problems burning NeroVision movie to DVD-R
Postby seastars on Fri Nov 24, 2006 3:30 pm
I'm a technoidiot, so I felt very, very impressed with myself today when I finally converted my old camcorder footage to digital files (using Plextor ConvertX hardware) and then used NeroVision to edit the digital files into a movie, ready to burn to DVD.
Except I get the message (during the transcoding phrase)
"Burn process failed! Would you like to create an error log?"
I've tried the following variants of my burn process without success:
+"Determine maximum speed" box under recording settings checked or unchecked
+Burn-at-Once box under recording settings checked or unchecked
+Write to Hard Disk folder instead of Burn to DVD
Here's some details taken from the burn screen itself:
Audio format: LPCM
Sample format: Automatic
Encoding mode: Fast Encoding (1-Pass)
Nero SmartEncoding: Automatic
Number of titles: 1
1. Baby Cruises: Month Eleven (Video Title, 1h 38m 02s)
- Audio SmartEncoding ratio: 0.0 %
- Video SmartEncoding ratio: 97.2 %
Number of menus: 1
- Menu for Baby Cruises: Month Eleven (6 pages)
Total space used: 3.40 out of 4.38GB (Quality:Excellent)
I have a ton of memory (hard drive space as well as RAM) on my computer and, at least the first few times I tried to burn, I didn't have any other applications open.
I made an error log the first time, but it's gibberish to me.
I emailed customer support but from prior experience I am expecting no help from them.
Please help.
seastars
Postby seastars on Fri Nov 24, 2006 6:37 pm
Oh - and the digital files I was working with were .mpg format, if that helps.
seastars
Postby seastars on Fri Nov 24, 2006 6:41 pm
And for those who can read error logs, here it is:
[09:33:28] NeroVision Log created (Date: 11/24/2006)
[09:33:28] NeroVision Processors: 1 (Intel)
[09:33:28] NeroVision OS: Windows XP
[09:33:28] GCCore Detected DirectX Version 9 or higher
[09:33:31] ExpressUI Running Nero Vision Version: 4.5.0.24
[09:33:33] GCCore Detected DirectX Version: 9.0c
[09:33:38] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
[09:33:38] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.48, Interface Version: 4.5.0.0
[09:33:38] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:33:38] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:33:38] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
[09:33:38] DVDEngine ..Application service registered...
[09:33:38] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
[09:33:39] NeroVision Estimate Size
[09:33:39] NeroVision +-------+------+--------+----------+---------
[09:33:39] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[09:33:39] NeroVision | 0 | 0 | 1 | 8.00 | 8037
[09:33:39] NeroVision | 1 | 0 | 1 | 8.00 | 1536
[09:33:39] NeroVision total data size : 10031616 bytes
[09:33:39] NeroVision multiplexed size : 10309632 bytes
[09:33:39] NeroVision | 0 | 0 | 1 | 5.00 | 5107
[09:33:39] NeroVision | 1 | 0 | 1 | 5.00 | 960
[09:33:39] NeroVision total data size : 6441792 bytes
[09:33:39] NeroVision multiplexed size : 6619136 bytes
[09:33:39] NeroVision | 0 | 0 | 1 | 20.00 | 19755
[09:33:39] NeroVision | 1 | 0 | 1 | 20.00 | 3840
[09:33:39] NeroVision | 2 | 0 | 0 | 20.00 | 0
[09:33:39] NeroVision total data size : 24390913 bytes
[09:33:39] NeroVision multiplexed size : 25073664 bytes
[09:33:39] NeroVision | 0 | 0 | 0 | 37.47 | 19103
[09:33:39] NeroVision | 0 | 1 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 2 | 0 | 67.50 | 36615
[09:33:39] NeroVision | 0 | 3 | 1 | 4.54 | 4656
[09:33:39] NeroVision | 0 | 4 | 0 | 63.00 | 26586
[09:33:39] NeroVision | 0 | 5 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 6 | 0 | 52.99 | 28248
[09:33:39] NeroVision | 0 | 7 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 8 | 0 | 94.53 | 57455
[09:33:39] NeroVision | 0 | 9 | 1 | 4.07 | 4199
[09:33:39] NeroVision | 0 | 10 | 0 | 169.60 | 87503
[09:33:39] NeroVision | 0 | 11 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 12 | 0 | 24.46 | 16233
[09:33:39] NeroVision | 0 | 13 | 1 | 4.07 | 4199
[09:33:39] NeroVision | 0 | 14 | 0 | 9.44 | 5612
[09:33:39] NeroVision | 0 | 15 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 16 | 0 | 64.50 | 34087
[09:33:39] NeroVision | 0 | 17 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 18 | 0 | 149.08 | 92472
[09:33:39] NeroVision | 0 | 19 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 20 | 0 | 44.98 | 29832
[09:33:39] NeroVision | 0 | 21 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 22 | 0 | 121.55 | 73409
[09:33:39] NeroVision | 0 | 23 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 24 | 0 | 117.55 | 70176
[09:33:39] NeroVision | 0 | 25 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 26 | 0 | 56.49 | 29947
[09:33:39] NeroVision | 0 | 27 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 28 | 0 | 19.95 | 11822
[09:33:39] NeroVision | 0 | 29 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 30 | 0 | 27.46 | 13058
[09:33:39] NeroVision | 0 | 31 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 32 | 0 | 63.00 | 42767
[09:33:39] NeroVision | 0 | 33 | 1 | 4.07 | 4199
[09:33:39] NeroVision | 0 | 34 | 0 | 199.13 | 105725
[09:33:39] NeroVision | 0 | 35 | 1 | 4.07 | 4199
[09:33:39] NeroVision | 0 | 36 | 0 | 77.01 | 51099
[09:33:39] NeroVision | 0 | 37 | 1 | 4.07 | 4199
[09:33:39] NeroVision | 0 | 38 | 0 | 225.16 | 66258
[09:33:39] NeroVision | 0 | 39 | 1 | 4.20 | 4330
[09:33:39] NeroVision | 0 | 40 | 0 | 521.45 | 99172
[09:33:39] NeroVision | 0 | 41 | 1 | 4.54 | 4656
[09:33:39] NeroVision | 0 | 42 | 0 | 116.05 | 21095
[09:33:39] NeroVision | 0 | 43 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 44 | 0 | 27.46 | 16094
[09:33:39] NeroVision | 0 | 45 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 46 | 0 | 84.02 | 42723
[09:33:39] NeroVision | 0 | 47 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 48 | 0 | 23.46 | 9854
[09:33:39] NeroVision | 0 | 49 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 50 | 0 | 7.94 | 4461
[09:33:39] NeroVision | 0 | 51 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 52 | 0 | 33.47 | 19022
[09:33:39] NeroVision | 0 | 53 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 54 | 0 | 45.98 | 29059
[09:33:39] NeroVision | 0 | 55 | 1 | 4.07 | 4199
[09:33:39] NeroVision | 0 | 56 | 0 | 35.47 | 20587
[09:33:39] NeroVision | 0 | 57 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 58 | 0 | 30.96 | 17548
[09:33:39] NeroVision | 0 | 59 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 60 | 0 | 56.99 | 28726
[09:33:39] NeroVision | 0 | 61 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 62 | 0 | 85.02 | 54953
[09:33:39] NeroVision | 0 | 63 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 64 | 0 | 20.45 | 9787
[09:33:39] NeroVision | 0 | 65 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 66 | 0 | 34.47 | 17368
[09:33:39] NeroVision | 0 | 67 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 68 | 0 | 275.21 | 145158
[09:33:39] NeroVision | 0 | 69 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 70 | 0 | 173.61 | 97295
[09:33:39] NeroVision | 0 | 71 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 72 | 0 | 219.65 | 133043
[09:33:39] NeroVision | 0 | 73 | 1 | 4.07 | 4199
[09:33:39] NeroVision | 0 | 74 | 0 | 256.69 | 167147
[09:33:39] NeroVision | 0 | 75 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 76 | 0 | 161.09 | 104880
[09:33:39] NeroVision | 0 | 77 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 78 | 0 | 44.98 | 27524
[09:33:39] NeroVision | 0 | 79 | 1 | 4.57 | 4688
[09:33:39] NeroVision | 0 | 80 | 0 | 1764.70 | 152991
[09:33:39] NeroVision | 1 | 0 | 1 | 5882.92 | 1129520
[09:33:39] NeroVision total data size : 3512232440 bytes
[09:33:39] NeroVision multiplexed size : 3647293440 bytes
[09:33:39] MMTools SourceBuilder: building c:\Documents and Settings\Suzanne\My Documents\My Videos\AV11242006_074525.mpg video/0
[09:33:41] MMTools SourceBuilder: --- used source filters ---
[09:33:41] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[09:33:41] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[09:33:41] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[09:33:41] MMTools SourceBuilder: file type MPEG2 - video
[09:33:41] MMTools --------------------
[09:33:43] MMTools SourceBuilder: building c:\Documents and Settings\Suzanne\My Documents\My Videos\Movie 5\AV04232006_070746.mpg video/0
[09:33:44] MMTools SourceBuilder: --- used source filters ---
[09:33:44] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[09:33:44] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[09:33:44] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[09:33:44] MMTools SourceBuilder: file type MPEG2 - video
[09:33:44] MMTools --------------------
[09:33:47] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Golf.mp4 audio/0
[09:33:47] MMTools SourceBuilder: failed to build c:\Program Files\Nero\Nero 7\Nero Vision\Video\Golf.mp4 audio: 0x80040207 - The owner SID on a per-user subscription doesn't exist
[09:33:47] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Golf.mp4 video/0
[09:33:47] MMTools SourceBuilder: --- used source filters ---
[09:33:47] MMTools {E206E4DE-A7EE-4A62-B3E9-4FBC8FE84C73} - Nero Digital Parser
[09:33:47] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[09:33:47] MMTools SourceBuilder: file type MP4 - video
[09:33:47] MMTools --------------------
[09:33:47] AMCUIBase Asset created by user: class AVFileAsset
[09:33:47] AMCUIBase - file paths: 1, first = 'c:\Program Files\Nero\Nero 7\Nero Vision\Video\Golf.mp4')
[09:33:47] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Halloween.mp4 audio/0
[09:33:47] MMTools SourceBuilder: failed to build c:\Program Files\Nero\Nero 7\Nero Vision\Video\Halloween.mp4 audio: 0x80040207 - The owner SID on a per-user subscription doesn't exist
[09:33:47] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Halloween.mp4 video/0
[09:33:48] AMCUIBase Asset created by user: class AVFileAsset
[09:33:48] AMCUIBase - file paths: 1, first = 'c:\Program Files\Nero\Nero 7\Nero Vision\Video\Halloween.mp4')
[09:33:48] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Holidays.mp4 audio/0
[09:33:48] MMTools SourceBuilder: failed to build c:\Program Files\Nero\Nero 7\Nero Vision\Video\Holidays.mp4 audio: 0x80040207 - The owner SID on a per-user subscription doesn't exist
[09:33:48] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Holidays.mp4 video/0
[09:33:48] MMTools SourceBuilder: --- used source filters ---
[09:33:48] MMTools {E206E4DE-A7EE-4A62-B3E9-4FBC8FE84C73} - Nero Digital Parser
[09:33:48] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[09:33:48] MMTools SourceBuilder: file type MP4 - video
[09:33:48] MMTools --------------------
[09:33:49] AMCUIBase Asset created by user: class AVFileAsset
[09:33:49] AMCUIBase - file paths: 1, first = 'c:\Program Files\Nero\Nero 7\Nero Vision\Video\Holidays.mp4')
[09:33:49] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Music.mp4 audio/0
[09:33:49] MMTools SourceBuilder: --- used source filters ---
[09:33:49] MMTools {E206E4DE-A7EE-4A62-B3E9-4FBC8FE84C73} - Nero Digital Parser
[09:33:49] MMTools {83E69A3D-56A5-4850-89C9-F6B6F003EB9B} - NeAudio2
[09:33:49] MMTools SourceBuilder: file type MP4 - audio
[09:33:49] MMTools --------------------
[09:33:49] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Music.mp4 video/0
[09:33:50] MMTools SourceBuilder: --- used source filters ---
[09:33:50] MMTools {E206E4DE-A7EE-4A62-B3E9-4FBC8FE84C73} - Nero Digital Parser
[09:33:50] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[09:33:50] MMTools SourceBuilder: file type MP4 - video
[09:33:50] MMTools --------------------
[09:33:50] AMCUIBase Asset created by user: class AVFileAsset
[09:33:50] AMCUIBase - file paths: 1, first = 'c:\Program Files\Nero\Nero 7\Nero Vision\Video\Music.mp4')
[09:33:50] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\OurWedding.mp4 audio/0
[09:33:50] MMTools SourceBuilder: failed to build c:\Program Files\Nero\Nero 7\Nero Vision\Video\OurWedding.mp4 audio: 0x80040207 - The owner SID on a per-user subscription doesn't exist
[09:33:50] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\OurWedding.mp4 video/0
[09:33:51] AMCUIBase Asset created by user: class AVFileAsset
[09:33:51] AMCUIBase - file paths: 1, first = 'c:\Program Files\Nero\Nero 7\Nero Vision\Video\OurWedding.mp4')
[09:33:51] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Silk.mp4 audio/0
[09:33:51] MMTools SourceBuilder: failed to build c:\Program Files\Nero\Nero 7\Nero Vision\Video\Silk.mp4 audio: 0x80040207 - The owner SID on a per-user subscription doesn't exist
[09:33:51] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Silk.mp4 video/0
[09:33:51] MMTools SourceBuilder: --- used source filters ---
[09:33:51] MMTools {E206E4DE-A7EE-4A62-B3E9-4FBC8FE84C73} - Nero Digital Parser
[09:33:51] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[09:33:51] MMTools SourceBuilder: file type MP4 - video
[09:33:51] MMTools --------------------
[09:33:54] MMTools BitmapGrabber::InternalGetBitmap - error handler (begin stop graph)
[09:33:54] MMTools BitmapGrabber::InternalGetBitmap - error handler (end stop graph)
[09:33:54] AMCUIBase Asset created by user: class AVFileAsset
[09:33:54] AMCUIBase - file paths: 1, first = 'c:\Program Files\Nero\Nero 7\Nero Vision\Video\Silk.mp4')
[09:33:54] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Sparkler.mp4 audio/0
[09:33:54] MMTools SourceBuilder: failed to build c:\Program Files\Nero\Nero 7\Nero Vision\Video\Sparkler.mp4 audio: 0x80040207 - The owner SID on a per-user subscription doesn't exist
[09:33:54] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Sparkler.mp4 video/0
[09:33:54] MMTools SourceBuilder: --- used source filters ---
[09:33:54] MMTools {E206E4DE-A7EE-4A62-B3E9-4FBC8FE84C73} - Nero Digital Parser
[09:33:54] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[09:33:54] MMTools SourceBuilder: file type MP4 - video
[09:33:54] MMTools --------------------
[09:33:56] AMCUIBase Asset created by user: class AVFileAsset
[09:33:56] AMCUIBase - file paths: 1, first = 'c:\Program Files\Nero\Nero 7\Nero Vision\Video\Sparkler.mp4')
[09:33:56] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Tennis.mp4 audio/0
[09:33:56] MMTools SourceBuilder: failed to build c:\Program Files\Nero\Nero 7\Nero Vision\Video\Tennis.mp4 audio: 0x80040207 - The owner SID on a per-user subscription doesn't exist
[09:33:56] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Tennis.mp4 video/0
[09:33:56] MMTools SourceBuilder: --- used source filters ---
[09:33:56] MMTools {E206E4DE-A7EE-4A62-B3E9-4FBC8FE84C73} - Nero Digital Parser
[09:33:56] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[09:33:56] MMTools SourceBuilder: file type MP4 - video
[09:33:56] MMTools --------------------
[09:33:56] AMCUIBase - file paths: 1, first = 'c:\Program Files\Nero\Nero 7\Nero Vision\Video\Tennis.mp4')
[09:33:56] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Velvet.mp4 audio/0
[09:33:56] MMTools SourceBuilder: failed to build c:\Program Files\Nero\Nero 7\Nero Vision\Video\Velvet.mp4 audio: 0x80040207 - The owner SID on a per-user subscription doesn't exist
[09:33:56] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Velvet.mp4 video/0
[09:33:57] AMCUIBase Asset created by user: class AVFileAsset
[09:33:57] AMCUIBase - file paths: 1, first = 'c:\Program Files\Nero\Nero 7\Nero Vision\Video\Velvet.mp4')
[09:33:57] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Winter.mp4 audio/0
[09:33:57] MMTools SourceBuilder: failed to build c:\Program Files\Nero\Nero 7\Nero Vision\Video\Winter.mp4 audio: 0x80040207 - The owner SID on a per-user subscription doesn't exist
[09:33:57] MMTools SourceBuilder: building c:\Program Files\Nero\Nero 7\Nero Vision\Video\Winter.mp4 video/0
[09:33:57] MMTools SourceBuilder: --- used source filters ---
[09:33:57] MMTools {E206E4DE-A7EE-4A62-B3E9-4FBC8FE84C73} - Nero Digital Parser
[09:33:57] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[09:33:57] MMTools SourceBuilder: file type MP4 - video
[09:33:57] MMTools --------------------
[09:33:57] AMCUIBase - file paths: 1, first = 'c:\Program Files\Nero\Nero 7\Nero Vision\Video\Winter.mp4')
[09:34:54] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[09:34:54] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[09:34:54] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:34:54] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:34:54] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
[09:34:54] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.48, Interface Version: 4.5.0.0
[09:34:54] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:34:54] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:34:54] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
[09:34:54] DVDEngine ..Application service registered...
