Recomendations for software making DVD copies and data discs
Postby otak on Sun Apr 22, 2007 5:54 am
Hi , I am usnig LG H22N and would like to save some of my data and discs .
i have read reviews as Roxio being one of the best and DVD - cloner IV as very good for coping . What do you think ?
I am using DeepBurner as a cheap alternative at a moment .
I have Alcohol-120 but cant use it to make my own DVD or CD data or other type , not just coping .
Also some good DVD-ram to recomend not the fastets
( because of the price ) preferable good for saving data longer ? ( uk or europe )
Thanks , using your forums gave me the choice of DVD that I am using and very useful other information :-)
otak
Postby SithTracy on Sun Apr 22, 2007 8:47 am
ImgBurn is both free and outstanding... Only thing you can't do with that is audio discs, but I think DeepBurner probably has you covered there (probably with some limitations)... not sure, I don't use it.
