Processor speed question
Postby peterd on Mon Aug 13, 2007 6:12 am
Hello
I've been upgrading a desktop PC and have been fitting a few new components including a DVD writer.
The system is an ex corporate Compaq Evo with a pentium 4 1.7Ghz processor.
The DVD writer is a Lite-On LH-20. On the box it says minimum processor spec P4 1.8Ghz. Is this going to be a problem if I fit it in this system with a slightly slower clock speed processor?
cheers
Pete
peterd
Postby SithTracy on Mon Aug 13, 2007 7:27 am
I wouldn't burn faster than 8x with that system and don't multi-task during a burn... it will probably be fine.
Postby peterd on Mon Aug 13, 2007 7:53 am
Thanks for the reply.
On a similar system with a LG 16 speed burner, I noticed that the write speed was very erratic when set to maximum.
Although the discs wrote OK different coloured bands could be seen on the disc surface.
peterd
Postby Wesociety on Mon Aug 13, 2007 12:09 pm
I've burned many DVDR's at 16x on a Compaq EVO running a 1.8 GHz processor with absolutely no issues at all...
Postby Ian on Mon Aug 13, 2007 12:58 pm
IMO, it has more to do with disc I/O than CPU speed. If your hard drive can spit the data out fast enough when writing at 16x, then go for it. As SithTracy pointed out, it probably wouldn't be a good idea to multitask though.
Postby Justin42 on Sat Aug 18, 2007 9:01 pm
A lot of time those specs have more to do with the bundled software and what is considered acceptable for that to run properly than the drive itself.
As long as you don't multitask much with burning and have a good 7200RPM hard drive in it you should be fine. If it's not running in tip-top shape you may have issues, though.