[09:34:54] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
[09:34:54] NeroVision Estimate Size
[09:34:54] NeroVision +-------+------+--------+----------+---------
[09:34:54] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[09:34:54] NeroVision | 0 | 0 | 1 | 0.03 | 224
[09:34:54] NeroVision | 1 | 0 | 0 | 0.03 | 0
[09:34:54] NeroVision total data size : 458753 bytes
[09:34:54] NeroVision multiplexed size : 475136 bytes
[09:34:54] NeroVision | 0 | 0 | 0 | 37.47 | 19103
[09:34:54] NeroVision | 0 | 1 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 2 | 0 | 67.50 | 36615
[09:34:54] NeroVision | 0 | 3 | 1 | 4.54 | 4656
[09:34:54] NeroVision | 0 | 4 | 0 | 63.00 | 26586
[09:34:54] NeroVision | 0 | 5 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 6 | 0 | 52.99 | 28248
[09:34:54] NeroVision | 0 | 7 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 8 | 0 | 94.53 | 57455
[09:34:54] NeroVision | 0 | 9 | 1 | 4.07 | 4199
[09:34:54] NeroVision | 0 | 10 | 0 | 169.60 | 87503
[09:34:54] NeroVision | 0 | 11 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 12 | 0 | 24.46 | 16233
[09:34:54] NeroVision | 0 | 13 | 1 | 4.07 | 4199
[09:34:54] NeroVision | 0 | 14 | 0 | 9.44 | 5612
[09:34:54] NeroVision | 0 | 15 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 16 | 0 | 64.50 | 34087
[09:34:54] NeroVision | 0 | 17 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 18 | 0 | 149.08 | 92472
[09:34:54] NeroVision | 0 | 19 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 20 | 0 | 44.98 | 29832
[09:34:54] NeroVision | 0 | 21 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 22 | 0 | 121.55 | 73409
[09:34:54] NeroVision | 0 | 23 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 24 | 0 | 117.55 | 70176
[09:34:54] NeroVision | 0 | 25 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 26 | 0 | 56.49 | 29947
[09:34:54] NeroVision | 0 | 27 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 28 | 0 | 19.95 | 11822
[09:34:54] NeroVision | 0 | 29 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 30 | 0 | 27.46 | 13058
[09:34:54] NeroVision | 0 | 31 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 32 | 0 | 63.00 | 42767
[09:34:54] NeroVision | 0 | 33 | 1 | 4.07 | 4199
[09:34:54] NeroVision | 0 | 34 | 0 | 199.13 | 105725
[09:34:54] NeroVision | 0 | 35 | 1 | 4.07 | 4199
[09:34:54] NeroVision | 0 | 36 | 0 | 77.01 | 51099
[09:34:54] NeroVision | 0 | 37 | 1 | 4.07 | 4199
[09:34:54] NeroVision | 0 | 38 | 0 | 225.16 | 66258
[09:34:54] NeroVision | 0 | 39 | 1 | 4.20 | 4330
[09:34:54] NeroVision | 0 | 40 | 0 | 521.45 | 99172
[09:34:54] NeroVision | 0 | 41 | 1 | 4.54 | 4656
[09:34:54] NeroVision | 0 | 42 | 0 | 116.05 | 21095
[09:34:54] NeroVision | 0 | 43 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 44 | 0 | 27.46 | 16094
[09:34:54] NeroVision | 0 | 45 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 46 | 0 | 84.02 | 42723
[09:34:54] NeroVision | 0 | 47 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 48 | 0 | 23.46 | 9854
[09:34:54] NeroVision | 0 | 49 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 50 | 0 | 7.94 | 4461
[09:34:54] NeroVision | 0 | 51 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 52 | 0 | 33.47 | 19022
[09:34:54] NeroVision | 0 | 53 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 54 | 0 | 45.98 | 29059
[09:34:54] NeroVision | 0 | 55 | 1 | 4.07 | 4199
[09:34:54] NeroVision | 0 | 56 | 0 | 35.47 | 20587
[09:34:54] NeroVision | 0 | 57 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 58 | 0 | 30.96 | 17548
[09:34:54] NeroVision | 0 | 59 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 60 | 0 | 56.99 | 28726
[09:34:54] NeroVision | 0 | 61 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 62 | 0 | 85.02 | 54953
[09:34:54] NeroVision | 0 | 63 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 64 | 0 | 20.45 | 9787
[09:34:54] NeroVision | 0 | 65 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 66 | 0 | 34.47 | 17368
[09:34:54] NeroVision | 0 | 67 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 68 | 0 | 275.21 | 145158
[09:34:54] NeroVision | 0 | 69 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 70 | 0 | 173.61 | 97295
[09:34:54] NeroVision | 0 | 71 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 72 | 0 | 219.65 | 133043
[09:34:54] NeroVision | 0 | 73 | 1 | 4.07 | 4199
[09:34:54] NeroVision | 0 | 74 | 0 | 256.69 | 167147
[09:34:54] NeroVision | 0 | 75 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 76 | 0 | 161.09 | 104880
[09:34:54] NeroVision | 0 | 77 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 78 | 0 | 44.98 | 27524
[09:34:54] NeroVision | 0 | 79 | 1 | 4.57 | 4688
[09:34:54] NeroVision | 0 | 80 | 0 | 1764.70 | 152991
[09:34:54] NeroVision | 1 | 0 | 1 | 5882.92 | 1129520
[09:34:54] NeroVision total data size : 3512232440 bytes
[09:34:54] NeroVision multiplexed size : 3647293440 bytes
[09:34:56] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[09:34:56] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[09:34:56] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:34:56] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:34:56] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
[09:34:56] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.48, Interface Version: 4.5.0.0
[09:34:56] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:34:56] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:34:56] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
[09:34:56] DVDEngine ..Application service registered...
[09:34:56] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
[09:34:56] NeroVision Estimate Size
[09:34:56] NeroVision +-------+------+--------+----------+---------
[09:34:56] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[09:34:56] NeroVision | 0 | 0 | 1 | 0.03 | 224
[09:34:56] NeroVision | 1 | 0 | 0 | 0.03 | 0
[09:34:56] NeroVision total data size : 458753 bytes
[09:34:56] NeroVision multiplexed size : 475136 bytes
seastars
Postby seastars on Sat Nov 25, 2006 11:48 am
For kicks and giggles I exported (using NeroVision) my Nero .nvc file (the completed movie) into .mpg format. The new .mpg file would then play fine in RealPlayer or Nero. BUT when I tried to burn the .mpg onto DVD - to test out my hypothesis that maybe my DVD burner somehow didn't recognize the .nvc file extension - I got a "problems burning" message.
So there appears to be something wrong with my .nvc movie itself. ("Themselves," actually - I made another, from different files, to try this again.)
What's really weird is that the .nvc movie plays just fine for me in Preview mode of NeroVision. It's just when I hit the next page and start the burn, that there's the error message (a couple of minutes into its "transcoding" phase). Help!
seastars
Postby dodecahedron on Sat Nov 25, 2006 1:44 pm
i'm not very knowledgeable about NeroVision, but here i go anyway:
1. your log seems to be truncated. why don't you post it as a text file attachment?
2. i don't understand how you can get a "Burn process failed!" error during the transcoding process.
is the error during the transcoding process or during the actual burn to disc stage ?
3. your expactation of zero help from techsupport seems reaslistic to me.
4. i don't understand how you burn the .mpg file.
did you burn using Nero? if so, it would be very helpful it you post the Nero log.
if you burn a .mpg file it will burn as a data file. if you want it to burn to the disc as a movie (that can be played in a DVD player) it has to be transcoded...and that means NeroVision.
hope that helps.
Postby seastars on Sat Nov 25, 2006 3:44 pm
I really appreciate your trying to help - i feel extremely frustrated.
Oh! Okay; my error copy-and-pasting. I've added as a text file. OOPS! No I haven't. The log is a .txt file and I get the error message "extension not allowed" when I try to attach. I'll post again.
2. i don't understand how you can get a "Burn process failed!" error during the transcoding process.is the error during the transcoding process or during the actual burn to disc stage ?
I was all the way at the end, and I pushed "burn now" or whatever. The screen changed; it asked me where I wanted to burn to (DVD-R I chose most times). I pushed "burn now" again. Screen changed and it said it was doing three steps: transcoding (that was highlighted, so presumably it was doing that), verify write speed, and then writing. During the time when transcoding was highlighted, and my movie was flickering across the screen's little mini-tv box, is when i got the "burn error!" error message. So that's why I'm guessing - I sure don't know! - it's some sort of transcoding problem, because it was in that staged when I got the error message. The transcoding phase way at the beginning of moviemaking, when I imported my .mpg files and detected chapters and such, went fine.
At the end of Nerovision, instead of burning to dvd or whatever, you can (and I did) push the button "export" and it'll copy your movie into an .mpg format and stick it on your harddrive under Nerovision/Exported Video Files. I could then go into My Computer, click on that icon and watch it in Nero just like any other mpg file.
seastars
Postby seastars on Sat Nov 25, 2006 3:49 pm
CONTINUATION OF BURN LOG
[09:34:56] NeroVision | 0 | 0 | 0 | 37.47 | 19103
[09:34:56] NeroVision | 0 | 1 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 2 | 0 | 67.50 | 36615
[09:34:56] NeroVision | 0 | 3 | 1 | 4.54 | 4656
[09:34:56] NeroVision | 0 | 4 | 0 | 63.00 | 26586
[09:34:56] NeroVision | 0 | 5 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 6 | 0 | 52.99 | 28248
[09:34:56] NeroVision | 0 | 7 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 8 | 0 | 94.53 | 57455
[09:34:56] NeroVision | 0 | 9 | 1 | 4.07 | 4199
[09:34:56] NeroVision | 0 | 10 | 0 | 169.60 | 87503
[09:34:56] NeroVision | 0 | 11 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 12 | 0 | 24.46 | 16233
[09:34:56] NeroVision | 0 | 13 | 1 | 4.07 | 4199
[09:34:56] NeroVision | 0 | 14 | 0 | 9.44 | 5612
[09:34:56] NeroVision | 0 | 15 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 16 | 0 | 64.50 | 34087
[09:34:56] NeroVision | 0 | 17 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 18 | 0 | 149.08 | 92472
[09:34:56] NeroVision | 0 | 19 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 20 | 0 | 44.98 | 29832
[09:34:56] NeroVision | 0 | 21 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 22 | 0 | 121.55 | 73409
[09:34:56] NeroVision | 0 | 23 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 24 | 0 | 117.55 | 70176
[09:34:56] NeroVision | 0 | 25 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 26 | 0 | 56.49 | 29947
[09:34:56] NeroVision | 0 | 27 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 28 | 0 | 19.95 | 11822
[09:34:56] NeroVision | 0 | 29 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 30 | 0 | 27.46 | 13058
[09:34:56] NeroVision | 0 | 31 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 32 | 0 | 63.00 | 42767
[09:34:56] NeroVision | 0 | 33 | 1 | 4.07 | 4199
[09:34:56] NeroVision | 0 | 34 | 0 | 199.13 | 105725
[09:34:56] NeroVision | 0 | 35 | 1 | 4.07 | 4199
[09:34:56] NeroVision | 0 | 36 | 0 | 77.01 | 51099
[09:34:56] NeroVision | 0 | 37 | 1 | 4.07 | 4199
[09:34:56] NeroVision | 0 | 38 | 0 | 225.16 | 66258
[09:34:56] NeroVision | 0 | 39 | 1 | 4.20 | 4330
[09:34:56] NeroVision | 0 | 40 | 0 | 521.45 | 99172
[09:34:56] NeroVision | 0 | 41 | 1 | 4.54 | 4656
[09:34:56] NeroVision | 0 | 42 | 0 | 116.05 | 21095
[09:34:56] NeroVision | 0 | 43 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 44 | 0 | 27.46 | 16094
[09:34:56] NeroVision | 0 | 45 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 46 | 0 | 84.02 | 42723
[09:34:56] NeroVision | 0 | 47 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 48 | 0 | 23.46 | 9854
[09:34:56] NeroVision | 0 | 49 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 50 | 0 | 7.94 | 4461
[09:34:56] NeroVision | 0 | 51 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 52 | 0 | 33.47 | 19022
[09:34:56] NeroVision | 0 | 53 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 54 | 0 | 45.98 | 29059
[09:34:56] NeroVision | 0 | 55 | 1 | 4.07 | 4199
[09:34:56] NeroVision | 0 | 56 | 0 | 35.47 | 20587
[09:34:56] NeroVision | 0 | 57 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 58 | 0 | 30.96 | 17548
[09:34:56] NeroVision | 0 | 59 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 60 | 0 | 56.99 | 28726
[09:34:56] NeroVision | 0 | 61 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 62 | 0 | 85.02 | 54953
[09:34:56] NeroVision | 0 | 63 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 64 | 0 | 20.45 | 9787
[09:34:56] NeroVision | 0 | 65 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 66 | 0 | 34.47 | 17368
[09:34:56] NeroVision | 0 | 67 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 68 | 0 | 275.21 | 145158
[09:34:56] NeroVision | 0 | 69 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 70 | 0 | 173.61 | 97295
[09:34:56] NeroVision | 0 | 71 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 72 | 0 | 219.65 | 133043
[09:34:56] NeroVision | 0 | 73 | 1 | 4.07 | 4199
[09:34:56] NeroVision | 0 | 74 | 0 | 256.69 | 167147
[09:34:56] NeroVision | 0 | 75 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 76 | 0 | 161.09 | 104880
[09:34:56] NeroVision | 0 | 77 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 78 | 0 | 44.98 | 27524
[09:34:56] NeroVision | 0 | 79 | 1 | 4.57 | 4688
[09:34:56] NeroVision | 0 | 80 | 0 | 1764.70 | 152991
[09:34:56] NeroVision | 1 | 0 | 1 | 5882.92 | 1129520
[09:34:56] NeroVision total data size : 3512232440 bytes
[09:34:56] NeroVision multiplexed size : 3647293440 bytes
[09:35:11] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[09:35:11] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[09:35:11] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:35:11] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:35:11] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
[09:35:11] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.48, Interface Version: 4.5.0.0
[09:35:11] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:35:11] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:35:11] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
[09:35:11] DVDEngine ..Application service registered...
[09:35:11] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
[09:35:11] NeroVision Estimate Size
[09:35:11] NeroVision +-------+------+--------+----------+---------
[09:35:11] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[09:35:11] NeroVision | 0 | 0 | 1 | 0.03 | 224
[09:35:11] NeroVision | 1 | 0 | 0 | 0.03 | 0
[09:35:11] NeroVision total data size : 458753 bytes
[09:35:11] NeroVision multiplexed size : 475136 bytes
[09:35:11] NeroVision | 0 | 0 | 0 | 37.47 | 19103
[09:35:11] NeroVision | 0 | 1 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 2 | 0 | 67.50 | 36615
[09:35:11] NeroVision | 0 | 3 | 1 | 4.54 | 4656
[09:35:11] NeroVision | 0 | 4 | 0 | 63.00 | 26586
[09:35:11] NeroVision | 0 | 5 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 6 | 0 | 52.99 | 28248
[09:35:11] NeroVision | 0 | 7 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 8 | 0 | 94.53 | 57455
[09:35:11] NeroVision | 0 | 9 | 1 | 4.07 | 4199
[09:35:11] NeroVision | 0 | 10 | 0 | 169.60 | 87503
[09:35:11] NeroVision | 0 | 11 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 12 | 0 | 24.46 | 16233
[09:35:11] NeroVision | 0 | 13 | 1 | 4.07 | 4199
[09:35:11] NeroVision | 0 | 14 | 0 | 9.44 | 5612
[09:35:11] NeroVision | 0 | 15 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 16 | 0 | 64.50 | 34087
[09:35:11] NeroVision | 0 | 17 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 18 | 0 | 149.08 | 92472
[09:35:11] NeroVision | 0 | 19 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 20 | 0 | 44.98 | 29832
[09:35:11] NeroVision | 0 | 21 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 22 | 0 | 121.55 | 73409
[09:35:11] NeroVision | 0 | 23 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 24 | 0 | 117.55 | 70176
[09:35:11] NeroVision | 0 | 25 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 26 | 0 | 56.49 | 29947
[09:35:11] NeroVision | 0 | 27 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 28 | 0 | 19.95 | 11822
[09:35:11] NeroVision | 0 | 29 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 30 | 0 | 27.46 | 13058
[09:35:11] NeroVision | 0 | 31 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 32 | 0 | 63.00 | 42767
[09:35:11] NeroVision | 0 | 33 | 1 | 4.07 | 4199
[09:35:11] NeroVision | 0 | 34 | 0 | 199.13 | 105725
[09:35:11] NeroVision | 0 | 35 | 1 | 4.07 | 4199
[09:35:11] NeroVision | 0 | 36 | 0 | 77.01 | 51099
[09:35:11] NeroVision | 0 | 37 | 1 | 4.07 | 4199
[09:35:11] NeroVision | 0 | 38 | 0 | 225.16 | 66258
[09:35:11] NeroVision | 0 | 39 | 1 | 4.20 | 4330
[09:35:11] NeroVision | 0 | 40 | 0 | 521.45 | 99172
[09:35:11] NeroVision | 0 | 41 | 1 | 4.54 | 4656
[09:35:11] NeroVision | 0 | 42 | 0 | 116.05 | 21095
[09:35:11] NeroVision | 0 | 43 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 44 | 0 | 27.46 | 16094
[09:35:11] NeroVision | 0 | 45 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 46 | 0 | 84.02 | 42723
[09:35:11] NeroVision | 0 | 47 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 48 | 0 | 23.46 | 9854
[09:35:11] NeroVision | 0 | 49 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 50 | 0 | 7.94 | 4461
[09:35:11] NeroVision | 0 | 51 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 52 | 0 | 33.47 | 19022
[09:35:11] NeroVision | 0 | 53 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 54 | 0 | 45.98 | 29059
[09:35:11] NeroVision | 0 | 55 | 1 | 4.07 | 4199
[09:35:11] NeroVision | 0 | 56 | 0 | 35.47 | 20587
[09:35:11] NeroVision | 0 | 57 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 58 | 0 | 30.96 | 17548
[09:35:11] NeroVision | 0 | 59 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 60 | 0 | 56.99 | 28726
[09:35:11] NeroVision | 0 | 61 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 62 | 0 | 85.02 | 54953
[09:35:11] NeroVision | 0 | 63 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 64 | 0 | 20.45 | 9787
[09:35:11] NeroVision | 0 | 65 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 66 | 0 | 34.47 | 17368
[09:35:11] NeroVision | 0 | 67 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 68 | 0 | 275.21 | 145158
[09:35:11] NeroVision | 0 | 69 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 70 | 0 | 173.61 | 97295
[09:35:11] NeroVision | 0 | 71 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 72 | 0 | 219.65 | 133043
[09:35:11] NeroVision | 0 | 73 | 1 | 4.07 | 4199
[09:35:11] NeroVision | 0 | 74 | 0 | 256.69 | 167147
[09:35:11] NeroVision | 0 | 75 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 76 | 0 | 161.09 | 104880
[09:35:11] NeroVision | 0 | 77 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 78 | 0 | 44.98 | 27524
[09:35:11] NeroVision | 0 | 79 | 1 | 4.57 | 4688
[09:35:11] NeroVision | 0 | 80 | 0 | 1764.70 | 152991
[09:35:11] NeroVision | 1 | 0 | 1 | 5882.92 | 1129520
[09:35:11] NeroVision total data size : 3512232440 bytes
[09:35:11] NeroVision multiplexed size : 3647293440 bytes
[09:35:31] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[09:35:31] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[09:35:31] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:35:31] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:35:31] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
[09:35:31] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.48, Interface Version: 4.5.0.0
[09:35:31] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:35:31] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:35:31] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
[09:35:31] DVDEngine ..Application service registered...
[09:35:31] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
[09:35:32] NeroVision Estimate Size
[09:35:32] NeroVision +-------+------+--------+----------+---------
[09:35:32] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[09:35:32] NeroVision | 0 | 0 | 1 | 0.03 | 224
[09:35:32] NeroVision | 1 | 0 | 0 | 0.03 | 0
[09:35:32] NeroVision total data size : 458753 bytes
[09:35:32] NeroVision multiplexed size : 475136 bytes
[09:35:32] NeroVision | 0 | 0 | 0 | 37.47 | 19103
[09:35:32] NeroVision | 0 | 1 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 2 | 0 | 67.50 | 36615
[09:35:32] NeroVision | 0 | 3 | 1 | 4.54 | 4656
[09:35:32] NeroVision | 0 | 4 | 0 | 63.00 | 26586
[09:35:32] NeroVision | 0 | 5 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 6 | 0 | 52.99 | 28248
[09:35:32] NeroVision | 0 | 7 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 8 | 0 | 94.53 | 57455
[09:35:32] NeroVision | 0 | 9 | 1 | 4.07 | 4199
[09:35:32] NeroVision | 0 | 10 | 0 | 169.60 | 87503
[09:35:32] NeroVision | 0 | 11 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 12 | 0 | 24.46 | 16233
[09:35:32] NeroVision | 0 | 13 | 1 | 4.07 | 4199
[09:35:32] NeroVision | 0 | 14 | 0 | 9.44 | 5612
[09:35:32] NeroVision | 0 | 15 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 16 | 0 | 64.50 | 34087
[09:35:32] NeroVision | 0 | 17 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 18 | 0 | 149.08 | 92472
[09:35:32] NeroVision | 0 | 19 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 20 | 0 | 44.98 | 29832
[09:35:32] NeroVision | 0 | 21 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 22 | 0 | 121.55 | 73409
[09:35:32] NeroVision | 0 | 23 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 24 | 0 | 117.55 | 70176
[09:35:32] NeroVision | 0 | 25 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 26 | 0 | 56.49 | 29947
[09:35:32] NeroVision | 0 | 27 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 28 | 0 | 19.95 | 11822
[09:35:32] NeroVision | 0 | 29 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 30 | 0 | 27.46 | 13058
[09:35:32] NeroVision | 0 | 31 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 32 | 0 | 63.00 | 42767
[09:35:32] NeroVision | 0 | 33 | 1 | 4.07 | 4199
[09:35:32] NeroVision | 0 | 34 | 0 | 199.13 | 105725
[09:35:32] NeroVision | 0 | 35 | 1 | 4.07 | 4199
[09:35:32] NeroVision | 0 | 36 | 0 | 77.01 | 51099
[09:35:32] NeroVision | 0 | 37 | 1 | 4.07 | 4199
[09:35:32] NeroVision | 0 | 38 | 0 | 225.16 | 66258
[09:35:32] NeroVision | 0 | 39 | 1 | 4.20 | 4330
[09:35:32] NeroVision | 0 | 40 | 0 | 521.45 | 99172
[09:35:32] NeroVision | 0 | 41 | 1 | 4.54 | 4656
[09:35:32] NeroVision | 0 | 42 | 0 | 116.05 | 21095
[09:35:32] NeroVision | 0 | 43 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 44 | 0 | 27.46 | 16094
[09:35:32] NeroVision | 0 | 45 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 46 | 0 | 84.02 | 42723
[09:35:32] NeroVision | 0 | 47 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 48 | 0 | 23.46 | 9854
[09:35:32] NeroVision | 0 | 49 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 50 | 0 | 7.94 | 4461
[09:35:32] NeroVision | 0 | 51 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 52 | 0 | 33.47 | 19022
[09:35:32] NeroVision | 0 | 53 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 54 | 0 | 45.98 | 29059
[09:35:32] NeroVision | 0 | 55 | 1 | 4.07 | 4199
[09:35:32] NeroVision | 0 | 56 | 0 | 35.47 | 20587
[09:35:32] NeroVision | 0 | 57 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 58 | 0 | 30.96 | 17548
[09:35:32] NeroVision | 0 | 59 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 60 | 0 | 56.99 | 28726
[09:35:32] NeroVision | 0 | 61 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 62 | 0 | 85.02 | 54953
[09:35:32] NeroVision | 0 | 63 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 64 | 0 | 20.45 | 9787
[09:35:32] NeroVision | 0 | 65 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 66 | 0 | 34.47 | 17368
[09:35:32] NeroVision | 0 | 67 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 68 | 0 | 275.21 | 145158
[09:35:32] NeroVision | 0 | 69 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 70 | 0 | 173.61 | 97295
[09:35:32] NeroVision | 0 | 71 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 72 | 0 | 219.65 | 133043
[09:35:32] NeroVision | 0 | 73 | 1 | 4.07 | 4199
[09:35:32] NeroVision | 0 | 74 | 0 | 256.69 | 167147
[09:35:32] NeroVision | 0 | 75 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 76 | 0 | 161.09 | 104880
[09:35:32] NeroVision | 0 | 77 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 78 | 0 | 44.98 | 27524
[09:35:32] NeroVision | 0 | 79 | 1 | 4.57 | 4688
[09:35:32] NeroVision | 0 | 80 | 0 | 1764.70 | 152991
[09:35:32] NeroVision | 1 | 0 | 1 | 5882.92 | 1129520
[09:35:32] NeroVision total data size : 3512232440 bytes
[09:35:32] NeroVision multiplexed size : 3647293440 bytes
[09:36:21] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[09:36:21] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[09:36:21] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:36:21] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:36:21] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
[09:36:21] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.48, Interface Version: 4.5.0.0
[09:36:21] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:36:21] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:36:21] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
[09:36:21] DVDEngine ..Application service registered...
[09:36:21] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
[09:36:21] NeroVision Estimate Size
[09:36:21] NeroVision +-------+------+--------+----------+---------
[09:36:21] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[09:36:21] NeroVision | 0 | 0 | 1 | 0.03 | 224
[09:36:21] NeroVision | 1 | 0 | 0 | 0.03 | 0
[09:36:21] NeroVision total data size : 458753 bytes
[09:36:21] NeroVision multiplexed size : 475136 bytes
[09:36:21] NeroVision | 0 | 0 | 0 | 37.47 | 19103
[09:36:21] NeroVision | 0 | 1 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 2 | 0 | 67.50 | 36615
[09:36:21] NeroVision | 0 | 3 | 1 | 4.54 | 4656
[09:36:21] NeroVision | 0 | 4 | 0 | 63.00 | 26586
[09:36:21] NeroVision | 0 | 5 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 6 | 0 | 52.99 | 28248
[09:36:21] NeroVision | 0 | 7 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 8 | 0 | 94.53 | 57455
[09:36:21] NeroVision | 0 | 9 | 1 | 4.07 | 4199
[09:36:21] NeroVision | 0 | 10 | 0 | 169.60 | 87503
[09:36:21] NeroVision | 0 | 11 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 12 | 0 | 24.46 | 16233
[09:36:21] NeroVision | 0 | 13 | 1 | 4.07 | 4199
[09:36:21] NeroVision | 0 | 14 | 0 | 9.44 | 5612
[09:36:21] NeroVision | 0 | 15 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 16 | 0 | 64.50 | 34087
[09:36:21] NeroVision | 0 | 17 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 18 | 0 | 149.08 | 92472
[09:36:21] NeroVision | 0 | 19 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 20 | 0 | 44.98 | 29832
[09:36:21] NeroVision | 0 | 21 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 22 | 0 | 121.55 | 73409
[09:36:21] NeroVision | 0 | 23 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 24 | 0 | 117.55 | 70176
[09:36:21] NeroVision | 0 | 25 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 26 | 0 | 56.49 | 29947
[09:36:21] NeroVision | 0 | 27 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 28 | 0 | 19.95 | 11822
[09:36:21] NeroVision | 0 | 29 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 30 | 0 | 27.46 | 13058
[09:36:21] NeroVision | 0 | 31 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 32 | 0 | 63.00 | 42767
[09:36:21] NeroVision | 0 | 33 | 1 | 4.07 | 4199
[09:36:21] NeroVision | 0 | 34 | 0 | 199.13 | 105725
[09:36:21] NeroVision | 0 | 35 | 1 | 4.07 | 4199
[09:36:21] NeroVision | 0 | 36 | 0 | 77.01 | 51099
[09:36:21] NeroVision | 0 | 37 | 1 | 4.07 | 4199
[09:36:21] NeroVision | 0 | 38 | 0 | 225.16 | 66258
[09:36:21] NeroVision | 0 | 39 | 1 | 4.20 | 4330
[09:36:21] NeroVision | 0 | 40 | 0 | 521.45 | 99172
[09:36:21] NeroVision | 0 | 41 | 1 | 4.54 | 4656
[09:36:21] NeroVision | 0 | 42 | 0 | 116.05 | 21095
[09:36:21] NeroVision | 0 | 43 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 44 | 0 | 27.46 | 16094
[09:36:21] NeroVision | 0 | 45 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 46 | 0 | 84.02 | 42723
[09:36:21] NeroVision | 0 | 47 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 48 | 0 | 23.46 | 9854
[09:36:21] NeroVision | 0 | 49 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 50 | 0 | 7.94 | 4461
[09:36:21] NeroVision | 0 | 51 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 52 | 0 | 33.47 | 19022
[09:36:21] NeroVision | 0 | 53 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 54 | 0 | 45.98 | 29059
[09:36:21] NeroVision | 0 | 55 | 1 | 4.07 | 4199
[09:36:21] NeroVision | 0 | 56 | 0 | 35.47 | 20587
[09:36:21] NeroVision | 0 | 57 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 58 | 0 | 30.96 | 17548
[09:36:21] NeroVision | 0 | 59 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 60 | 0 | 56.99 | 28726
[09:36:21] NeroVision | 0 | 61 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 62 | 0 | 85.02 | 54953
[09:36:21] NeroVision | 0 | 63 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 64 | 0 | 20.45 | 9787
[09:36:21] NeroVision | 0 | 65 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 66 | 0 | 34.47 | 17368
[09:36:21] NeroVision | 0 | 67 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 68 | 0 | 275.21 | 145158
[09:36:21] NeroVision | 0 | 69 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 70 | 0 | 173.61 | 97295
[09:36:21] NeroVision | 0 | 71 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 72 | 0 | 219.65 | 133043
[09:36:21] NeroVision | 0 | 73 | 1 | 4.07 | 4199
[09:36:21] NeroVision | 0 | 74 | 0 | 256.69 | 167147
[09:36:21] NeroVision | 0 | 75 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 76 | 0 | 161.09 | 104880
[09:36:21] NeroVision | 0 | 77 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 78 | 0 | 44.98 | 27524
[09:36:21] NeroVision | 0 | 79 | 1 | 4.57 | 4688
[09:36:21] NeroVision | 0 | 80 | 0 | 1764.70 | 152991
[09:36:21] NeroVision | 1 | 0 | 1 | 5882.92 | 1129520
[09:36:21] NeroVision total data size : 3512232440 bytes
[09:36:21] NeroVision multiplexed size : 3647293440 bytes
[09:36:25] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[09:36:25] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[09:36:25] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:36:25] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:36:25] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
[09:36:25] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.48, Interface Version: 4.5.0.0
[09:36:25] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:36:25] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:36:25] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
[09:36:25] DVDEngine ..Application service registered...
