A problem with Incd,or not??Please help.
Postby lunte on Wed Jul 07, 2004 3:02 pm
HI.
I hope someone could help me out?
For many months ago I install Incd,and made a format to my fujii dvd+rw.
It has run with no problem so fare,But yesterday when I put in my disk in my plextor 708-uf (1.07)
It could recognized the disc but could not mount it why is that?
I could not transfer or delete any thing from/or to the disk,I try to reinstall incd and doing a new install of incd.
But nothing did help,I have to delete the disk,and doing a new format.
Now Is the quistion:Why can the disk suddenly be closed?What can course this problem??
Hope someone will help me to understand this problem???
lunte :D
lunte
Postby dburg on Thu Jul 08, 2004 1:11 pm
Did it mount it read-only (no possible write, delete or rename) or did it not mount it at all?
David Burg
Nero AG - Im Stoeckmaedle 18
76307 Karlsbad - Germany
dburg
Postby lunte on Thu Jul 08, 2004 1:36 pm
HI dburg.
It mount read-only (no possible write,delete or rename)
I could see all the backup on the disk,but I could not write to it.
Hope you can tell me what is wrong?
lunte :D
lunte
Postby dburg on Fri Jul 09, 2004 6:32 pm
Likely the volume integrity was left open on an interrupted write. Just copy your files to you HD, quick format the media, put back you data, and you're done.
David Burg
dburg
Postby lunte on Sat Jul 10, 2004 2:38 pm
Hi dburg.
Thanks for you help,I will try to do this next time.
lunte :D
lunte
