Problem with my new LiteOn Drive??? (LTR-52327S@QS0C)
Postby semit82 on Tue Feb 24, 2004 4:17 pm
What would you say if i told you that i burned a disc branded LG 48x (Prodisc Technology Inc.)
and i surfed the net a little.. and of course the SMART-BURN
kicked in.. (the LED turned to orange) but the verification process failed (the file was unreadable)
is that a bad firmware i'm having?
do i need to downgrade to QS0B?
semit82
Postby dhc014 on Tue Feb 24, 2004 4:30 pm
I would say the same thing that I said when you asked this question on CDFreaks. http://club.cdfreaks.com/showthread.php?threadid=88604
Check DMA.
dhc014
Postby dodecahedron on Tue Feb 24, 2004 4:59 pm
Postby semit82 on Tue Feb 24, 2004 6:30 pm
The DMA is always enabled in my computer...
there must be another problem...
semit82
Postby Gilbert on Wed Feb 25, 2004 3:05 am
semit82 wrote:The DMA is always enabled in my computer...
Have you checked what InfoTool found for the DMA on this CD?
Gilbert
Gilbert
Postby CDRecorder on Wed Feb 25, 2004 4:17 am
Try another disc, and if that doesn't work, try another brand.
Also, this is only a remote possibility, but you might want to try replacing the cable if trying another kind of disc doesn't help. After doing a lot of computer maintence/upgrading/repairing recently, I tried to burn a CD in my LTR-52327S, and the same thing happened, even though DMA was enabled. I replaced the cable with a good one, and everything worked fine.
ok
Postby semit82 on Wed Feb 25, 2004 7:54 am
this brand by Prodisc (LG) is excellent...
i'll just try to replace the cable and see what happends...
semit82