[09:36:25] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
[09:36:25] NeroVision Estimate Size
[09:36:25] NeroVision +-------+------+--------+----------+---------
[09:36:25] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[09:36:25] NeroVision | 0 | 0 | 1 | 0.03 | 224
[09:36:25] NeroVision | 1 | 0 | 0 | 0.03 | 0
[09:36:25] NeroVision total data size : 458753 bytes
[09:36:25] NeroVision multiplexed size : 475136 bytes
[09:36:25] NeroVision | 0 | 0 | 0 | 37.47 | 19103
[09:36:25] NeroVision | 0 | 1 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 2 | 0 | 67.50 | 36615
[09:36:25] NeroVision | 0 | 3 | 1 | 4.54 | 4656
[09:36:25] NeroVision | 0 | 4 | 0 | 63.00 | 26586
[09:36:25] NeroVision | 0 | 5 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 6 | 0 | 52.99 | 28248
[09:36:25] NeroVision | 0 | 7 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 8 | 0 | 94.53 | 57455
[09:36:25] NeroVision | 0 | 9 | 1 | 4.07 | 4199
[09:36:25] NeroVision | 0 | 10 | 0 | 169.60 | 87503
[09:36:25] NeroVision | 0 | 11 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 12 | 0 | 24.46 | 16233
[09:36:25] NeroVision | 0 | 13 | 1 | 4.07 | 4199
[09:36:25] NeroVision | 0 | 14 | 0 | 9.44 | 5612
[09:36:25] NeroVision | 0 | 15 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 16 | 0 | 64.50 | 34087
[09:36:25] NeroVision | 0 | 17 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 18 | 0 | 149.08 | 92472
[09:36:25] NeroVision | 0 | 19 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 20 | 0 | 44.98 | 29832
[09:36:25] NeroVision | 0 | 21 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 22 | 0 | 121.55 | 73409
[09:36:25] NeroVision | 0 | 23 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 24 | 0 | 117.55 | 70176
[09:36:25] NeroVision | 0 | 25 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 26 | 0 | 56.49 | 29947
[09:36:25] NeroVision | 0 | 27 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 28 | 0 | 19.95 | 11822
[09:36:25] NeroVision | 0 | 29 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 30 | 0 | 27.46 | 13058
[09:36:25] NeroVision | 0 | 31 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 32 | 0 | 63.00 | 42767
[09:36:25] NeroVision | 0 | 33 | 1 | 4.07 | 4199
[09:36:25] NeroVision | 0 | 34 | 0 | 199.13 | 105725
[09:36:25] NeroVision | 0 | 35 | 1 | 4.07 | 4199
[09:36:25] NeroVision | 0 | 36 | 0 | 77.01 | 51099
[09:36:25] NeroVision | 0 | 37 | 1 | 4.07 | 4199
[09:36:25] NeroVision | 0 | 38 | 0 | 225.16 | 66258
[09:36:25] NeroVision | 0 | 39 | 1 | 4.20 | 4330
[09:36:25] NeroVision | 0 | 40 | 0 | 521.45 | 99172
[09:36:25] NeroVision | 0 | 41 | 1 | 4.54 | 4656
[09:36:25] NeroVision | 0 | 42 | 0 | 116.05 | 21095
[09:36:25] NeroVision | 0 | 43 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 44 | 0 | 27.46 | 16094
[09:36:25] NeroVision | 0 | 45 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 46 | 0 | 84.02 | 42723
[09:36:25] NeroVision | 0 | 47 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 48 | 0 | 23.46 | 9854
[09:36:25] NeroVision | 0 | 49 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 50 | 0 | 7.94 | 4461
[09:36:25] NeroVision | 0 | 51 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 52 | 0 | 33.47 | 19022
[09:36:25] NeroVision | 0 | 53 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 54 | 0 | 45.98 | 29059
[09:36:25] NeroVision | 0 | 55 | 1 | 4.07 | 4199
[09:36:25] NeroVision | 0 | 56 | 0 | 35.47 | 20587
[09:36:25] NeroVision | 0 | 57 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 58 | 0 | 30.96 | 17548
[09:36:25] NeroVision | 0 | 59 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 60 | 0 | 56.99 | 28726
[09:36:25] NeroVision | 0 | 61 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 62 | 0 | 85.02 | 54953
[09:36:25] NeroVision | 0 | 63 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 64 | 0 | 20.45 | 9787
[09:36:25] NeroVision | 0 | 65 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 66 | 0 | 34.47 | 17368
[09:36:25] NeroVision | 0 | 67 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 68 | 0 | 275.21 | 145158
[09:36:25] NeroVision | 0 | 69 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 70 | 0 | 173.61 | 97295
[09:36:25] NeroVision | 0 | 71 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 72 | 0 | 219.65 | 133043
[09:36:25] NeroVision | 0 | 73 | 1 | 4.07 | 4199
[09:36:25] NeroVision | 0 | 74 | 0 | 256.69 | 167147
[09:36:25] NeroVision | 0 | 75 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 76 | 0 | 161.09 | 104880
[09:36:25] NeroVision | 0 | 77 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 78 | 0 | 44.98 | 27524
[09:36:25] NeroVision | 0 | 79 | 1 | 4.57 | 4688
[09:36:25] NeroVision | 0 | 80 | 0 | 1764.70 | 152991
[09:36:25] NeroVision | 1 | 0 | 1 | 5882.92 | 1129520
[09:36:25] NeroVision total data size : 3512232440 bytes
[09:36:25] NeroVision multiplexed size : 3647293440 bytes
[09:36:26] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[09:36:26] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[09:36:26] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:36:26] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[09:36:26] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
[09:36:26] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.48, Interface Version: 4.5.0.0
[09:36:26] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:36:26] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[09:36:26] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
[09:36:26] DVDEngine ..Application service registered...
[09:36:26] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
[09:36:26] NeroVision Estimate Size
[09:36:26] NeroVision +-------+------+--------+----------+---------
[09:36:26] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[09:36:26] NeroVision | 0 | 0 | 1 | 0.03 | 224
[09:36:26] NeroVision | 1 | 0 | 0 | 0.03 | 0
[09:36:26] NeroVision total data size : 458753 bytes
[09:36:26] NeroVision multiplexed size : 475136 bytes
[09:36:26] NeroVision | 0 | 0 | 0 | 37.47 | 19103
[09:36:26] NeroVision | 0 | 1 | 1 | 4.57 | 4688
[09:36:26] NeroVision | 0 | 2 | 0 | 67.50 | 36615
[09:36:26] NeroVis
seastars
Postby seastars on Sat Nov 25, 2006 3:54 pm
Drat! Okay, here's just the end of the log file; maybe THAT will post:
[10:21:54] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
[10:21:54] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.48, Interface Version: 4.5.0.0
[10:21:54] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[10:21:54] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[10:21:54] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
[10:21:54] DVDEngine ..Application service registered...
[10:21:54] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
[10:21:54] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[10:21:54] DVDEngine ..Session callback registered...
[10:21:54] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[10:21:54] DVDEngine BEGIN: IDVDVideoSessionImpl - Prepare
[10:21:54] DVDEngine **BEGIN: _DVDVideo - Prepare
[10:21:54] DVDEngine ..VTS_Ns=1...
[10:21:54] DVDEngine ****BEGIN: _DVDVideoBase - Prepare VMG
[10:21:54] DVDEngine ...VMGM_VOBS_exist = true
[10:21:54] DVDEngine ******BEGIN: VMGM_VOBS - Process Create
[10:21:54] DVDEngine ********BEGIN: _VOBS - Process VOB
[10:21:54] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[10:21:54] DVDEngine ...Duration 333667
[10:21:54] DVDEngine ..._streamtime_frame_duration is 333667
[10:21:54] DVDEngine ...This is a still stream
[10:21:54] DVDEngine ...Stream 0 is 'Video'
[10:21:54] DVDEngine ...Stream 1 is 'System/Stream'
[10:21:54] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[10:21:54] NeroVision Analyze video stream
[10:21:54] NeroVision Seg. | frames | weight | volume
[10:21:54] NeroVision ------+---------+--------+--------
[10:21:54] NeroVision 0 | 1 | 1 | 1
[10:21:54] NeroVision total : 1
[10:21:54] NeroVision Estimate Size
[10:21:54] NeroVision +-------+------+--------+----------+---------
[10:21:54] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[10:21:54] NeroVision | 0 | 0 | 1 | 0.03 | 224
[10:21:54] NeroVision | 1 | 0 | 0 | 0.03 | 0
[10:21:54] NeroVision total data size : 458753 bytes
[10:21:54] NeroVision multiplexed size : 475136 bytes
[10:21:54] DVDEngine ********END: _VOBS - Process VOB
[10:21:55] NeroVision Estimate Size
[10:21:55] NeroVision +-------+------+--------+----------+---------
[10:21:55] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[10:21:55] NeroVision | 0 | 0 | 1 | 0.03 | 224
[10:21:55] NeroVision | 1 | 0 | 0 | 0.03 | 0
[10:21:55] NeroVision total data size : 458753 bytes
[10:21:55] NeroVision multiplexed size : 475136 bytes
[10:21:55] DVDEngine ********END: _VOBS - Process VOB
[10:21:55] DVDEngine ******END: VMGM_VOBS - Process Create
[10:21:55] DVDEngine ****END: _DVDVideoBase - Prepare VMG
[10:21:55] DVDEngine ****BEGIN: _DVDVideoBase - Prepare VTS#1
[10:21:55] DVDEngine ...VTSM_VOBS_exist = false
[10:21:55] DVDEngine ******BEGIN: VTSTT_VOBS#1 - Process Create
[10:21:55] DVDEngine ********BEGIN: _VOBS - Process VOB
[10:21:55] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[10:21:55] DVDEngine ...Duration 58829162437
[10:21:55] DVDEngine ..._streamtime_frame_duration is 333667
[10:21:55] DVDEngine ...Stream 0 is 'Video'
[10:21:55] DVDEngine ...Stream 1 is 'Audio'
[10:21:55] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[10:21:55] NeroVision Analyze video stream
[10:21:55] NeroVision Seg. | frames | weight | volume
[10:21:55] NeroVision ------+---------+--------+--------
[10:21:55] NeroVision 0 | 1123 | 1 | 1123
[10:21:55] NeroVision 1 | 137 | 1 | 137
[10:21:55] NeroVision 2 | 2023 | 1 | 2023
[10:21:55] NeroVision 3 | 136 | 1 | 136
[10:21:55] NeroVision 4 | 1888 | 1 | 1888
[10:21:55] NeroVision 5 | 137 | 1 | 137
[10:21:55] NeroVision 6 | 1588 | 1 | 1588
[10:21:55] NeroVision 7 | 137 | 1 | 137
[10:21:55] NeroVision 8 | 2833 | 1 | 2833
[10:21:55] NeroVision 9 | 122 | 1 | 122
[10:21:55] NeroVision 10 | 5083 | 1 | 5083
[10:21:55] NeroVision 11 | 137 | 1 | 137
[10:21:55] NeroVision 12 | 733 | 1 | 733
[10:21:55] NeroVision 13 | 122 | 1 | 122
[10:21:55] NeroVision 14 | 2353 | 1 | 2353
[10:21:55] NeroVision 15 | 137 | 1 | 137
[10:21:55] NeroVision 16 | 4468 | 1 | 4468
[10:21:55] NeroVision 17 | 137 | 1 | 137
[10:21:55] NeroVision 18 | 1348 | 1 | 1348
[10:21:55] NeroVision 19 | 137 | 1 | 137
[10:21:55] NeroVision 20 | 3643 | 1 | 3643
[10:21:55] NeroVision 21 | 137 | 1 | 137
[10:21:55] NeroVision 22 | 3523 | 1 | 3523
[10:21:55] NeroVision 23 | 137 | 1 | 137
[10:21:55] NeroVision 24 | 1693 | 1 | 1693
[10:21:55] NeroVision 25 | 137 | 1 | 137
[10:21:55] NeroVision 26 | 598 | 1 | 598
[10:21:55] NeroVision 27 | 137 | 1 | 137
[10:21:55] NeroVision 28 | 823 | 1 | 823
[10:21:55] NeroVision 29 | 137 | 1 | 137
[10:21:55] NeroVision 30 | 1888 | 1 | 1888
[10:21:55] NeroVision 31 | 122 | 1 | 122
[10:21:55] NeroVision 32 | 5968 | 1 | 5968
[10:21:55] NeroVision 33 | 122 | 1 | 122
[10:21:55] NeroVision 34 | 2308 | 1 | 2308
[10:21:55] NeroVision 35 | 122 | 1 | 122
[10:21:55] NeroVision 36 | 6748 | 1 | 6748
[10:21:55] NeroVision 37 | 126 | 1 | 126
[10:21:55] NeroVision 38 | 15628 | 1 | 15628
[10:21:55] NeroVision 39 | 136 | 1 | 136
[10:21:55] NeroVision 40 | 3478 | 1 | 3478
[10:21:55] NeroVision 41 | 137 | 1 | 137
[10:21:55] NeroVision 42 | 823 | 1 | 823
[10:21:55] NeroVision 43 | 137 | 1 | 137
[10:21:55] NeroVision 44 | 2518 | 1 | 2518
[10:21:55] NeroVision 45 | 137 | 1 | 137
[10:21:55] NeroVision 46 | 703 | 1 | 703
[10:21:55] NeroVision 47 | 137 | 1 | 137
[10:21:55] NeroVision 48 | 1378 | 1 | 1378
[10:21:55] NeroVision 49 | 137 | 1 | 137
[10:21:55] NeroVision 50 | 1378 | 1 | 1378
[10:21:55] NeroVision 51 | 122 | 1 | 122
[10:21:55] NeroVision 52 | 1063 | 1 | 1063
[10:21:55] NeroVision 53 | 137 | 1 | 137
[10:21:55] NeroVision 54 | 928 | 1 | 928
[10:21:55] NeroVision 55 | 137 | 1 | 137
[10:21:55] NeroVision 56 | 1708 | 1 | 1708
