of the time I would want 4x, but occasionally if I am burning a disc that I know will need to be read on a picky DVD player, I would rather burn slower to decrease errors. Any way to enable this?
diskdocx wrote:I have a SonyDRU 710A, and a bunch of 4 and 8x DVD media. Is there any way to select a slower burn speed? For example, when I put in a blank 4x DVD, there is no option to burn at any speed other than 4x (the box is greyed out at 4x). But the media should be able to be burned at 1, 2 or 4x?
diskdocx wrote:When you say unless limited to 1x or 2x, I assume you mean unless the burner being used cannot exceed these speeds (as was the case with my old Sony DRU500a)?
diskdocx wrote:So with 8x media, I should be able to choose either 4x or 8x (I will need to get more 8x media to verify this)?
diskdocx wrote:When the drive lists speeds for DVD-r from 1x-12x, that means it will burn old media which is 1 or 2x speed, but you're saying that for 4x media and up, the minimum speed on this burner is 4x, correct?
| All Content is Copyright (c) 2001-2026 CDRLabs Inc. |
