Problems with DVD-R and Nero
Postby chris_the_fan on Sun Jan 08, 2006 6:08 pm
Tring to make some back-up copies of my DVD with my new DVD burnere and this message comes up and wanting to see if anyone know what this message means (I will post the whole thing).
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 9/10/1999 12:06:00 PM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero Version: 6.6.0.18
Internal Version: 6, 6, 0, 18e
(Nero Express)
Recorder: <LITE-ON DVDRW SOHW-1693S>Version: KS04 - HA 1 TA 1 - 6.6.0.18
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
CD-ROM: <MATSHITA DVD-ROM SR-8587 >Version: 5G26 - HA 1 TA 0 - 6.6.0.18
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD800BB-53CAA0 atapi Port 0 ID 0 DMA: Off
CdRomPeripheral : MATSHITA DVD-ROM SR-8587 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LITE-ON DVDRW SOHW-1693S atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
MATSHITA DVD-ROM SR-8587 D: CDRom0
LITE-ON DVDRW SOHW-1693S E: CDRom1
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 767MB (785712kB)
Free physical memory: 250MB (256076kB)
Memory in use : 67 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
8.1.2006
UDF/ISO compilation
4:31:40 PM #1 Phase 112 File dlgbrnst.cpp, Line 1832
DVD-Video files reallocation started
4:31:41 PM #2 Text 0 File DVDVideoCompilation.cpp, Line 552
Content of VIDEO_TS.IFO has been modified
4:31:41 PM #3 Text 0 File DVDVideoCompilation.cpp, Line 552
Content of VIDEO_TS.BUP has been modified
4:31:41 PM #4 Phase 113 File dlgbrnst.cpp, Line 1832
DVD-Video files reallocation completed
4:31:41 PM #5 Text 0 File Isodoc.cpp, Line 6359
UDF document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Revision : 1.02
UDF Partition Type : physical
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
4:31:41 PM #6 Phase 111 File dlgbrnst.cpp, Line 1832
DVD-Video files sorted
4:31:42 PM #7 Text 0 File Reader.cpp, Line 127
Reader running
4:31:42 PM #8 Text 0 File Writer.cpp, Line 122
Writer LITE-ON DVDRW SOHW-1693S running
4:31:42 PM #9 ISO9660GEN -11 File geniso.cpp, Line 3309
4:31:42 PM #10 ISO9660GEN -11 File geniso.cpp, Line 3309
4:31:42 PM #11 Text 0 File Burncd.cpp, Line 3233
4:31:43 PM #12 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1888863 (419:44.63, 3689MB)
4:31:43 PM #13 Text 0 File DlgWaitCD.cpp, Line 282
4:31:43 PM #14 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: LITE-ON DVDRW SOHW-1693S, Media type: DVD-R
Disc Manufacturer: SONY08 - D1
4:31:43 PM #15 Text 0 File DlgWaitCD.cpp, Line 448
4:31:43 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 838
0: TRM_DATA_MODE1 ()
original disc pos #0 + 1888864 (1888864) = #1888864/419:44.64
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1888864 blocks [LITE-ON DVDRW SOHW-1693S]
4:31:43 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [LITE-ON DVDRW SOHW-1693S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3868393472, ISRC ""
DAO layout:
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1888864 | lead-out | 1 | 0x41 | 0x00
4:31:43 PM #18 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
4:31:44 PM #19 Text 0 File Burncd.cpp, Line 4122
Cache writing successful.