[10:21:55] NeroVision 57 | 137 | 1 | 137
[10:21:55] NeroVision 58 | 2548 | 1 | 2548
[10:21:55] NeroVision 59 | 137 | 1 | 137
[10:21:55] NeroVision 60 | 613 | 1 | 613
[10:21:55] NeroVision 61 | 137 | 1 | 137
[10:21:55] NeroVision 62 | 9418 | 1 | 9418
[10:21:55] NeroVision 63 | 137 | 1 | 137
[10:21:55] NeroVision 64 | 5203 | 1 | 5203
[10:21:55] NeroVision 65 | 137 | 1 | 137
[10:21:55] NeroVision 66 | 6583 | 1 | 6583
[10:21:55] NeroVision 67 | 122 | 1 | 122
[10:21:55] NeroVision 68 | 7693 | 1 | 7693
[10:21:55] NeroVision 69 | 137 | 1 | 137
[10:21:55] NeroVision 70 | 4828 | 1 | 4828
[10:21:55] NeroVision 71 | 137 | 1 | 137
[10:21:55] NeroVision 72 | 1348 | 1 | 1348
[10:21:55] NeroVision 73 | 137 | 1 | 137
[10:21:55] NeroVision 74 | 52888 | 1 | 52888
[10:21:55] NeroVision total : 176310
[10:21:55] NeroVision | 0 | 0 | 0 | 37.47 | 19103
[10:21:55] NeroVision | 0 | 1 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 2 | 0 | 67.50 | 36615
[10:21:55] NeroVision | 0 | 3 | 1 | 4.54 | 4656
[10:21:55] NeroVision | 0 | 4 | 0 | 63.00 | 26586
[10:21:55] NeroVision | 0 | 5 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 6 | 0 | 52.99 | 28248
[10:21:55] NeroVision | 0 | 7 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 8 | 0 | 94.53 | 57455
[10:21:55] NeroVision | 0 | 9 | 1 | 4.07 | 4199
[10:21:55] NeroVision | 0 | 10 | 0 | 169.60 | 87503
[10:21:55] NeroVision | 0 | 11 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 12 | 0 | 24.46 | 16233
[10:21:55] NeroVision | 0 | 13 | 1 | 4.07 | 4199
[10:21:55] NeroVision | 0 | 14 | 0 | 78.51 | 42651
[10:21:55] NeroVision | 0 | 15 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 16 | 0 | 149.08 | 92472
[10:21:55] NeroVision | 0 | 17 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 18 | 0 | 44.98 | 29832
[10:21:55] NeroVision | 0 | 19 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 20 | 0 | 121.55 | 73409
[10:21:55] NeroVision | 0 | 21 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 22 | 0 | 117.55 | 70176
[10:21:55] NeroVision | 0 | 23 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 24 | 0 | 56.49 | 29947
[10:21:55] NeroVision | 0 | 25 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 26 | 0 | 19.95 | 11822
[10:21:55] NeroVision | 0 | 27 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 28 | 0 | 27.46 | 13058
[10:21:55] NeroVision | 0 | 29 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 30 | 0 | 63.00 | 42767
[10:21:55] NeroVision | 0 | 31 | 1 | 4.07 | 4199
[10:21:55] NeroVision | 0 | 32 | 0 | 199.13 | 105725
[10:21:55] NeroVision | 0 | 33 | 1 | 4.07 | 4199
[10:21:55] NeroVision | 0 | 34 | 0 | 77.01 | 51099
[10:21:55] NeroVision | 0 | 35 | 1 | 4.07 | 4199
[10:21:55] NeroVision | 0 | 36 | 0 | 225.16 | 66258
[10:21:55] NeroVision | 0 | 37 | 1 | 4.20 | 4330
[10:21:55] NeroVision | 0 | 38 | 0 | 521.45 | 99172
[10:21:55] NeroVision | 0 | 39 | 1 | 4.54 | 4656
[10:21:55] NeroVision | 0 | 40 | 0 | 116.05 | 21095
[10:21:55] NeroVision | 0 | 41 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 42 | 0 | 27.46 | 16094
[10:21:55] NeroVision | 0 | 43 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 44 | 0 | 84.02 | 42723
[10:21:55] NeroVision | 0 | 45 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 46 | 0 | 23.46 | 9854
[10:21:55] NeroVision | 0 | 47 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 48 | 0 | 45.98 | 25965
[10:21:55] NeroVision | 0 | 49 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 50 | 0 | 45.98 | 29059
[10:21:55] NeroVision | 0 | 51 | 1 | 4.07 | 4199
[10:21:55] NeroVision | 0 | 52 | 0 | 35.47 | 20587
[10:21:55] NeroVision | 0 | 53 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 54 | 0 | 30.96 | 17548
[10:21:55] NeroVision | 0 | 55 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 56 | 0 | 56.99 | 28726
[10:21:55] NeroVision | 0 | 57 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 58 | 0 | 85.02 | 54953
[10:21:55] NeroVision | 0 | 59 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 60 | 0 | 20.45 | 9787
[10:21:55] NeroVision | 0 | 61 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 62 | 0 | 314.25 | 164710
[10:21:55] NeroVision | 0 | 63 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 64 | 0 | 173.61 | 97295
[10:21:55] NeroVision | 0 | 65 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 66 | 0 | 219.65 | 133043
[10:21:55] NeroVision | 0 | 67 | 1 | 4.07 | 4199
[10:21:55] NeroVision | 0 | 68 | 0 | 256.69 | 167147
[10:21:55] NeroVision | 0 | 69 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 70 | 0 | 161.09 | 104880
[10:21:55] NeroVision | 0 | 71 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 72 | 0 | 44.98 | 27524
[10:21:55] NeroVision | 0 | 73 | 1 | 4.57 | 4688
[10:21:55] NeroVision | 0 | 74 | 0 | 1764.70 | 152991
[10:21:55] NeroVision | 1 | 0 | 1 | 5882.92 | 1129520
[10:21:55] NeroVision total data size : 3505631247 bytes
[10:21:55] NeroVision multiplexed size : 3640573952 bytes
[10:21:56] MMTools SourceBuilder: building cached c:\Documents and Settings\Suzanne\My Documents\My Videos\AV11242006_074525.mpg video/0
[10:21:58] MMTools SourceBuilder: building cached c:\Documents and Settings\Suzanne\My Documents\My Videos\AV11242006_074525.mpg audio/0
[10:22:02] DVDEngine ********END: _VOBS - Process VOB
[10:22:02] DVDEngine ******END: VTSTT_VOBS#1 - Process Create
[10:22:02] DVDEngine ****END: _DVDVideoBase - Prepare VTS#1
[10:22:02] DVDEngine **END: _DVDVideo - Prepare
[10:22:02] DVDEngine ..Estimated size=3.39 GB
[10:22:02] DVDEngine ..Estimated duration=8 min 0 sec
[10:22:02] DVDEngine END: IDVDVideoSessionImpl - Prepare
[10:22:02] DVDEngine BEGIN: IDVDVideoSessionImpl - CreateVOBs
[10:22:02] DVDEngine **BEGIN: _DVDVideo - Create
[10:22:02] DVDEngine ****BEGIN: Create - VMGM_VOBS
[10:22:02] DVDEngine ******BEGIN: VMGM_VOBS - Process Create
[10:22:02] DVDEngine ********BEGIN: _VOBS - Process VOB
[10:22:02] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[10:22:02] DVDEngine ...Duration 333667
[10:22:02] DVDEngine ..._streamtime_frame_duration is 333667
[10:22:02] DVDEngine ...This is a still stream
[10:22:02] DVDEngine ...Stream 0 is 'Video'
[10:22:02] DVDEngine ...Stream 1 is 'System/Stream'
[10:22:02] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[10:22:02] NeroVision Analyze video stream
[10:22:02] NeroVision Seg. | frames | weight | volume
[10:22:02] NeroVision ------+---------+--------+--------
[10:22:02] NeroVision 0 | 1 | 1 | 1
[10:22:02] NeroVision total : 1
[10:22:02] NeroVision Estimate Size
[10:22:02] NeroVision +-------+------+--------+----------+---------
[10:22:02] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[10:22:02] NeroVision | 0 | 0 | 1 | 0.03 | 224
[10:22:02] NeroVision | 1 | 0 | 0 | 0.03 | 0
[10:22:02] NeroVision total data size : 458753 bytes
[10:22:02] NeroVision multiplexed size : 475136 bytes
[10:22:02] DVDEngine ...estimated VOB size is 240 sectors (480 KB).
[10:22:02] DVDEngine **********BEGIN: IDVDEngineManagerImpl - CreateSubpictureSource
[10:22:02] DVDEngine **********END: IDVDEngineManagerImpl - CreateSubpictureSource
[10:22:02] DVDEngine **********BEGIN: CSPU::Process()
[10:22:02] DVDEngine ...'Decoding SubPicture No.' is '0'
[10:22:02] DVDEngine ..._nLines == 480
[10:22:02] DVDEngine ...Found 'bottom half' in the bottom field at bit 12920, addr. is 1615 (241)
[10:22:02] DVDEngine ...Detected 'top half' at 1, addr. is 2
[10:22:02] DVDEngine ...Detected 'bottom half' at 1, addr. is 1615
[10:22:02] DVDEngine ...Lines processed: 480
[10:22:02] DVDEngine ...processed 2 packs
[10:22:02] DVDEngine **********END: CSPU::Process()
[10:22:02] DVDEngine ...New VOB 1
[10:22:02] DVDEngine ..+VOB#1: VOB_IDN=1, SA=0, VOB_V_S_PTM=36181
[10:22:02] DVDEngine ...New CELL 1
[10:22:02] DVDEngine ....+Cell#1: C_IDN=1
[10:22:02] DVDEngine BTNGR1_DSP_TY == 126219358
[10:22:02] DVDEngine ....|Cell#1: C_IDN=1, [0;72], VOBU_Ns=1, C_PBTM=00s.12
[10:22:02] DVDEngine ..|VOB#1: VOB_IDN=1, [0;72], C_Ns=1, VOB_V_S_PTM=36181, VOB_V_E_PTM=72217
[10:22:03] DVDEngine ...actual VOB size is 73 sectors (146 KB).
[10:22:03] DVDEngine ********END: _VOBS - Process VOB
[10:22:03] DVDEngine ********BEGIN: _VOBS - Process VOB
[10:22:03] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[10:22:03] DVDEngine ...Duration 333667
[10:22:03] DVDEngine ..._streamtime_frame_duration is 333667
[10:22:03] DVDEngine ...This is a still stream
[10:22:03] DVDEngine ...Stream 0 is 'Video'
[10:22:03] DVDEngine ...Stream 1 is 'System/Stream'
[10:22:03] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[10:22:03] NeroVision Analyze video stream
[10:22:03] NeroVision Seg. | frames | weight | volume
[10:22:03] NeroVision ------+---------+--------+--------
[10:22:03] NeroVision 0 | 1 | 1 | 1
[10:22:03] NeroVision total : 1
[10:22:03] NeroVision Estimate Size
[10:22:03] NeroVision +-------+------+--------+----------+---------
[10:22:03] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[10:22:03] NeroVision | 0 | 0 | 1 | 0.03 | 224
[10:22:03] NeroVision | 1 | 0 | 0 | 0.03 | 0
[10:22:03] NeroVision total data size : 458753 bytes
[10:22:03] NeroVision multiplexed size : 475136 bytes
[10:22:03] DVDEngine ...estimated VOB size is 240 sectors (480 KB).
[10:22:03] DVDEngine **********BEGIN: IDVDEngineManagerImpl - CreateSubpictureSource
[10:22:03] DVDEngine **********END: IDVDEngineManagerImpl - CreateSubpictureSource
[10:22:03] DVDEngine **********BEGIN: CSPU::Process()
[10:22:03] DVDEngine ...'Decoding SubPicture No.' is '0'
[10:22:03] DVDEngine ..._nLines == 480
[10:22:03] DVDEngine ...Found 'bottom half' in the bottom field at bit 13496, addr. is 1687 (241)
[10:22:03] DVDEngine ...Detected 'top half' at 1, addr. is 2
[10:22:03] DVDEngine ...Detected 'bottom half' at 1, addr. is 1687
[10:22:03] DVDEngine ...Lines processed: 480
[10:22:03] DVDEngine ...processed 2 packs
[10:22:03] DVDEngine **********END: CSPU::Process()
[10:22:03] DVDEngine ...New VOB 1
[10:22:03] DVDEngine ..+VOB#2: VOB_IDN=2, SA=73, VOB_V_S_PTM=35889
[10:22:03] DVDEngine ...New CELL 1
[10:22:03] DVDEngine ....+Cell#1: C_IDN=1
[10:22:03] DVDEngine BTNGR1_DSP_TY == 126219358
[10:22:03] DVDEngine ....|Cell#1: C_IDN=1, [73;143], VOBU_Ns=1, C_PBTM=00s.12
[10:22:03] DVDEngine ..|VOB#2: VOB_IDN=2, [73;143], C_Ns=1, VOB_V_S_PTM=35889, VOB_V_E_PTM=71925
[10:22:03] DVDEngine ...actual VOB size is 71 sectors (142 KB).
[10:22:03] MMTools SourceBuilder: building cached c:\Documents and Settings\Suzanne\My Documents\My Videos\Movie 5\AV04232006_070746.mpg video/0
[10:22:14] MMTools BitmapGrabber::InternalGetBitmap - failed to get sample (timeout)
[10:22:14] MMTools BitmapGrabber::InternalGetBitmap - error handler (begin stop graph)
[10:22:17] MMTools BitmapGrabber::InternalGetBitmap - error handler (end stop graph)
[10:22:22] DVDEngine **********BEGIN: IDVDEngineManagerImpl - CreateSubpictureSource
[10:22:22] DVDEngine **********END: IDVDEngineManagerImpl - CreateSubpictureSource
[10:22:22] DVDEngine **********BEGIN: CSPU::Process()
[10:22:22] DVDEngine ...'Decoding SubPicture No.' is '0'
[10:22:22] DVDEngine ..._nLines == 480
[10:22:22] DVDEngine ...Found 'bottom half' in the bottom field at bit 13496, addr. is 1687 (241)
[10:22:22] DVDEngine ...Detected 'top half' at 1, addr. is 2
[10:22:22] DVDEngine ...Detected 'bottom half' at 1, addr. is 1687
[10:22:22] DVDEngine ...Lines processed: 480
[10:22:22] DVDEngine ...processed 2 packs
[10:22:22] DVDEngine **********END: CSPU::Process()
[10:22:22] DVDEngine ...New VOB 1
[10:22:22] DVDEngine ..+VOB#3: VOB_IDN=3, SA=144, VOB_V_S_PTM=36328
[10:22:22] DVDEngine ...New CELL 1
[10:22:22] DVDEngine ....+Cell#1: C_IDN=1
[10:22:22] DVDEngine BTNGR1_DSP_TY == 126219358
[10:22:22] DVDEngine ....|Cell#1: C_IDN=1, [144;217], VOBU_Ns=1, C_PBTM=00s.12
[10:22:22] DVDEngine ..|VOB#3: VOB_IDN=3, [144;217], C_Ns=1, VOB_V_S_PTM=36328, VOB_V_E_PTM=72364
[10:22:22] DVDEngine ...actual VOB size is 74 sectors (148 KB).
