Problem with Decoder Pack 2.2
Postby weetoots on Sun Jan 02, 2005 1:34 am
I bought the decoder pack so the family could watch DVD's on our computer. We normally use Windows Media Player, so I got this to suppliment the WMP, as recommended by MS. I downloaded the Pack and installed it on the computer, simple enough.
Now my problem, it does not decode some of my DVD's. I read the FAQ on the Sonic site and it said that some DVD's might not be readable. OK, but they decode and play on my (4 yr old) laptop. One DVD was very interesting. It comes from a set of 7 DVD's, CBS"S "The Survivors", number 4 will not play, only gives a black screen, all of the others work perfectly. Also "BLue Hawaii" will not play.
I feel that the problem is with the software, not with any specific disc.
I tried an uninstall/reinstall, but no help.
SYSTEM: Windows XP HOME SP2, DirectX9.0C, WMP 10
512 Ram
CPU: AMD 2400
Vid Card: Radeon 9000PRO Catalyst 04.10
Toshiba SDR-1612 Drive
Any ideas??
Al
weetoots
Postby weetoots on Thu Jan 06, 2005 10:31 pm
Anyone one at Sonic want to answer this?
weetoots