4:31:44 PM #20 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
4:31:44 PM #21 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 8x (11,080 KB/s)
4:31:44 PM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2661
4:31:44 PM #23 Text 0 File DVDR.cpp, Line 2571
Recording mode: Sequential Recording Mode
4:31:44 PM #24 Text 0 File Mmc.cpp, Line 21774
Set BUFE: Buffer underrun protection -> ON , SMART-BURN : ON
4:31:44 PM #25 Text 0 File DVDR.cpp, Line 2726
Start write address at LBA 0
4:31:44 PM #26 Text 0 File Cdrdrv.cpp, Line 8892
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
4:33:05 PM #27 Text 0 File Cdrdrv.cpp, Line 1288
16:33:05.990 - LITE-ON DVDRW SOHW-1693S\H1 T1 : Queue again later
4:35:35 PM #28 SCSI -1046 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x0C2E0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x2A 0x00 0x00 0x00 0x05 0x60 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x30 0x05
4:35:35 PM #29 CDR -1046 File Writer.cpp, Line 311
Illegal disc
4:35:35 PM #30 Text 0 File ThreadedTransfer.cpp, Line 228
4:35:36 PM #31 Text 0 File ThreadedTransfer.cpp, Line 222
4:35:36 PM #32 Text 0 File DVDR.cpp, Line 2969
EndDAO: Last written address was 1375
4:35:36 PM #33 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 8x (11,080 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=6.0.0.171 , size=24839 bytes, created 1/13/2003 1:19:26 PM
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 9/10/1999 12:06:00 PM
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 9/14/2005 2:17:44 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/4/2004 7:00:00 AM (Adapter driver for rec)
Registry Keys:
chris_the_fan
Postby dodecahedron on Mon Jan 09, 2006 2:36 am
OK chris you need to post more info.
what your system specs? hardware?
what media are you using?
how did you try to back up your DVDs?
what softwares? what exactly did you do?
Postby chris_the_fan on Mon Jan 09, 2006 7:01 am
Specs:
-Windows XP (Version 2002, Service Pack 2)
-Pentium 4 1800MHz
-1.79GHz, 788 MB os RAM
-80GM Hard Drive
What tring to Do:
-Using DVD Decrypter to rip, and DVD Shrink 3.2 to back-up my Wedding Crashers DVD.
What else do you need?
chris_the_fan
Postby dodecahedron on Mon Jan 09, 2006 9:01 am
explain exactly what you did with Nero.
i might be wrong but from the log it looks like you were doing a DVD Video compilation, not burning an image.
Postby chris_the_fan on Mon Jan 09, 2006 7:31 pm
I put the DVD in and using the DVD Decrypter, rip in file mode to a folder. Then I open up DVD Shrink. Then click on Open files, choose the folder, then click on re-author and move Title 1 in Main Movie to the DVD Structure(with some extras, if they fit). The click on Back-up, and it goes through the process then the error message comes up I posted above.
chris_the_fan
Postby dodecahedron on Wed Jan 11, 2006 2:43 am
yeah, but what settings in the Back up dialog?
are you burning it directly to the disc with Nero? to an ISO image? to DVD folder (Video_TS) ?
Postby chris_the_fan on Thu Jan 12, 2006 6:42 am
In the settings right befroe I burn I say I want to "Burn with Nero (E:LightOn DVDRW SOHW-#'s)" Then I put my temp files into a folder. This is with DVD Shrink, the DVD Decrypter puts the movie in a folder with the move name and does have a folder called VIDEO_TS with a lot of files in that folder.
Is this what you are asking for?
chris_the_fan
Postby dodecahedron on Thu Jan 12, 2006 1:19 pm
maybe try making an ISO image and burn it separately.
but in any case i just noticed in your log that DMA is off for your hard drive!!! :o turn it on!
Postby chris_the_fan on Thu Jan 12, 2006 9:04 pm
The ISO image is the one large file, correct? When I do that it is too big for a DVD-R.
chris_the_fan
Postby dodecahedron on Fri Jan 13, 2006 1:35 am
so you need to shrink it.
click the Reauthor button, add just the stuff you want and shrink it.
there are many guides on how to use DVD Shrink on the web.
http://www.mrbass.org/dvdshrink/
www.doom9.org (search there...)
Postby CCampbell on Thu Jan 19, 2006 1:13 am
The Log file shows a 'Queue again later' error message, which means the drive was too busy to accept the write command. But seems to recover and then immediatly reports an 'Illegal disc'.
I would recommend try burning at a slower write speed instead of 8x, or try another brand of media.