[10:22:22] DVDEngine ********END: _VOBS - Process VOB
[10:22:22] DVDEngine ********BEGIN: _VOBS - Process VOB
[10:22:22] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[10:22:22] DVDEngine ...Duration 333667
[10:22:22] DVDEngine ..._streamtime_frame_duration is 333667
[10:22:22] DVDEngine ...This is a still stream
[10:22:22] DVDEngine ...Stream 0 is 'Video'
[10:22:22] DVDEngine ...Stream 1 is 'System/Stream'
[10:22:22] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[10:22:22] NeroVision Analyze video stream
[10:22:22] NeroVision Seg. | frames | weight | volume
[10:22:22] NeroVision ------+---------+--------+--------
[10:22:22] NeroVision 0 | 1 | 1 | 1
[10:22:22] NeroVision total : 1
[10:22:22] NeroVision Estimate Size
[10:22:22] NeroVision +-------+------+--------+----------+---------
[10:22:22] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[10:22:22] NeroVision | 0 | 0 | 1 | 0.03 | 224
[10:22:22] NeroVision | 1 | 0 | 0 | 0.03 | 0
[10:22:22] NeroVision total data size : 458753 bytes
[10:22:22] NeroVision multiplexed size : 475136 bytes
[10:22:22] DVDEngine ...estimated VOB size is 240 sectors (480 KB).
[10:22:22] MMTools SourceBuilder: building cached c:\Documents and Settings\Suzanne\My Documents\My Videos\Movie 5\AV04262006_074445.mpg video/0
[10:22:31] DVDEngine **********BEGIN: IDVDEngineManagerImpl - CreateSubpictureSource
[10:22:31] DVDEngine **********END: IDVDEngineManagerImpl - CreateSubpictureSource
[10:22:31] DVDEngine **********BEGIN: CSPU::Process()
[10:22:31] DVDEngine ...'Decoding SubPicture No.' is '0'
[10:22:31] DVDEngine ..._nLines == 480
[10:22:31] DVDEngine ...Found 'bottom half' in the bottom field at bit 13496, addr. is 1687 (241)
[10:22:31] DVDEngine ...Detected 'top half' at 1, addr. is 2
[10:22:31] DVDEngine ...Detected 'bottom half' at 1, addr. is 1687
[10:22:31] DVDEngine ...Lines processed: 480
[10:22:31] DVDEngine ...processed 2 packs
[10:22:31] DVDEngine **********END: CSPU::Process()
[10:22:31] DVDEngine ...New VOB 1
[10:22:31] DVDEngine ..+VOB#4: VOB_IDN=4, SA=218, VOB_V_S_PTM=36474
[10:22:31] DVDEngine ...New CELL 1
[10:22:31] DVDEngine ....+Cell#1: C_IDN=1
[10:22:31] DVDEngine BTNGR1_DSP_TY == 126219358
[10:22:31] DVDEngine ....|Cell#1: C_IDN=1, [218;292], VOBU_Ns=1, C_PBTM=00s.12
[10:22:31] DVDEngine ..|VOB#4: VOB_IDN=4, [218;292], C_Ns=1, VOB_V_S_PTM=36474, VOB_V_E_PTM=72510
[10:22:31] DVDEngine ...actual VOB size is 75 sectors (150 KB).
[10:22:31] DVDEngine ********END: _VOBS - Process VOB
[10:22:31] DVDEngine ********BEGIN: _VOBS - Process VOB
[10:22:31] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[10:22:31] DVDEngine ...Duration 333667
[10:22:31] DVDEngine ..._streamtime_frame_duration is 333667
[10:22:31] DVDEngine ...This is a still stream
[10:22:31] DVDEngine ...Stream 0 is 'Video'
[10:22:31] DVDEngine ...Stream 1 is 'System/Stream'
[10:22:31] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[10:22:31] NeroVision Analyze video stream
[10:22:31] NeroVision Seg. | frames | weight | volume
[10:22:31] NeroVision ------+---------+--------+--------
[10:22:31] NeroVision 0 | 1 | 1 | 1
[10:22:31] NeroVision total : 1
[10:22:31] NeroVision Estimate Size
[10:22:31] NeroVision +-------+------+--------+----------+---------
[10:22:31] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[10:22:31] NeroVision | 0 | 0 | 1 | 0.03 | 224
[10:22:31] NeroVision | 1 | 0 | 0 | 0.03 | 0
[10:22:31] NeroVision total data size : 458753 bytes
[10:22:31] NeroVision multiplexed size : 475136 bytes
[10:22:31] DVDEngine ...estimated VOB size is 240 sectors (480 KB).
[10:22:46] DVDEngine **********BEGIN: IDVDEngineManagerImpl - CreateSubpictureSource
[10:22:46] DVDEngine **********END: IDVDEngineManagerImpl - CreateSubpictureSource
[10:22:46] DVDEngine **********BEGIN: CSPU::Process()
[10:22:46] DVDEngine ...'Decoding SubPicture No.' is '0'
[10:22:46] DVDEngine ..._nLines == 480
[10:22:46] DVDEngine ...Found 'bottom half' in the bottom field at bit 13496, addr. is 1687 (241)
[10:22:46] DVDEngine ...Detected 'top half' at 1, addr. is 2
[10:22:46] DVDEngine ...Detected 'bottom half' at 1, addr. is 1687
[10:22:46] DVDEngine ...Lines processed: 480
[10:22:46] DVDEngine ...processed 2 packs
[10:22:46] DVDEngine **********END: CSPU::Process()
[10:22:46] DVDEngine ...New VOB 1
[10:22:46] DVDEngine ..+VOB#5: VOB_IDN=5, SA=293, VOB_V_S_PTM=36328
[10:22:46] DVDEngine ...New CELL 1
[10:22:46] DVDEngine ....+Cell#1: C_IDN=1
[10:22:46] DVDEngine BTNGR1_DSP_TY == 126219358
[10:22:46] DVDEngine ....|Cell#1: C_IDN=1, [293;366], VOBU_Ns=1, C_PBTM=00s.12
[10:22:46] DVDEngine ..|VOB#5: VOB_IDN=5, [293;366], C_Ns=1, VOB_V_S_PTM=36328, VOB_V_E_PTM=72364
[10:22:46] DVDEngine ...actual VOB size is 74 sectors (148 KB).
[10:22:46] DVDEngine ********END: _VOBS - Process VOB
[10:22:46] DVDEngine ********BEGIN: _VOBS - Process VOB
[10:22:46] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[10:22:46] DVDEngine ...Duration 333667
[10:22:46] DVDEngine ..._streamtime_frame_duration is 333667
[10:22:46] DVDEngine ...This is a still stream
[10:22:46] DVDEngine ...Stream 0 is 'Video'
[10:22:46] DVDEngine ...Stream 1 is 'System/Stream'
[10:22:46] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[10:22:46] NeroVision Analyze video stream
[10:22:46] NeroVision Seg. | frames | weight | volume
[10:22:46] NeroVision ------+---------+--------+--------
[10:22:46] NeroVision 0 | 1 | 1 | 1
[10:22:46] NeroVision total : 1
[10:22:46] NeroVision Estimate Size
[10:22:46] NeroVision +-------+------+--------+----------+---------
[10:22:46] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[10:22:46] NeroVision | 0 | 0 | 1 | 0.03 | 224
[10:22:46] NeroVision | 1 | 0 | 0 | 0.03 | 0
[10:22:46] NeroVision total data size : 458753 bytes
[10:22:46] NeroVision multiplexed size : 475136 bytes
[10:22:46] DVDEngine ...estimated VOB size is 240 sectors (480 KB).
[10:23:07] DVDEngine **********BEGIN: IDVDEngineManagerImpl - CreateSubpictureSource
[10:23:07] DVDEngine **********END: IDVDEngineManagerImpl - CreateSubpictureSource
[10:23:07] DVDEngine **********BEGIN: CSPU::Process()
[10:23:07] DVDEngine ...'Decoding SubPicture No.' is '0'
[10:23:07] DVDEngine ..._nLines == 480
[10:23:07] DVDEngine ...Found 'bottom half' in the bottom field at bit 12256, addr. is 1532 (241)
[10:23:07] DVDEngine ...Detected 'top half' at 1, addr. is 2
[10:23:07] DVDEngine ...Detected 'bottom half' at 1, addr. is 1532
[10:23:07] DVDEngine ...Lines processed: 480
[10:23:07] DVDEngine ...processed 2 packs
[10:23:07] DVDEngine **********END: CSPU::Process()
[10:23:07] DVDEngine ...New VOB 1
[10:23:07] DVDEngine ..+VOB#6: VOB_IDN=6, SA=367, VOB_V_S_PTM=36035
[10:23:07] DVDEngine ...New CELL 1
[10:23:07] DVDEngine ....+Cell#1: C_IDN=1
[10:23:07] DVDEngine BTNGR1_DSP_TY == 126219358
[10:23:07] DVDEngine ....|Cell#1: C_IDN=1, [367;438], VOBU_Ns=1, C_PBTM=00s.12
[10:23:07] DVDEngine ..|VOB#6: VOB_IDN=6, [367;438], C_Ns=1, VOB_V_S_PTM=36035, VOB_V_E_PTM=72071
[10:23:07] DVDEngine ...actual VOB size is 72 sectors (144 KB).
[10:23:07] DVDEngine ********END: _VOBS - Process VOB
[10:23:07] DVDEngine ********BEGIN: VMGM_VOBS - INFORMATION after Create
[10:23:07] DVDEngine ----------------------------------------------------------------------------------------
[10:23:07] DVDEngine General information:
[10:23:07] DVDEngine ..size=439 (878 KB)
[10:23:07] DVDEngine ..capacity=439 (878 KB)
[10:23:07] DVDEngine ..max_capacity=524287 (1.00 GB)
[10:23:07] DVDEngine ..VOB_Ns=6
[10:23:07] DVDEngine ..C_Ns=6
[10:23:07] DVDEngine ..VOBU_Ns=6
[10:23:07] DVDEngine VOB information:
[10:23:07] DVDEngine ...VOB#1: VOB_IDN=1, [0;72], C_Ns=1, VOB_V_S_PTM=36181, VOB_V_E_PTM=72217
[10:23:07] DVDEngine .....Cell#1: C_IDN=1, [0;72], VOBU_Ns=1, C_PBTM=00s.12
[10:23:07] DVDEngine ...VOB#2: VOB_IDN=2, [73;143], C_Ns=1, VOB_V_S_PTM=35889, VOB_V_E_PTM=71925
[10:23:07] DVDEngine .....Cell#1: C_IDN=1, [73;143], VOBU_Ns=1, C_PBTM=00s.12
[10:23:07] DVDEngine ...VOB#3: VOB_IDN=3, [144;217], C_Ns=1, VOB_V_S_PTM=36328, VOB_V_E_PTM=72364
[10:23:07] DVDEngine .....Cell#1: C_IDN=1, [144;217], VOBU_Ns=1, C_PBTM=00s.12
[10:23:07] DVDEngine ...VOB#4: VOB_IDN=4, [218;292], C_Ns=1, VOB_V_S_PTM=36474, VOB_V_E_PTM=72510
[10:23:07] DVDEngine .....Cell#1: C_IDN=1, [218;292], VOBU_Ns=1, C_PBTM=00s.12
[10:23:07] DVDEngine ...VOB#5: VOB_IDN=5, [293;366], C_Ns=1, VOB_V_S_PTM=36328, VOB_V_E_PTM=72364
[10:23:07] DVDEngine .....Cell#1: C_IDN=1, [293;366], VOBU_Ns=1, C_PBTM=00s.12
[10:23:07] DVDEngine ...VOB#6: VOB_IDN=6, [367;438], C_Ns=1, VOB_V_S_PTM=36035, VOB_V_E_PTM=72071
[10:23:07] DVDEngine .....Cell#1: C_IDN=1, [367;438], VOBU_Ns=1, C_PBTM=00s.12
[10:23:07] DVDEngine ********END: VMGM_VOBS - INFORMATION after Create
[10:23:07] DVDEngine ******END: VMGM_VOBS - Process Create
[10:23:07] DVDEngine ******BEGIN: VMGM_VOBS - Verify
[10:23:07] DVDEngine ******END: VMGM_VOBS - Verify
[10:23:07] DVDEngine ..VMGM_VOBS: size=878 KB (899,072 bytes)
[10:23:07] DVDEngine ****END: Create - VMGM_VOBS
[10:23:07] DVDEngine ****BEGIN: Create - VTSTT_VOBS#1
[10:23:07] DVDEngine ******BEGIN: VTSTT_VOBS#1 - Process Create
[10:23:07] DVDEngine ********BEGIN: _VOBS - Process VOB
[10:23:07] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[10:23:07] DVDEngine ...Duration 58829162437
[10:23:07] DVDEngine ..._streamtime_frame_duration is 333667
[10:23:07] DVDEngine ...Stream 0 is 'Video'
[10:23:07] DVDEngine ...Stream 1 is 'Audio'
[10:23:07] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[10:23:07] NeroVision Analyze video stream
[10:23:07] NeroVision Seg. | frames | weight | volume
[10:23:07] NeroVision ------+---------+--------+--------
[10:23:07] NeroVision 0 | 1123 | 1 | 1123
[10:23:07] NeroVision 1 | 137 | 1 | 137
[10:23:07] NeroVision 2 | 2023 | 1 | 2023
[10:23:07] NeroVision 3 | 136 | 1 | 136
[10:23:07] NeroVision 4 | 1888 | 1 | 1888
[10:23:07] NeroVision 5 | 137 | 1 | 137
[10:23:07] NeroVision 6 | 1588 | 1 | 1588
[10:23:07] NeroVision 7 | 137 | 1 | 137
[10:23:07] NeroVision 8 | 2833 | 1 | 2833
[10:23:07] NeroVision 9 | 122 | 1 | 122
[10:23:07] NeroVision 10 | 5083 | 1 | 5083
[10:23:07] NeroVision 11 | 137 | 1 | 137
[10:23:07] NeroVision 12 | 733 | 1 | 733
[10:23:07] NeroVision 13 | 122 | 1 | 122
[10:23:07] NeroVision 14 | 2353 | 1 | 2353
[10:23:07] NeroVision 15 | 137 | 1 | 137
[10:23:07] NeroVision 16 | 4468 | 1 | 4468
[10:23:07] NeroVision 17 | 137 | 1 | 137
[10:23:07] NeroVision 18 | 1348 | 1 | 1348
[10:23:07] NeroVision 19 | 137 | 1 | 137
[10:23:07] NeroVision 20 | 3643 | 1 | 3643
[10:23:07] NeroVision 21 | 137 | 1 | 137
[10:23:07] NeroVision 22 | 3523 | 1 | 3523
[10:23:07] NeroVision 23 | 137 | 1 | 137
[10:23:07] NeroVision 24 | 1693 | 1 | 1693
[10:23:07] NeroVision 25 | 137 | 1 | 137
[10:23:07] NeroVision 26 | 598 | 1 | 598
[10:23:07] NeroVision 27 | 137 | 1 | 137
[10:23:07] NeroVision 28 | 823 | 1 | 823
[10:23:07] NeroVision 29 | 137 | 1 | 137
[10:23:07] NeroVision 30 | 1888 | 1 | 1888
[10:23:07] NeroVision 31 | 122 | 1 | 122
[10:23:07] NeroVision 32 | 5968 | 1 | 5968
[10:23:07] NeroVision 33 | 122 | 1 | 122
[10:23:07] NeroVision 34 | 2308 | 1 | 2308
[10:23:07] NeroVision 35 | 122 | 1 | 122
[10:23:07] NeroVision 36 | 6748 | 1 | 6748
[10:23:07] NeroVision 37 | 126 | 1 | 126
[10:23:07] NeroVision 38 | 15628 | 1 | 15628
[10:23:07] NeroVision 39 | 136 | 1 | 136
[10:23:07] NeroVision 40 | 3478 | 1 | 3478
[10:23:07] NeroVision 41 | 137 | 1 | 137
[10:23:07] NeroVision 42 | 823 | 1 | 823
[10:23:07] NeroVision 43 | 137 | 1 | 137
[10:23:07] NeroVision 44 | 2518 | 1 | 2518
