Hi, I have a DVD-RW MSI DR4-A and when I tried to use the hd-burn feature in nero (5.5.10.50) on a 700mb verbatim the following message appear "Power calibration error" "Burn process failed", any idea why can be happening this?
This is the log:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 12:06:00 p.m.
ahead WinASPI: File 'C:\Archivos de programa\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 29/01/2003 10:37:36 p.m.
Nero Version: 5.5.10.50
Recorder: <ATAPI DVD DUAL 4XMax> Version: 2.17 - HA 1 TA 0 - 5.5.10.50
Adapter driver: <atapi> HA 1
Drive buffer : 8192kB
CD-ROM: <AXV CD/DVD-ROM> Version: 2.2a - HA 2 TA 0 - 5.5.10.50
Adapter driver: <sojuscsi> HA 2
Bus Type : default (0) -> SCSI, detected: ?
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD600BB-00CFC0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : ATAPI DVD DUAL 4XMax atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SAMSUNG CDRW/DVD SM-352B atapi Port 1 ID 1 DMA: On
CdRomPeripheral : AXV CD/DVD-ROM 2.2a sojuscsi Port 2 ID 0 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 335MB (343352kB)
Memory in use : 34 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: Off
24.10.2003
CD-ROM (ISO)
08:07:03 a.m. #1 Text 0 File Isodoc.cpp, Line 7589
Iso document burn settings
Determine maximum speed : TRUE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
08:07:03 a.m. #2 Phase 72 File dlgbrnst.cpp, Line 1655
BURN-Proof activated
08:07:03 a.m. #3 Text 0 File Reader.cpp, Line 115
Reader running
08:07:03 a.m. #4 Text 0 File Writer.cpp, Line 125
Writer ATAPI DVD DUAL 4XMax running
08:07:03 a.m. #5 ISO9660GEN -11 File geniso.cpp, Line 4571
08:07:03 a.m. #6 Text 0 File Burncd.cpp, Line 3744
Turn on Disc-At-Once, using HD-BURN media
08:07:03 a.m. #7 Text 0 File ThreadedTransferInterface.cpp, Line 672
original CD pos #0 + 523413 (523413) = #523413/116:18.63
relocatable, CD pos for caching/writing not required/required, no patch infos
08:07:03 a.m. #8 Text 0 File DlgWaitCD.cpp, Line 229
Last possible write address on media: 719693 (159:57.68)
Last address to be written: 523412 (116:20.62)
08:07:03 a.m. #9 Text 0 File DlgWaitCD.cpp, Line 234
08:07:03 a.m. #10 Text 0 File DlgWaitCD.cpp, Line 1693
Recorder: ATAPI DVD DUAL 4XMax;
CDR code: 00 97 34 22; OSJ entry from: Mitsubishi Chemical
ATIP Data:
Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
08:07:03 a.m. #11 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder ATAPI DVD DUAL 4XMax for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD not fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 1072257024
08:07:03 a.m. #12 Text 0 File ThreadedTransferInterface.cpp, Line 672
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 523413 blocks [ATAPI DVD DUAL 4XMax ]
08:07:03 a.m. #13 Phase 24 File dlgbrnst.cpp, Line 1655
Caching of files started
08:07:03 a.m. #14 Phase 25 File dlgbrnst.cpp, Line 1655
Caching of files completed
08:07:03 a.m. #15 Phase 28 File dlgbrnst.cpp, Line 1655
Speed measurement started
08:07:03 a.m. #16 Text 0 File ThreadedTransferInterface.cpp, Line 1978
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
08:11:21 a.m. #17 Text 0 File WriterStatus.cpp, Line 115
<ATAPI DVD DUAL 4XMax > start writing Lead-Out at LBA 523413 (7FC95h), lenght 0 blocks
08:11:21 a.m. #18 Text 0 File ThreadedTransfer.cpp, Line 222
08:11:21 a.m. #19 Phase 29 File dlgbrnst.cpp, Line 1625
Speed measurement completed: 28,6x (4.290 KB/s)
08:11:21 a.m. #20 Phase 36 File dlgbrnst.cpp, Line 1655
Burn process started at 12x (1.800 KB/s)
08:11:21 a.m. #21 Text 0 File ThreadedTransferInterface.cpp, Line 1978
08:11:21 a.m. #22 Text 0 File DVDR.cpp, Line 1495
Recording mode: Sequential Recording Mode for Multisession
08:11:21 a.m. #23 Text 0 File Mmc.cpp, Line 18938
Set BUFE: BURN-Proof -> ON
08:11:21 a.m. #24 Text 0 File DVDR.cpp, Line 1609
Start write address at LBA 0
08:11:26 a.m. #25 Text 0 File Mmc.cpp, Line 18938
08:11:29 a.m. #26 SCSI -1106 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x025B0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x40 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x73 0x03
08:11:29 a.m. #27 DVDR -1106 File Writer.cpp, Line 333
08:11:29 a.m. #28 Text 0 File ThreadedTransfer.cpp, Line 222
08:11:29 a.m. #29 Text 0 File ThreadedTransfer.cpp, Line 216
08:11:32 a.m. #30 Phase 38 File dlgbrnst.cpp, Line 1655
Burn process failed at 12x (1.800 KB/s)
08:11:32 a.m. #31 Text 0 File Scsicmd.cpp, Line 406
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 12:06:00 p.m.
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29/08/2002 01:27:50 a.m. (Adapter driver for rec)
File 'Drivers\sojuscsi.sys': Ver=3.41.0.0 built by: WinDDK, size=5504 bytes, created 28/09/2003 10:57:52 a.m. (Adapter driver for src)
Registry Keys:
