Hi all,
I have problems with my NEW liteon ltr-52x24x52: it can't burn anything and every time nero says : "invalid block address", can anyone help me?
here I post the logs of nero while I tried to burn iso's images
(3 differents logs):
Windows XP 5.1
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 13.06.00
ahead WinASPI: File 'K:\Programmi\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 25/06/2002 10.34.54
Nero Version: 5.5.9.13
Recorder: <LITE-ON LTR-52246S> Version: 6S0D - HA 2 TA 0 - 5.5.9.13
Adapter driver: <atapi> HA 2
Drive buffer : 2048kB
CD-ROM: <LITE-ON LTR-52246S> Version: 6S0D - HA 2 TA 0 - 5.5.9.13
=== Scsi-Device-Map ===
CdRomPeripheral : ELBY DVD-ROM 1.0 ElbyVCD Port 0 ID 0 DMA: ?
DiskPeripheral : MAXTOR 6L040J2 atapi Port 1 ID 0 DMA: On
DiskPeripheral : WDC WD800JB-00CRA1 atapi Port 1 ID 1 DMA: On
CdRomPeripheral : LITE-ON LTR-52246S atapi Port 2 ID 0 DMA: On
CdRomPeripheral : ATAPI CD-ROM DRIVE atapi Port 2 ID 1 DMA: Off
AutoRun : 0
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 137MB (140700kB)
Memory in use : 73 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: Off
21.4.2003
CD-Immagine
10.42.56 #1 Phase 90 File dlgbrnst.cpp, Line 1571
10.42.56 #2 Text 0 File Reader.cpp, Line 118
Reader running
10.42.56 #3 Text 0 File Writer.cpp, Line 134
Writer LITE-ON LTR-52246S running
10.42.56 #4 Text 0 File Burncd.cpp, Line 3568
Turn on Track-At-Once, using CD-R/RW media
10.42.56 #5 Text 0 File ThreadedTransferInterface.cpp, Line 666
0: TRM_DATA_MODE1 (Joliet)
original CD pos #0 + 326656 (326656) = #326656/72:35.31
relocatable, CD pos for caching/writing not required/not required, patch infos
10.42.56 #6 Text 0 File DlgWaitCD.cpp, Line 202
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 326655 (72:37.30)
10.42.56 #7 Text 0 File DlgWaitCD.cpp, Line 207
10.42.56 #8 Text 0 File DlgWaitCD.cpp, Line 1407
Recorder: LITE-ON LTR-52246S;
CDRW code: 00 97 17 06; OSJ entry from: Moser Baer India Limited
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 11 06 (LI 97:17.06), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
10.42.56 #9 Text 0 File ThreadedTransferInterface.cpp, Line 818
Prepare recorder LITE-ON LTR-52246S for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close CD
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 669298688
10.42.56 #10 Text 0 File ThreadedTransferInterface.cpp, Line 846
Removed 2 run-out blocks from end of track 1.
10.42.56 #11 Text 0 File ThreadedTransferInterface.cpp, Line 666
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 326654 blocks [LITE-ON LTR-52246S ]
10.42.56 #12 Phase 36 File dlgbrnst.cpp, Line 1571
Burn process started at 24x (3.600 KB/s)
10.42.56 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1950
Verifying CD position of item 0 (relocatable, no CD pos, patch infos, orig at #0): write at #0
10.42.56 #14 Text 0 File Mmc.cpp, Line 17113
Set BUFE: supported -> ON , SMART-BURN : ON
10.44.11 #15 SCSI -1064 File Cdrdrv.cpp, Line 1415
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x026A0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x21
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x01 0x80 0x79 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x21 0x00
10.44.11 #16 MMC -1064 File Writer.cpp, Line 342
Invalid block address
10.44.11 #17 Text 0 File ThreadedTransfer.cpp, Line 222
10.44.12 #18 Text 0 File ThreadedTransfer.cpp, Line 216
10.44.12 #19 CDR -201 File WriterStatus.cpp, Line 188
Invalid write state
10.44.12 #20 TRANSFER -18 File WriterStatus.cpp, Line 188
Could not perform EndTrack
10.44.29 #21 Phase 38 File dlgbrnst.cpp, Line 1571
Burn process failed at 24x (3.600 KB/s)
10.44.29 #22 Text 0 File Scsicmd.cpp, Line 402
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 13.06.00
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29/08/2002 1.27.50 (Adapter driver for rec)
Registry Keys:
---------------- log 2 -------------------------------------
Windows XP 5.1
AutoRun : 0
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Free physical memory: 130MB (133956kB)
Memory in use : 74 %
Use Inquiry : 1
Wizard: Off
21.4.2003
CD-Immagine
10.49.40 #1 Phase 90 File dlgbrnst.cpp, Line 1571
10.49.40 #2 Text 0 File Reader.cpp, Line 118
Reader running
10.49.40 #3 Text 0 File Writer.cpp, Line 134
10.49.40 #4 Text 0 File Burncd.cpp, Line 3568
10.49.40 #5 Text 0 File ThreadedTransferInterface.cpp, Line 666
10.49.40 #6 Text 0 File DlgWaitCD.cpp, Line 202
10.49.40 #7 Text 0 File DlgWaitCD.cpp, Line 207
10.49.40 #8 Text 0 File DlgWaitCD.cpp, Line 1407
ATIP Data:
10.49.40 #9 Text 0 File ThreadedTransferInterface.cpp, Line 818
DAO infos:
MCN:
Tracks 1 to 1:
10.49.40 #10 Text 0 File ThreadedTransferInterface.cpp, Line 846
10.49.40 #11 Text 0 File ThreadedTransferInterface.cpp, Line 666
10.49.40 #12 Phase 36 File dlgbrnst.cpp, Line 1571
Burn process started at 32x (4.800 KB/s)
10.49.40 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1950
10.49.40 #14 Text 0 File Mmc.cpp, Line 17113
10.49.59 #15 SCSI -1064 File Cdrdrv.cpp, Line 1415
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x02730000
Sense Code: 0x21
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x26 0x06 0x00 0x00 0x1F 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x21 0x02
10.49.59 #16 MMC -1064 File Writer.cpp, Line 342
10.49.59 #17 Text 0 File ThreadedTransfer.cpp, Line 222
10.49.59 #18 Text 0 File ThreadedTransfer.cpp, Line 216
10.50.00 #19 CDR -201 File WriterStatus.cpp, Line 188
Invalid write state
10.50.00 #20 TRANSFER -18 File WriterStatus.cpp, Line 188
10.50.15 #21 Phase 38 File dlgbrnst.cpp, Line 1571
Burn process failed at 32x (4.800 KB/s)
10.50.15 #22 Text 0 File Scsicmd.cpp, Line 402
Existing drivers:
Registry Keys:
----------------------- log 3 -------------------------------------
Windows XP 5.1
AutoRun : 0
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Free physical memory: 185MB (190200kB)
Memory in use : 63 %
Use Inquiry : 1
Wizard: Off
20.4.2003
CueSheet
22.18.12 #1 Phase 90 File dlgbrnst.cpp, Line 1571
22.18.12 #2 Text 0 File Reader.cpp, Line 118
Reader running
22.18.12 #3 Text 0 File Writer.cpp, Line 134
22.18.12 #4 Text 0 File Burncd.cpp, Line 3568
Turn on UltraRaw 96-Mode, using CD-R/RW media
22.18.12 #5 Text 0 File ThreadedTransferInterface.cpp, Line 666
0: TRM_DATA_RAW_MODE1 (Cue Sheet Track)
2 indices, index0 (150) provided
original CD pos #0 + 323494 (323494) = #323494/71:53.19
relocatable, CD pos for caching/writing not required/not required, no patch infos
22.18.12 #6 Text 0 File DlgWaitCD.cpp, Line 202
Last address to be written: 323493 (71:55.18)
22.18.12 #7 Text 0 File DlgWaitCD.cpp, Line 207
22.18.12 #8 Text 0 File DlgWaitCD.cpp, Line 1407
ATIP Data:
22.18.12 #9 Text 0 File ThreadedTransferInterface.cpp, Line 818
Prepare recorder LITE-ON LTR-52246S for write in raw writing
DAO infos:
MCN:
Tracks 1 to 1:
TRM_ULTRARAW96, 2448/0x4, ISRC "", FilePos 0 367200 792280512
22.18.12 #10 Text 0 File ThreadedTransferInterface.cpp, Line 666
-> TRM_ULTRARAW96, 2448, config 0x4, wanted index0 0 blocks, length 323494 blocks [LITE-ON LTR-52246S ]
22.18.12 #11 Phase 36 File dlgbrnst.cpp, Line 1571
22.18.12 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1950
Verifying CD position of item 0 (relocatable, no CD pos, no patch infos, orig at #0): write at #0
22.18.12 #13 Text 0 File Mmc.cpp, Line 12580
StartDAO : CD-Text - Off
22.18.12 #14 Text 0 File Mmc.cpp, Line 17113
22.19.55 #15 SCSI -1064 File Cdrdrv.cpp, Line 1415
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x027A0000
Sense Code: 0x21
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x02 0x03 0xF0 0x00 0x00 0x1A 0x00 0x00 0x00
22.19.55 #16 MMC -1064 File Writer.cpp, Line 342
22.19.55 #17 Text 0 File ThreadedTransfer.cpp, Line 222
22.19.55 #18 Text 0 File ThreadedTransfer.cpp, Line 216
22.20.02 #19 Phase 38 File dlgbrnst.cpp, Line 1571
22.20.02 #20 Text 0 File Scsicmd.cpp, Line 402
Existing drivers:
Registry Keys:
THANKS ALL,
PLEASE HELP ME
BYE.
