i can't burn VCDs because this keeps occurring.. any1 kind enough to explain to me wat it is saying?
Windows 98 4.10
IA32
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 23/04/99 10:22:00 PM
ahead WinASPI: File 'C:\PROGRAM FILES\AHEAD\NERO\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 17/12/03 2:18:04 AM
Nero version: 6.3.0.2 (Nero Express)
Recorder: <TSSTcorp CD-R/RW TS-H292A>Version: TS02 - HA 0 TA 0 - 6.3.0.2
Adapter driver: <ESDI_506> HA 0
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <SONY CDU5211 >Version: YYS2 - HA 0 TA 1 - 6.3.0.2
TSSTcorp CD-R/RW TS-H292A (Target 0, E:): Autoinsert On, DMA Off, Disconnect ?, SyncDataXfer ?
SONY CDU5211 (Target 1, F:): Autoinsert On, DMA Off, Disconnect ?, SyncDataXfer ?
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 39845888 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 247MB (253396kB)
Free physical memory: 76MB (78112kB)
Memory in use : 56 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
11.5.2005
Video CD
12:02:00 AM #1 Text 0 File VCDDoc.cpp, Line 1433
VideoCD document burn settings
Compilation type : VCD
Menu : Disable
Picture in separate folder : TRUE
Folder name :PICTURES
Use CD-I : TRUE
CD-I configuration : CONTROLS=ALL
CURCOL=YELLOW
PSDCURCOL=RED
PSDCURSHAPE=ARROW
CENTRTRACK=2
AUTOPLAY=AUTO_ON
DUALCHAN=DUAL_ON
TIMECODE_X=64
TIMECODE_Y=100
LOTID_X=64
LOTID_Y=64
ALBUM=STANDARD
Encoding bitrate mode : User defined (kb/s)
12:02:00 AM #2 Phase 82 File dlgbrnst.cpp, Line 1800
Encoding video
12:02:00 AM #3 Text 0 File VCDCompilationImpl.cpp, Line 489
Using Nero Video Converter version 0.00
12:02:00 AM #4 Text 0 File AVIVCDFileItem.cpp, Line 873
Encoding D:\My Documents\My Videos\[SEED-Fansubs] Gundam SEED Destiny - 22.avi to C:\WINDOWS\TEMP\NER2002.TMP
ScalingType: 0 Video: yes Audio: no
File size: 245196800 bytes
Resolution: 640x480 23.9762 Hz
Frames: 34314
12:02:00 AM #5 Text 0 File AVIVCDFileItem.cpp, Line 886
Playing time: 1431.160000 s
Requested rate: 225 KB/s
iVideoRate=0
iAudioRate=32
Estimated size: 107337 blocks
12:08:00 AM #6 Text 0 File AVIVCDFileItem.cpp, Line 915
Encoding done
12:08:00 AM #7 WINPFILE 32 File CPortableWinPFile.cpp, Line 263
The process cannot access the file because
it is being used by another process.
12:08:00 AM #8 AVIVCDFILEITEM -105 File VCDFileItem.cpp, Line 932
Unknown error in the Video MPEG encoder
12:08:00 AM #9 Text 0 File AVIVCDFileItem.cpp, Line 979
Temporary file C:\WINDOWS\TEMP\NER2002.TMP deleted
12:08:00 AM #10 Text 0 File VCDDoc.cpp, Line 2680
VCD options:
Create standard compliant CD: YES
Encoding resolution: NTSC
