vixius wrote:1. Burnatonce Software.
No doubt it is a good software but it saves your CD in 2 files:
*.TOC/*.CUE.
I meant *.BIN/*.CUE
no, you must have misunderstood the help file.
you have 2 options for reading a disc image with burnatonce.
one is *.toc/*.dat
second is *.cue/*.bin (only data CDs though).
when choosing Read to Image, when presented with the Save As dialog, you are given two types to save as: Cdrdao Image File (*.toc); Cue Sheet (*.cue).
just finished reading a 535MB data disc to *.cue/*.bin files.
here's the output:
- Code: Select all
SPTI:1,1,0: PLEXTOR CD-R PX-W2410A Rev: 1.04
Reading toc and track data...
Track Mode Flags Start Length
1 DATA 4 00:00:00( 0) 60:53:34(274009)
Leadout DATA 4 60:53:34(274009)
PQ sub-channel reading (data track) is supported, data format is HEX.
Raw P-W sub-channel reading (data track) is supported.
Cooked R-W sub-channel reading (data track) is supported.
Copying data track 1 (MODE1): start 00:00:00, length 60:53:34 to "D:/Temp/a.bin"...
Reading of toc and track data finished successfully.
Copied toc file to cue file format - please use for data only.
created 2 files: D:\Temp\a.bin, D:\Temp\a.cue .
also read same disc to *.toc/*.dat format, created 2 files: D:\Temp\a.dat, D:\Temp\a.toc .
log was identical to above except for the last line (obviously not there).
(incidentally the .cue file is empty
. is this as it should be? i think not, something is amiss. burnatonce will not load this bin/cue image. i know nothing of bin/cue files
give it a try!
