Problems with Nero 8 (8.1.1.4) and creating an image
Postby skypx on Tue Nov 27, 2007 1:30 pm
The latest version of Nero 8 uses ALL 4GB of ram whenever I create an image (using Vista 64). Anyone else experiencing this?
Gigabyte GA-X38T-DQ6|Intel QX9650|Corsair TWIN3X4096-1600C7DHX|EVGA 8800GTX|Plextor PX-760SA|Samsung 244T
skypx
Postby SithTracy on Tue Nov 27, 2007 8:22 pm
I don't use Nero 8 and I don't use Vista... Try ImgBurn... less headaches.
Postby skypx on Mon Dec 10, 2007 10:00 pm
If you are using Vista 64 and Nero 8, can you please help with the verification of this bug? I've been in contact with customer support and they are convinced the issue is not related to the latest version of Nero 8. Thank you in advance.
skypx
Postby skypx on Mon Dec 10, 2007 10:04 pm
Forgot to mention, the issue presents itself when I create an image of a DVD. Thanks.
skypx
Postby skypx on Mon Dec 17, 2007 8:45 am
Update..... Nero is aware of the problem. Below is part of an e-mail from tech support.
"thank you for your e-mail and please excuse the delay.
I talked to our developers and they were already able to reproduce the problem so please excuse my previous e-mail. The problem is not that Nero takes up to 4GB RAM but the Windows Vista cache Nero uses takes up to 4GB RAM.
The problem will be solved with one of our next Nero updates but unfortunately I'm not able to tell you with which version as this task is currently in work.
Should you have any further queries, please do not hesitate to contact us again."
skypx
Postby skypx on Wed Dec 19, 2007 7:11 pm
Update............. Version 8.2.8.0 does the same thing! Great job Nero!
skypx
Postby skypx on Wed Feb 20, 2008 12:24 am
Does anyone know if this issue is addressed in the next release? Thank you.
skypx
Postby skypx on Fri Feb 22, 2008 1:37 pm
skypx wrote:Does anyone know if this issue is addressed in the next release? Thank you.
I guess I'll just have to wait and see. :o
skypx