[10:23:07] NeroVision 45 | 137 | 1 | 137
[10:23:07] NeroVision 46 | 703 | 1 | 703
[10:23:07] NeroVision 47 | 137 | 1 | 137
[10:23:07] NeroVision 48 | 1378 | 1 | 1378
[10:23:07] NeroVision 49 | 137 | 1 | 137
[10:23:07] NeroVision 50 | 1378 | 1 | 1378
[10:23:07] NeroVision 51 | 122 | 1 | 122
[10:23:07] NeroVision 52 | 1063 | 1 | 1063
[10:23:07] NeroVision 53 | 137 | 1 | 137
[10:23:07] NeroVision 54 | 928 | 1 | 928
[10:23:07] NeroVision 55 | 137 | 1 | 137
[10:23:07] NeroVision 56 | 1708 | 1 | 1708
[10:23:07] NeroVision 57 | 137 | 1 | 137
[10:23:07] NeroVision 58 | 2548 | 1 | 2548
[10:23:07] NeroVision 59 | 137 | 1 | 137
[10:23:07] NeroVision 60 | 613 | 1 | 613
[10:23:07] NeroVision 61 | 137 | 1 | 137
[10:23:07] NeroVision 62 | 9418 | 1 | 9418
[10:23:07] NeroVision 63 | 137 | 1 | 137
[10:23:07] NeroVision 64 | 5203 | 1 | 5203
[10:23:07] NeroVision 65 | 137 | 1 | 137
[10:23:07] NeroVision 66 | 6583 | 1 | 6583
[10:23:07] NeroVision 67 | 122 | 1 | 122
[10:23:07] NeroVision 68 | 7693 | 1 | 7693
[10:23:07] NeroVision 69 | 137 | 1 | 137
[10:23:07] NeroVision 70 | 4828 | 1 | 4828
[10:23:07] NeroVision 71 | 137 | 1 | 137
[10:23:07] NeroVision 72 | 1348 | 1 | 1348
[10:23:07] NeroVision 73 | 137 | 1 | 137
[10:23:07] NeroVision 74 | 52888 | 1 | 52888
[10:23:07] NeroVision total : 176310
[10:23:08] NeroVision Estimate Size
[10:23:08] NeroVision +-------+------+--------+----------+---------
[10:23:08] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[10:23:08] NeroVision | 0 | 0 | 0 | 37.47 | 19103
[10:23:08] NeroVision | 0 | 1 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 2 | 0 | 67.50 | 36615
[10:23:08] NeroVision | 0 | 3 | 1 | 4.54 | 4656
[10:23:08] NeroVision | 0 | 4 | 0 | 63.00 | 26586
[10:23:08] NeroVision | 0 | 5 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 6 | 0 | 52.99 | 28248
[10:23:08] NeroVision | 0 | 7 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 8 | 0 | 94.53 | 57455
[10:23:08] NeroVision | 0 | 9 | 1 | 4.07 | 4199
[10:23:08] NeroVision | 0 | 10 | 0 | 169.60 | 87503
[10:23:08] NeroVision | 0 | 11 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 12 | 0 | 24.46 | 16233
[10:23:08] NeroVision | 0 | 13 | 1 | 4.07 | 4199
[10:23:08] NeroVision | 0 | 14 | 0 | 78.51 | 42651
[10:23:08] NeroVision | 0 | 15 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 16 | 0 | 149.08 | 92472
[10:23:08] NeroVision | 0 | 17 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 18 | 0 | 44.98 | 29832
[10:23:08] NeroVision | 0 | 19 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 20 | 0 | 121.55 | 73409
[10:23:08] NeroVision | 0 | 21 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 22 | 0 | 117.55 | 70176
[10:23:08] NeroVision | 0 | 23 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 24 | 0 | 56.49 | 29947
[10:23:08] NeroVision | 0 | 25 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 26 | 0 | 19.95 | 11822
[10:23:08] NeroVision | 0 | 27 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 28 | 0 | 27.46 | 13058
[10:23:08] NeroVision | 0 | 29 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 30 | 0 | 63.00 | 42767
[10:23:08] NeroVision | 0 | 31 | 1 | 4.07 | 4199
[10:23:08] NeroVision | 0 | 32 | 0 | 199.13 | 105725
[10:23:08] NeroVision | 0 | 33 | 1 | 4.07 | 4199
[10:23:08] NeroVision | 0 | 34 | 0 | 77.01 | 51099
[10:23:08] NeroVision | 0 | 35 | 1 | 4.07 | 4199
[10:23:08] NeroVision | 0 | 36 | 0 | 225.16 | 66258
[10:23:08] NeroVision | 0 | 37 | 1 | 4.20 | 4330
[10:23:08] NeroVision | 0 | 38 | 0 | 521.45 | 99172
[10:23:08] NeroVision | 0 | 39 | 1 | 4.54 | 4656
[10:23:08] NeroVision | 0 | 40 | 0 | 116.05 | 21095
[10:23:08] NeroVision | 0 | 41 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 42 | 0 | 27.46 | 16094
[10:23:08] NeroVision | 0 | 43 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 44 | 0 | 84.02 | 42723
[10:23:08] NeroVision | 0 | 45 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 46 | 0 | 23.46 | 9854
[10:23:08] NeroVision | 0 | 47 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 48 | 0 | 45.98 | 25965
[10:23:08] NeroVision | 0 | 49 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 50 | 0 | 45.98 | 29059
[10:23:08] NeroVision | 0 | 51 | 1 | 4.07 | 4199
[10:23:08] NeroVision | 0 | 52 | 0 | 35.47 | 20587
[10:23:08] NeroVision | 0 | 53 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 54 | 0 | 30.96 | 17548
[10:23:08] NeroVision | 0 | 55 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 56 | 0 | 56.99 | 28726
[10:23:08] NeroVision | 0 | 57 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 58 | 0 | 85.02 | 54953
[10:23:08] NeroVision | 0 | 59 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 60 | 0 | 20.45 | 9787
[10:23:08] NeroVision | 0 | 61 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 62 | 0 | 314.25 | 164710
[10:23:08] NeroVision | 0 | 63 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 64 | 0 | 173.61 | 97295
[10:23:08] NeroVision | 0 | 65 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 66 | 0 | 219.65 | 133043
[10:23:08] NeroVision | 0 | 67 | 1 | 4.07 | 4199
[10:23:08] NeroVision | 0 | 68 | 0 | 256.69 | 167147
[10:23:08] NeroVision | 0 | 69 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 70 | 0 | 161.09 | 104880
[10:23:08] NeroVision | 0 | 71 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 72 | 0 | 44.98 | 27524
[10:23:08] NeroVision | 0 | 73 | 1 | 4.57 | 4688
[10:23:08] NeroVision | 0 | 74 | 0 | 1764.70 | 152991
[10:23:08] NeroVision | 1 | 0 | 1 | 5882.92 | 1129520
[10:23:08] NeroVision total data size : 3505631247 bytes
[10:23:08] NeroVision multiplexed size : 3640573952 bytes
[10:23:08] DVDEngine ...estimated VOB size is 1777632 sectors (3.39 GB).
[10:23:08] NeroVision Set Preview Channel
[10:23:08] MMTools SourceBuilder: building cached c:\Documents and Settings\Suzanne\My Documents\My Videos\AV11242006_074525.mpg audio/0
[10:23:09] DVDEngine ...New VOB 1
[10:23:09] DVDEngine ..+VOB#1: VOB_IDN=1, SA=0, VOB_V_S_PTM=29452
[10:23:09] DVDEngine ...New CELL 1
[10:23:09] DVDEngine ....+Cell#1: C_IDN=1
[10:23:10] MMTools SourceBuilder: building cached c:\Documents and Settings\Suzanne\My Documents\My Videos\AV11242006_074525.mpg video/0
[10:23:13] DVDEngine ...New CELL 2
[10:23:13] DVDEngine ....|Cell#1: C_IDN=1, [0;14470], VOBU_Ns=79, C_PBTM=39s.22
[10:23:13] DVDEngine ....+Cell#2: C_IDN=2
[10:23:21] MMTools SourceBuilder: building cached c:\Documents and Settings\Suzanne\My Documents\My Videos\Movie 5\AV04232006_070746.mpg video/0
[10:23:21] MMTools SourceBuilder: building cached c:\Documents and Settings\Suzanne\My Documents\My Videos\Movie 5\AV04232006_070746.mpg audio/0
[10:23:36] DVDEngine ...New CELL 3
[10:23:36] DVDEngine ....|Cell#2: C_IDN=2, [14471;68566], VOBU_Ns=279, C_PBTM=02m19s.13
[10:23:36] DVDEngine ....+Cell#3: C_IDN=3
[10:23:53] DVDEngine ...New CELL 4
[10:23:53] DVDEngine ....|Cell#3: C_IDN=3, [68567;95692], VOBU_Ns=116, C_PBTM=57s.17
[10:23:53] DVDEngine ....+Cell#4: C_IDN=4
[10:23:58] DVDEngine ********END: _VOBS - Process VOB
[10:23:58] DVDEngine ******END: VTSTT_VOBS#1 - Process Create
[10:23:58] DVDEngine ****END: Create - VTSTT_VOBS#1
[10:23:58] DVDEngine **END: _DVDVideo - Create
[10:23:58] DVDEngine ########################################################################################
[10:23:58] DVDEngine ERROR
[10:23:58] DVDEngine cause: 128 (nmc_processing_exception)
[10:23:58] DVDEngine source: CDVDProcessor::ProcessSector
[10:23:58] DVDEngine description: buffer overflow
[10:23:58] DVDEngine END: IDVDVideoSessionImpl - CreateVOBs
[10:23:58] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[10:23:58] DVDEngine ..Session callback unregistered...
[10:23:58] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[10:23:58] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[10:23:58] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[10:23:58] NeroVision Process information:
[10:23:58] NeroVision --------------------
[10:23:58] NeroVision Address Version Module name
[10:23:58] NeroVision -----------------------------------------------------
[10:23:58] NeroVision 0x00330000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\GCCore.dll
[10:23:58] NeroVision 0x003C0000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\AMCDOM.dll
[10:23:58] NeroVision 0x003D0000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\GDIPainter.dll
[10:23:58] NeroVision 0x00400000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\NeroVision.exe
[10:23:58] NeroVision 0x00480000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\GCLib.dll
[10:23:58] NeroVision 0x00510000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\AMCDocBase.dll
[10:23:58] NeroVision 0x00700000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\MMTools.dll
[10:23:58] NeroVision 0x00770000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\AMCUIBase.dll
[10:23:58] NeroVision 0x009A0000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\AMCLib.dll
[10:23:58] NeroVision 0x01360000 7.0.46.0 C:\WINDOWS\system32\ImagXpr7.dll
[10:23:58] NeroVision 0x013E0000 7.0.46.0 C:\WINDOWS\system32\ImagX7.dll
[10:23:58] NeroVision 0x015C0000 7.0.476.0 C:\WINDOWS\system32\ImagXR7.dll
[10:23:58] NeroVision 0x017A0000 6.0.5441.0 C:\WINDOWS\system32\Normaliz.dll
[10:23:58] NeroVision 0x017D0000 2.3.15.2 C:\Program Files\Common Files\Ahead\Lib\ShellManager.dll
[10:23:58] NeroVision 0x018B0000 3.15.2.6900 C:\Program Files\Common Files\Ahead\Lib\AdvrCntr2.dll
[10:23:58] NeroVision 0x02390000 1.2.0.13 C:\Program Files\Common Files\Ahead\Lib\NeroFileDialog.dll
[10:23:58] NeroVision 0x02470000 3.525.1117.0 C:\WINDOWS\system32\odbcint.dll
[10:23:58] NeroVision 0x02490000 4.5.0.1 C:\Program Files\Common Files\Ahead\Lib\GCHW.dll
[10:23:58] NeroVision 0x026C0000 7.2.3.2 C:\Program Files\Nero\Nero 7\Core\NeroAPI.dll
[10:23:58] NeroVision 0x032C0000 7.2.3.2 C:\Program Files\Nero\Nero 7\Core\CDCopy.dll
[10:23:58] NeroVision 0x032F0000 7.2.3.2 C:\Program Files\Nero\Nero 7\Core\NeRSDB.dll
[10:23:58] NeroVision 0x03300000 1.0.0.18 C:\Program Files\Common Files\Ahead\Lib\DriveLocker.dll
[10:23:58] NeroVision 0x03660000 2.1.9.1 C:\Program Files\Nero\Nero 7\Nero Vision\NeroMediaCon.DLL
[10:23:58] NeroVision 0x03750000 4.5.0.3 C:\Program Files\Nero\Nero 7\Nero Vision\DVDEngine.dll
[10:23:58] NeroVision 0x03C70000 5.1.2600.2180 C:\WINDOWS\system32\xpsp2res.dll
[10:23:58] NeroVision 0x04140000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\GCFX.DLL
[10:23:58] NeroVision 0x04250000 1.1.0.865 C:\Program Files\Nero\Nero 7\Nero Vision\NeVideoFX.dll
[10:23:58] NeroVision 0x044C0000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\ExpressUI.dll
[10:23:58] NeroVision 0x04860000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\GCHWCfg.dll
[10:23:58] NeroVision 0x04890000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\GCLocale.dll
[10:23:58] NeroVision 0x048A0000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\ExpressDoc.dll
[10:23:58] NeroVision 0x05A10000 7.10.3077.0 C:\Program Files\Common Files\Ahead\Lib\MFC71U.DLL
[10:23:58] NeroVision 0x05B20000 8.0.0.0 C:\Program Files\Common Files\Ahead\Lib\BCGCBPRO800u.dll
[10:23:58] NeroVision 0x05E30000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\DVDUI.dll
[10:23:58] NeroVision 0x05E80000 1.2.0.13 C:\Program Files\Common Files\Ahead\Lib\MediaLibraryNSE.dll
[10:23:58] NeroVision 0x05F30000 1.2.0.13 C:\Program Files\Common Files\Ahead\Lib\NMVDS.dll
[10:23:58] NeroVision 0x05F70000 1.2.0.13 C:\Program Files\Common Files\Ahead\Lib\NMSearchPluginWeb.dll
