Problem with saved audio compilations in Nero 5.5.10.28 .35
Postby Kinomoto-san on Tue Jun 03, 2003 9:26 am
Ok, I create a new audio compilation (MP3 files) with nero, rename some track names (CD-Text), than I save and close it.
When I re-open the compilation the files are there but the modifications are gone!
Any ideas?
Thanks in advance.
Until version .20 there's no such problem, but versions .28 and .35 have it.
Kinomoto-san
Postby Inertia on Thu Jun 05, 2003 5:02 am
I just noticed this behavior in the latest Nero 5.5.10.35.
It seems to be a bug not present in some earlier versions such as 5.5.10.7. See my comments regarding this behavior at Moving audio compilation to other hard drive.
It seems that the latest Nero releases are always Betas with buggy behavior.
Inertia
Roger That!
Postby Kinomoto-san on Fri Jun 06, 2003 6:14 am
Ok, I'll stick with .20 till a working release is out.
Thanks. :P
Kinomoto-san
