Problems updating Sony CRX140E firmware
Postby RyanVM on Sun Jan 05, 2003 1:30 am
I have a CRX-140E with firmware revision 1.0n on it. When I try updating to version 1.0p, the flashing program says it's incompatible with the computer when it tries to run (in pure DOS mode of course).
I've also tried the Windows-based flasher for firmware version 1.0s. Unfortunately, when I run that version, it says it can't detect any compatible drives for flashing.
It's currently the Secondary slave and the OS is WinXP. Any help you people could provide would be greatly appreciated.
P.S. Does anybody have a BIN rip of the 1.0s firmware?
RyanVM
Postby RyanVM on Sun Jan 05, 2003 7:19 pm
Quick update:
I tried flashing the drive with the 1.0p firmware using updcrx21 (the program included with the 1.0n firmware). When booting into DOS and trying to run it, it gave me the following messages:
Check sum data not good. Continue?
After continuing, it gave me the following message while trying to flash:
error(write buffer Mode 7)
Obviously, at this point, the flash failed. The drive came out unscathed though :)
Also, the exact error message from the Windows-based flasher is:
No updatable drives present
This time I tried running it with the drive as the Primary Master on a different computer.
Anybody have a clue what's going on here?
RyanVM
Postby BuddhaTB on Sun Jan 05, 2003 8:32 pm
What's the IDE configuration of your system? You said the CD-RW drive is secondary slave, what is on secondary master?
BuddhaTB
Postby RyanVM on Sun Jan 05, 2003 10:06 pm
Hard drive is primary master. Creative CD-ROM is secondary master. CD Writer is secondary slave.
Like I said in my followup, though, I made it primary master on another comp and still no luck :(
RyanVM
SONY CD-RW CRX140E firmware 2.02
Postby RBCoputers on Sat Mar 15, 2003 11:42 pm
Hi
I'm looking for a firmware upgrade for a sony cdrw crx140e currently has ver1.0n I've searched online and found that there is an update from 1.0(x) n-s but havent been able to find it does any one have it
Thank You
RBComputers
RBCoputers
Postby dhc014 on Sun Mar 16, 2003 12:01 am
dhc014