[10:23:58] NeroVision 0x05FC0000 1.2.2.0 C:\Program Files\Nero\Nero 7\Nero Vision\zlib1.dll
[10:23:58] NeroVision 0x06200000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\DVDDoc.dll
[10:23:58] NeroVision 0x06290000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\DVDLib.dll
[10:23:58] NeroVision 0x062D0000 0.0.0.0 C:\Program Files\Nero\Nero 7\Nero Vision\lib3ds_dll.dll
[10:23:58] NeroVision 0x06700000 1.2.0.13 C:\Program Files\Common Files\Ahead\Lib\NeroSearch.dll
[10:23:58] NeroVision 0x069E0000 1.2.0.13 C:\Program Files\Common Files\Ahead\Lib\NMSearch.dll
[10:23:58] NeroVision 0x06BA0000 1.0.0.7 C:\Program Files\Common Files\Ahead\Lib\Nero3DMenuEffects.dll
[10:23:58] NeroVision 0x06C40000 0.0.0.0 C:\Program Files\Nero\Nero 7\Nero Vision\libxml2.dll
[10:23:58] NeroVision 0x06D20000 1.0.0.7 C:\Program Files\Common Files\Ahead\Lib\NSGResources.dll
[10:23:58] NeroVision 0x070D0000 10.0.0.3646 C:\WINDOWS\system32\WMASF.DLL
[10:23:58] NeroVision 0x07290000 1.9.0.0 C:\Program Files\Nero\Nero 7\Nero Vision\iconv.dll
[10:23:58] NeroVision 0x07370000 5.9.9.3 C:\Program Files\Nero\Nero 7\Nero Vision\cximage.dll
[10:23:58] NeroVision 0x08660000 4.5.0.24 C:\Program Files\Common Files\Ahead\Lib\GCCapture.ax
[10:23:58] NeroVision 0x086C0000 10.0.0.3646 C:\WINDOWS\system32\WMVCore.DLL
[10:23:58] NeroVision 0x09270000 1.2.0.1 C:\Program Files\Common Files\Ahead\DSFilter\NeResize.ax
[10:23:58] NeroVision 0x092A0000 2.0.7.0 C:\Program Files\Common Files\Ahead\DSFilter\NeroFormatConv.ax
[10:23:58] NeroVision 0x092D0000 5.2.3790.3646 C:\WINDOWS\system32\Audiodev.dll
[10:23:58] NeroVision 0x09C20000 4.5.0.24 C:\Program Files\Nero\Nero 7\Nero Vision\GCFilter.ax
[10:23:58] NeroVision 0x09EC0000 1.0.0.80 C:\Program Files\Common Files\Ahead\DSFilter\NeroVideoProc.ax
[10:23:58] NeroVision 0x09F00000 1.9.3.0 C:\Program Files\Common Files\Ahead\DSFilter\NeSplitter.ax
[10:23:58] NeroVision 0x0A050000 2.1.6.1 C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax
[10:23:58] NeroVision 0x0D2F0000 2.1.0.6 C:\Program Files\Common Files\Ahead\DSFilter\NeAudio2.ax
[10:23:58] NeroVision 0x0F140000 1.2.6.0 C:\Program Files\Common Files\Ahead\DSFilter\NeAudioConv.ax
[10:23:58] NeroVision 0x10000000 7.0.0.0 C:\Program Files\Nero\Nero 7\Nero Vision\HDCC.dll
[10:23:58] NeroVision 0x15000000 7.2.3.2 C:\Program Files\Nero\Nero 7\Core\image.dll
[10:23:58] NeroVision 0x18000000 7.2.3.2 C:\Program Files\Nero\Nero 7\Core\ISOFS.dll
[10:23:58] NeroVision 0x19000000 7.2.3.2 C:\Program Files\Nero\Nero 7\Core\MMC.DLL
[10:23:58] NeroVision 0x20000000 7.2.3.2 C:\Program Files\Nero\Nero 7\Core\NeroErr.dll
[10:23:58] NeroVision 0x22000000 7.2.3.2 C:\Program Files\Nero\Nero 7\Core\newtrf.dll
[10:23:58] NeroVision 0x4EC50000 5.1.3102.2180 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.2600.2180_x-ww_522f9f82\gdiplus.dll
[10:23:58] NeroVision 0x4FDD0000 5.3.2600.2180 C:\WINDOWS\system32\D3D9.DLL
[10:23:58] NeroVision 0x5AD70000 6.0.2900.2180 C:\WINDOWS\system32\uxtheme.dll
[10:23:58] NeroVision 0x5B860000 5.1.2600.2976 C:\WINDOWS\system32\NETAPI32.dll
[10:23:58] NeroVision 0x5DCA0000 7.0.5730.11 C:\WINDOWS\system32\iertutil.dll
[10:23:58] NeroVision 0x5ED00000 5.1.2600.2180 C:\WINDOWS\system32\OPENGL32.dll
[10:23:58] NeroVision 0x60CA0000 6.5.2600.2180 C:\WINDOWS\system32\qedit.dll
[10:23:58] NeroVision 0x68B20000 5.1.2600.2180 C:\WINDOWS\system32\GLU32.dll
[10:23:58] NeroVision 0x69500000 6.14.10.6693 C:\WINDOWS\system32\nvoglnt.dll
[10:23:58] NeroVision 0x6D990000 5.3.2600.2180 C:\WINDOWS\system32\d3d8thk.dll
[10:23:58] NeroVision 0x71AA0000 5.1.2600.2180 C:\WINDOWS\system32\WS2HELP.dll
[10:23:58] NeroVision 0x71AB0000 5.1.2600.2180 C:\WINDOWS\system32\WS2_32.dll
[10:23:58] NeroVision 0x71AD0000 5.1.2600.2180 C:\WINDOWS\system32\WSOCK32.dll
[10:23:58] NeroVision 0x71B20000 5.1.2600.2180 C:\WINDOWS\system32\MPR.dll
[10:23:58] NeroVision 0x71BF0000 5.1.2600.2180 C:\WINDOWS\System32\SAMLIB.dll
[10:23:58] NeroVision 0x71C10000 5.1.2600.2180 C:\WINDOWS\System32\ntlanman.dll
[10:23:58] NeroVision 0x71C80000 5.1.2600.2180 C:\WINDOWS\System32\NETRAP.dll
[10:23:58] NeroVision 0x71C90000 5.1.2600.2180 C:\WINDOWS\System32\NETUI1.dll
[10:23:58] NeroVision 0x71CD0000 5.1.2600.2180 C:\WINDOWS\System32\NETUI0.dll
[10:23:58] NeroVision 0x72D10000 5.1.2600.0 C:\WINDOWS\system32\msacm32.drv
[10:23:58] NeroVision 0x72D20000 5.1.2600.2180 C:\WINDOWS\system32\wdmaud.drv
[10:23:58] NeroVision 0x73000000 5.1.2600.2180 C:\WINDOWS\system32\WINSPOOL.DRV
[10:23:58] NeroVision 0x732E0000 5.1.2600.0 C:\WINDOWS\system32\RICHED32.DLL
[10:23:58] NeroVision 0x736B0000 6.5.2600.2180 C:\WINDOWS\system32\msdmo.dll
[10:23:58] NeroVision 0x73760000 5.3.2600.2180 C:\WINDOWS\system32\DDRAW.dll
[10:23:58] NeroVision 0x73940000 5.3.2600.2180 C:\WINDOWS\system32\D3DIM700.DLL
[10:23:58] NeroVision 0x73BC0000 5.1.2600.2180 C:\WINDOWS\system32\DCIMAN32.dll
[10:23:58] NeroVision 0x73D70000 6.0.2900.2180 C:\WINDOWS\system32\shgina.dll
[10:23:58] NeroVision 0x73EE0000 5.3.2600.2180 C:\WINDOWS\system32\ksuser.dll
[10:23:58] NeroVision 0x73F10000 5.3.2600.2180 C:\WINDOWS\system32\dsound.dll
[10:23:58] NeroVision 0x74320000 3.525.1117.0 C:\WINDOWS\system32\ODBC32.dll
[10:23:58] NeroVision 0x74720000 5.1.2600.2180 C:\WINDOWS\system32\MSCTF.dll
[10:23:58] NeroVision 0x74810000 6.5.2600.2749 C:\WINDOWS\system32\QUARTZ.dll
[10:23:58] NeroVision 0x74AD0000 6.0.2900.2180 C:\WINDOWS\system32\POWRPROF.dll
[10:23:58] NeroVision 0x74E30000 5.0.0.0 C:\WINDOWS\system32\RICHED20.dll
[10:23:58] NeroVision 0x754D0000 5.131.2600.2180 C:\WINDOWS\system32\CRYPTUI.dll
[10:23:58] NeroVision 0x755C0000 5.1.2600.2180 C:\WINDOWS\system32\msctfime.ime
[10:23:58] NeroVision 0x75970000 5.1.2600.2180 C:\WINDOWS\system32\MSGINA.dll
[10:23:58] NeroVision 0x75A70000 5.1.2600.2180 C:\WINDOWS\system32\MSVFW32.dll
[10:23:58] NeroVision 0x75F40000 6.5.2600.2180 C:\WINDOWS\system32\devenum.dll
[10:23:58] NeroVision 0x75F60000 5.1.2600.2180 C:\WINDOWS\System32\drprov.dll
[10:23:58] NeroVision 0x75F70000 5.1.2600.2180 C:\WINDOWS\System32\davclnt.dll
[10:23:58] NeroVision 0x75F80000 6.0.2900.2995 C:\WINDOWS\system32\browseui.dll
[10:23:58] NeroVision 0x76360000 5.1.2600.2180 C:\WINDOWS\system32\WINSTA.dll
[10:23:58] NeroVision 0x76380000 5.1.2600.2180 C:\WINDOWS\system32\MSIMG32.dll
[10:23:58] NeroVision 0x76390000 5.1.2600.2180 C:\WINDOWS\system32\IMM32.DLL
[10:23:58] NeroVision 0x763B0000 6.0.2900.2180 C:\WINDOWS\system32\comdlg32.dll
[10:23:58] NeroVision 0x76600000 5.1.2600.2180 C:\WINDOWS\System32\CSCDLL.dll
[10:23:58] NeroVision 0x76780000 6.0.2900.2180 C:\WINDOWS\system32\SHFOLDER.dll
[10:23:58] NeroVision 0x76990000 5.1.2600.2180 C:\WINDOWS\system32\ntshrui.dll
[10:23:58] NeroVision 0x769C0000 5.1.2600.2180 C:\WINDOWS\system32\USERENV.dll
[10:23:58] NeroVision 0x76B20000 6.5.0.2284 C:\WINDOWS\system32\ATL.DLL
[10:23:58] NeroVision 0x76B40000 5.1.2600.2180 C:\WINDOWS\system32\WINMM.dll
[10:23:58] NeroVision 0x76C30000 5.131.2600.2180 C:\WINDOWS\system32\WINTRUST.dll
[10:23:58] NeroVision 0x76C90000 5.1.2600.2180 C:\WINDOWS\system32\IMAGEHLP.dll
[10:23:58] NeroVision 0x76F60000 5.1.2600.2180 C:\WINDOWS\system32\WLDAP32.dll
[10:23:58] NeroVision 0x76FD0000 3.0.0.4414 C:\WINDOWS\system32\CLBCATQ.DLL
[10:23:58] NeroVision 0x77050000 3.0.0.4414 C:\WINDOWS\system32\COMRes.dll
[10:23:58] NeroVision 0x77120000 5.1.2600.2180 C:\WINDOWS\system32\OLEAUT32.dll
[10:23:58] NeroVision 0x771B00
seastars
Postby seastars on Sat Nov 25, 2006 3:57 pm
NOPE! Okay, try again to show just the end of the burn log: (last words are "Len x1008". The error I see - but can't understand - is:
[10:23:58] NeroVision D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
[10:23:58] NeroVision === CDRom-Device-Map ===
[10:23:58] NeroVision TSSTcorp CD/DVDW TS-H552B D: CDRom0
[10:23:58] NeroVision =======================
[10:23:58] NeroVision AutoRun : 1
[10:23:58] NeroVision Excluded drive IDs:
[10:23:58] NeroVision WriteBufferSize: 83886080 (0) Byte
[10:23:58] NeroVision BUFE : 0
[10:23:58] NeroVision Physical memory : 1023MB (1048048kB)
[10:23:58] NeroVision Free physical memory: 333MB (341220kB)
[10:23:58] NeroVision Memory in use : 67 %
[10:23:58] NeroVision Uncached PFiles: 0x0
[10:23:58] NeroVision Use Inquiry : 1
[10:23:58] NeroVision Global Bus Type: default (0)
[10:23:58] NeroVision Check supported media : Disabled (0)
[10:23:58] NeroVision 24.11.2006
[10:23:58] NeroVision NeroAPI
[10:23:58] NeroVision 10:19:41 AM #1 SPTI -1066 File SCSIPassThrough.cpp, Line 291
[10:23:58] NeroVision Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
[10:23:58] NeroVision Sense Code: 0x24
[10:23:58] NeroVision Sense Qual: 0x00
[10:23:58] NeroVision CDB Data: 0xAC 00 00 00 00 00 00 00 01 00 00 00
[10:23:58] NeroVision Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
[10:23:58] NeroVision Buffer x098f4800: Len x1008
[10:23:58] NeroVision 10:19:41 AM #2 SPTI -1066 File SCSIPassThrough.cpp, Line 291
seastars
Postby dodecahedron on Sat Nov 25, 2006 4:06 pm
maybe you can make a zip file out of the logand post that, maybe it will let you.
i don't know how to read the NeroVision log.
since it appears that the error is during transcocding, not the actual burning, i don't know what to say.
thst doesn't sound good. but i don't know what it means.
Postby seastars on Sat Nov 25, 2006 6:53 pm
dodecahedron wrote:maybe you can make a zip file out of the logand post that, maybe it will let you.
You clearly forgot the first sentence of my first post on this thread: I'm a technoidiot. :oops: I don't know how to make a .zip file.
If anyone thinks the rest of the error log would be useful to read, though, I can try to figure out how. It's probably easier than learning how to burn Nero movies, grr! :evil:
seastars
Postby Ian on Sat Nov 25, 2006 7:26 pm
The error seems to be in the burn process.
seastars wrote:[10:23:58] NeroVision D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Things to try:
- Update Nero Vision (http://ww2.nero.com/nero7/enu/nero7-up.php). I think they're up to version 4.7 something. You're still at 4.5.
- If that doesn't work, try updating your drive's firmware.
Postby seastars on Sat Nov 25, 2006 8:19 pm
Hey, thanks! I started the fix but get "download connection problem" when it tries to access the Internet for the latest Nero file. My firewall announces when it blocks something (and lets me override), so that shouldn't be it. Hmm.
seastars
Postby Ian on Sat Nov 25, 2006 9:41 pm
I don't ever use Nero's update feature. I just download it from the website and run the setup file.
Postby seastars on Sat Nov 25, 2006 10:52 pm
I did it your way just now - and successfully burned the movie (and doublechecked the playback in DVD player)! THANK YOU! You have no idea how giddy I am right now - I have been working on this moviemaking for 18 months off and on. I made it. I made it! THANK YOU!
seastars
Postby Ian on Sat Nov 25, 2006 11:04 pm
Glad to hear that it worked. Have fun making movies!
Postby CowboySlim on Sun Nov 26, 2006 11:58 pm
OK, I was gone for the weekend, so it's all good.
But I had a something like that last week after having burned many movies successfully in the past.
So, FWIW, I repeated the transcoding of the mpg file again,
but this time "burned" it back to hard drive.
Then I used Nero Burning ROM to make the Video DVD from the saved Video_Ts folder that contained the transcoded output.
Postby seastars on Mon Nov 27, 2006 12:33 am
Thanks, Cowboy. So far (4 DVDs down this weekend), so good, though.
seastars
